Question about Garden
Starts good with choke on-- actually runs longer than it should with the choke on but dies as soon as you switch to run. will not start or fire without choke on
  • 784 Answers
Idle settings isnt fine, Or fuel filter is old. Maybe 10% problem with carburator - is faulty.
Posted on Mar 17, 2011
    Sergeant:
    Champion:
  • 250 Answers
I would replace the fuel filter located in the fuel tank and replace spongy fuel lines. If that does not correct the problem try adjusting the high low air mixture screws on the carburetor is it has them by turning in the high speed in until you feel the least resistance then back the screw off 1 and a half turns. Then turn the low speed need in until you feel slight resistance and back that one off one turn. Try running the saw.
Starts but wont run after ignition switch is returned to the run position from the start position.
The problem is that when you have the switch in the START position, you are getting power to the ignition system, but not when in the RUN position. Most likely causes are a bad ignition switch, a faulty aftermarket alarm system [if it has one] or a bad ballest resistor wire going to the ignition coil's + terminal. You need to break out your test light and start checking to see where the fault lies.
Jul 14, 2014 | 1981 Ford F 150
1991 F350 w/460 cu starts but runs rough until warm.
sounds like auto matic choke problem try a manual choke
Jan 02, 2014 | Cars & Trucks
Toro Proline 52" stalls out after warming up
Do you know if that unit has a fuel pump or not? If not, then engine vacuum is what draws the fuel in ... but only IF the hoses involved DON'T have any cracks or splits, and they fit TIGHT on the ports to which they connect! Try using an eye dropper and squirt a little gas in the air intake under the air cleaner. Does it fire then?
Apr 19, 2017 | Garden
I have a 1994 Intruder. It only starts and runs
The hot side is running way too lean. Have your carbs synchronized may help. Try draining the bowls. Good luck.
May 28, 2010 | 1994 Suzuki VS 800 Intruder
I have a Honda XR250 that I am having trouble getting started. I think it is a '96, but honestly I am unsure. It's an MD30 frame bought secondhand in Africa. The frame actually also says Honda XR250S,...
i had the same pronlem this year cleaned the carb emtied the gas changed the oil and it would run but when i got on it it would cough and not produce power so i took the sparkplug outn filed it down and put some gas on it it fired right up n ran great for about 20 min so i replaced the sparkplug n it runs great now
Mar 15, 2010 | 1992 Honda XR 250 R
Hi i have a 1981 gsx1100et when i start it with the choke out number 3 cylinder does not run as soon as i push the choke in that starts running and number 1 cylinder stops,,, help
check your coil wires they are out of firing sequence. I believe they are 1, 4,2,3. if the firing order is correct. you may have removed the coils and and switch their position.
Feb 15, 2010 | Suzuki GSX 1100 E Motorcycles
Homelite leaf blover run with choke soon when chokeis off ,cant rev up and die
if he put fuel in it dump it out & put yours in it , if problem persist there are 2 screws on the carberator turn the 1 on the right or th bottom 1/4 turn to the left!
Jun 02, 2009 | Homelite 'Yard Broom' Leaf Blower
Garden Logo
93 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
