Question about Kitchen Appliances - Others
I have a 1950 Murphy radiogram which is equipped with the HMV 'Hypa Sensitive' cartridge, & takes HMV 'silent Stylus' needles.I am having great difficulty obtaining these needles, can you help please ? john.varley@hotmail.co.uk
Tech Jenkins
  • 359 Answers
SOURCE: Brand New Dx8400 Printer Wont Recognise Black Cartridge
replace cartridge, take the cartridge back to get another, this is a common issue.
Posted on Sep 08, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: I have recently bought a
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
For parts and service, you should contact Kenwood at the number in the owner's manual.
Posted on Nov 25, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima
F1 means short circuit motor triac.
You need to call an engineer.
SOURCE: how to set up a hotmail.com e-mail address?
Browse for http://get.live.com/mail/overview, it will redirect you to a page where you sign up for hotmail ID
Posted on Feb 02, 2009
  • 61 Answers
SOURCE: I have lost the instructions for my Porta Potti
Go to thetford.com and download
Posted on Nov 06, 2009
Not sure which stylus fits my sl-2500 cartridge
The proper stylus is the best you can afford. However the cartridge itself will only take certain types. To find which simply enter the cartridge make and model number into Google and see what comes up.
Actually most hi-fi buffs say it's the cartridge and stylus combined that gives the best sound, since many cartridges fit only one stylus it's often the cartridge that is the real choice. Most turntables will take a wide range of cartridges, so you pay your money and take your pick.
Mar 31, 2014 | Gli Pro SL-2500 Turntable
Have stylus & headshell.need to attatch to tone arm.what other part do I need?
sounds like your missing the cartridge......the cartridge screws to the head shell, & has 4 wires connected to it...blue / red / green / white.
then the stylus,which is the needle, attaches to the cartridge.
then the hole thing connects to the tone arm, with the head shell.
Oct 08, 2013 | Audio Players & Recorders
Gerrard AT6 Radiogram. I have inherited my parents old record player/radio. I have plugged it in & the radio works but any records I play the sound doesn't come through the speakers you can hear...
It could be that the wires to the cartridge are off, or that the cartridge is faulty. If you touch two of the 4 wires to the cartridge (when removed) with you finger and the amp on you should hear a buzz on either channel (assuming it's a stereo deck). If you do that's a sign the cartridge has gone. If you don't there's something wrong with the pre-amp in the main part.
Jul 29, 2013 | Audio Players & Recorders
My turntable does not have good sound? Is it the stylus needle?
It could be, first check all connections as they can come loose. It could also be the cartridge, the only way to find out is to get a new one. If you get a cartridge and stylus, you can fit the new stylus to your old one, if that solves the problem, you have a spare cartridge in stock, if it doesn't then replace the cartridge. If that doesn't work and the connections are good, then there is a fault on the magnetic cartridge pre-amp in your amp.
Jul 14, 2011 | Sony PS-LX300USB Turntable
Cannot locate a replacement needle without a make. Can you help? I have the number on the needle being T50HD. Is it ceramic or magnetic? I also need a manual. Thank you
The make is probably printed on the cartridge rather than the stylus but it could well be this one (ceramic)
http://www.stylusplus.co.uk/bush-t50hd-stylus-1890-p.asp
Personally I prefer to change the whole cartridge rather than just the stylus for better sound quality. At least replace the cartridge every 2nd or 3rd needle change -
You don't specify the make of equipment you need a manual for but the best place will be the support pages of the website of the original manufacturer. If you need a manual for a record-player cartridge they usually come in the box.
Feb 24, 2011 | Audio Players & Recorders
Just bought a new Shure high performance stylus for my Technics SL-1200MK2. After a few weeks of use, while a record is playing the volume on the left channel will drop significantly. If I take the...
it could be two things:
1.the tone arm wires that connect to the head shell (blue-red-green-white i think)
2. the needle arm has twisted round
Put it on the other deck if you've got one & see if it does it.
look right at the end of the needle tip,& see if it's straight & pointing down, if not carefully twist the needle arm round until it is,& push it into back in to the cartridge a little bit.
Sep 30, 2010 | Technics SL-1200MK2 Turntable
HMV Radiogram Turntable run slow at the start,
you should check under the table.
if it's a roller drive there, you can use water to clean the roller rubber and the inside edge of the platter.
If it's a belt drive, take it out and measure the length and get a replacement belt of same length
Jul 27, 2010 | Audio Players & Recorders
I have a rockola mystic jukebox & one side of the speakers does not work, i would be greatful for any tips
Either a bad connection somewhere, or one channel in your amplifier is out.
Before you try anything else, switch the amp from 'stereo' to 'mono.' If the speakers come on, your amp is good and you simply have a bad connection somewhere between the amplifier and cartridge (thing that holds the stylus"needle"). Or, possible, but not probable, a bad cartridge.
For a quick fix, switch the amplifier to "mono" and then run all the speakers to the working channel.
In the meantime, if you're handy, try switching the speaker leads and such and see if you can isolate the problem.
Kyle~
Apr 18, 2009 | Vintage Jukebox External Speakers Shelf...
Needle for Technics mk5
Ok, the needle is just a small portion of everything required to get up and running. Here is a diagram of what your going to need:
The stylus, also known as the Needle, is what you are asking for. As you can see it's only 1 of 3 items you need:
1) Headshell
2) Cartridge
3) Stylus / Needle
If you already have 1 and 2, and you need to replace #3, then we would need to know what model #2 is?
You'll need what's called a STANDARD Mount cartridge, (aka Half-inch). In addition, that cartridge will need to be mounted to a Standard Mount Headshell.
Here is a collection of Standard Mount Cartridges that will fit this model.
Try to stay away from those all-in-one configurations that look like the Concorde airplane. Over time they will damage your tonearm due to a poor design flaw. Stick with a set up similar to the image posted. You can't go wrong, and you'll have more options.
- OPTiC
The ORIGINAL 1200 TECHNICIAN.
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Feb 15, 2009 | Technics SL-1210MK5 Turntable
Kitchen Appliances - Others Logo
53 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
