Question about Dual Car Audio & Video
Reason red light turns on on dual xdma6630 receiver
I had this problem and had to do a reset. (remove faceplate, turn on the power to aux for the car, press the 'reset' button with a pin or paper-clip for about 7 seconds, release. Put the faceplate back on and power on. I'd say it's a computer bug of some sort, at least in my case - the reset did the trick.
Posted on May 25, 2011
  • cmorwood
    cmorwood Feb 23, 2012
    this set me strait, thank you for sharing this
  • Steve Gainey
    Steve Gainey Jun 11, 2017
    Very helpful
Can't find reset button or turn receiver on, please help
Can not find the button to reset only disconnect the power connector behind the stereo for a few minutes
Mar 06, 2014 | Dual XDMA6630 In-Dash AM/FM/CD/MP3/WMA...
My new dual XDMA450 stereo wont turn on. when i take off the face plate the red sensor light is flashing. this only happens when my head lights are on. what problem am i having with my stereo and why
Check your wiring connections. A similar thing started happening to me out of the blue. The unit would work fine for a period of time, and then just shut off for no reason, and I couldn't get it to come back on. The next day, it would come on again when I started the car and stay on for a while, only to shut down again. The red light behind the face plate continually flashed, regardless of whether the receiver was working. In my case, there was something off in my red wire connection. The unit would turn on / shut off when I moving the wires on either side of the connection. I redid the connection, secured it with electrical tape, and the problem has not reoccurred. If the red wire is not the problem in your case, try the black and yellow connections. These appear to be the wires that could cause this to happen. I can't explain why the power kept repeating the power on / off cycle, unless the wires were in just the right position to be moved / jostled slightly while driving. Hope this helps.
Oct 19, 2012 | Dual Audio Players & Recorders
I have dual xhdr 6435 power is running to it but the red light won't stop blnking.
Do you have power going to both the red and yellow wires? It sounds like you may not have power going to the red wire.
Sep 25, 2011 | Dual XDM6825 CD/MP3/WMA Player
How do u set the clock on an xdma6630 cd receiver
Press and hold AUDIO key. Using volume knob to adjust, keep clicking AUDIO to browse through all options, turning them off as they somehow disable the DISPLAY button when on. With clock on, follow the normal directions from the manual: press and hold DISPLAY button until clock blinks. Set hours and minutes with arrow buttons. Leave alone to exit. Afterward you can turn all extras back on with AUDIO button/VOLUME knob. and skype
Jun 29, 2011 | Car Audio & Video
Just installed Dual XDMA6330 has no power no lights no sound
the red wire needs to go to a switced power source. unless both the red and yellow wires are getting power, the deck will not turn on.
Mar 12, 2010 | Dual XD7600 CD Player
My dual xd7500 cd player doesnt turn on anymore while hooked up only the power button light turns on nothing else works this is hooked up in my bedroom but the problem should be the same as in car can...
Is the red wire in the back hooked up to a power source? You will need that in order for it to turn on. It is the wire tells the radio to turn on when you turn your key.
Oct 18, 2009 | Dual XD-7500 CD Player
My dual xdm6820 doesnt turn on and theres a red binking light behind the face plate next to the reset button
Probably you are mising 1 voltage,check this you need to have 2 voltages ok,1 voltage has to be present on the yellow wire(constant voltage,means all the time,ok) and the second voltage on the red wire (this voltage has to be switched wiht the ignition key)check this and try to fix the problem,probably there is a fuse blown,you can use a tester light to check the 2 voltages.or if you dont want to do this just conect the yellow and red wires together and the unit has to turn on.
Mar 24, 2009 | Dual XDM-6820 CD Player
You may be using the incorrect dvd disks either DVD+R or DVD-R
or you might have dual layer DVD disks which you will nedd a Dual layer dvd writer.
Down load of of an easy to easy dvd writing program aas this may help as well.
Hope of some help
Dec 31, 2007 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Dual MXD55 W/6/5 SP CD Problems
make sure the speaker grounds are connected to the speaker ground wires on the deck and not the "chassis" ground. also make sure both power wires are hooked up to a power source. the thinner power wire is supposed to be a switched source (like the ignition key or an accessory switch) that turns the unit on and the thicker one is a constant source which actually powers the deck once the switched source is turned on.
Jul 01, 2007 | Dual MXD55 AM/FM/CD/Weather Receiver
Car Audio & Video Logo
3,333 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
