Question about Intel Motherboard
My motherboard have power but no display on display on monitor
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 149 Answers
Do you mean not showing at start-up system? have you check your memori and Proccesor device?
Posted on Mar 17, 2011
  • 314 Answers
Hi roystonfer33 ,
make sure the cable connected to your Monitor is securely connected and firmly in place. make sure the monitor is plugged into the power socket properly. if there is still no display, then maybe trying another cable for the display.
When my computer was power on then cpu was run but the monitor doesn't display ...
If the monitor did not display the CMOS messages as computer was booting then there is an issue either with the monitor or the video card/motherboard.
Is there a light on the monitor to show it has power to it?
Is the video cable connected securely at both ends?
If all above is true then suggest looking at video card.
Aug 26, 2013 | MSI PM8M-V Motherboard
MOTHERBOARD ON BUT NO DISPLAY
Is the monitor turn ON. Is the monitor still connected to the computer. The graphic card is bad or your monitor is bad or the mother board is bad. Check to see if the fan is working in bark of the computer of the power unit when the computer is turn on. If it is not working then your power unit is bad.
Mar 25, 2012 | Gigabyte Computers & Internet
Motherbord run but not dishplay
MY DEAR FRIEND
CAN you tell me the what is the display problem
OK
Apr 11, 2011 | Intel Motherboard
The power lite goes on and off and screen wont lite up
telepathy do not work, you need to state what computer brand, what model, what monitor, meantime follow that procedure:
1. switch off computer and monitor
2. disconnect all cables on the back of the computer and monitor
3. re-connect all cables
4. re-power your monitor (is light on? any message on the screen?)
5. re-power your computer - is there any activity on the screen?
if there is no joy:
6. change monitor for known working one and check for display,
7. connect your monitor to known working computer,
is there a display on your monitor? is there a display on borrowed monitor?
if there is display on borrowed monitor, that mean that your monitor is at fault, especially if your monitor do not work on another machine.
if neither monitor work on your machine but both work on other, this will indicate video card at fault (most probable) or motherboard, or memory all of these need to be assessed before further proceedig can be advised.
before further help is sought, state clearly what computer, motherboard type and model (all in one?), video card model, monitor model
if you find this advice helpful, vote for me
Jul 31, 2010 | Computers & Internet
No beep sound, no display but all fan are functioning
no error beep code means, everything is good as far as the computer goes.
check the monitor, make sure the power cord is pushed in tight, there is power to the monitor,and the data connector is on correctly. if it still doen't comeup, try another monitor.
Apr 02, 2009 | Intel Motherboard
DO ANYBODY KNOWS WAT TO DO IF DISPLAY NOT APPEARS
The 280W may not be supportive enough for the computer requirements and is not diverting its power correctly to power the VGA part of the motherboard.
Jan 31, 2009 | Compaq Refurbished 280WATT POWER SUPPLY...
Change power output from motherboard
Windows will automatically install your desktop monitor using generic drivers. But if it doesn't, go to safemode by pressing F8 before it goes to windows. Change your settings from there. Also, normally, CRT monitors can take more than LCD monitors.
Sep 08, 2008 | ASUS V8440 (128 MB) Graphic Card
No Beep No Display
Immediately change your motherboard.
Jul 03, 2008 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
No Beep No Display
motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
Jul 03, 2008 | Intel Motherboard
No display on screen and solid amber light on pcs' power button
it seems to be an issue with the power supply as you already tried replacing the motherboard
power supply will be less expensive do try to get it replaced first
do check that monitor iss fine
unplug the blue VGA cable which connects your monitor to the tower
if a 4 colored box moves all over the screen the monitor is fine
and if it doesn't
get the monitor either repaired or get it replaced.
Jun 06, 2008 | Intel Motherboard
Intel Motherboard Logo
163 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
