Question about LG 50PX4D 50 in. Plasma Television
I have an lg j250r 50in which did not turn on.After searching on the panel i found they were 5 transistor which were short so i replace them from another 42in which had a broken screen.I also took the rf panel from the 42in and put it on the 50in..now its switching on but the screen is not full its just occupying an upper corner the rest is dark.Tried to adjust vs voltage port but no change.Vs voltage is 203v and Va voltage is 58v which seem to be normal.What shall i do? The Rf panel m refering to is the panel which host the rf socket ,hdmi av.there is some surface mounted capacitor that are short thus i replace with a 42in one
3 Suggested Answers
  • 208 Answers
SOURCE: LG 42PC3RV module LGEPDP burned hybrid IC
If the buffer drive bds. were replaced along with the ysus and zsus and this problem occured it is definately and defective pdp.
Posted on Feb 15, 2008
  • 458 Answers
SOURCE: Picture gone on an LG 42pc1dv-ec plasma. Sound OK,
Your Vs voltage is high, check if the heatsinks on the Z-sustain board are getting hot after a short time, if so replace the Z-sustain board. If not, dis-connect the Vs & Va plug connection to the Y-sustain & check if the voltages are normal (185V & 80V). If they are then your fault will be in the Y-sustain board. There is a possibility the control board (sits below the power supply) could also be a problem as it is not able to initiate the control to the sustain boards.
Posted on Oct 11, 2009
My Sherwood RX-4109 sounds "quieter" and "muddier" than it previously did. Also the "click" when it turns on in quieter. Wondering what this could mean
Main board fault. Shorted component/s at its audio output section circuit. Most common fault is with its audio output transistors. If any one of them get shorted [collector to emitter short]; this kind of fault can occur. Check 2SD1510 / 2SB2510 transistor pair at this section circuit for short. If found shorted, check all the other components related to these transistors and make sure that all are good; otherwise, the replaced transistor too will get damaged in no time. If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of many popular brand TVs and other devices are given. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 15, 2016 | Sherwood RX-4109
My 50in lg plasma TV won't turn on and no sound all it does is make a clicking sound
Short circuited component/s at its main board. Contact any service technician. Gopakumar Gopalan Google
May 13, 2015 | LG Televison & Video
Lg 32pc51 PSU shorted
Please replace the power board as card basis. It will be best, rather than trying to repair it. You'd lose both money and effort.
Feb 17, 2014 | LG Televison & Video
When i switch on 21 inch lg tv the voltage in power supply section continuously falls to 0.2 and tv wont power on
Short circuit at the main board. Check the horizontal scan output transistor for short circuit. Check its collector to emitter, or collector to base for short. Replace this transistor and check. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | LG Televison & Video
LG42PT350-U0
There should be any short circuited component/s at its horizontal scan output section circuit. In most cases, the horizontal scan output transistor is found faulty. Replace it, and check. If you wish to get some details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide / Flipcard, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Nov 11, 2013 | Hitachi 50V500 50 in. HD-Ready LCD...
Where can i get replacement screws for the base/stand for my lg 50PX1D 50in plasma tv?
I belive the screws you are speaking of are 5 mill 20 thred per , I have found them at local TV shop. They will give them to you if you ask. IF you can not find them local, e-mail me.
please leave feedback
Feb 20, 2011 | LG 50PX1D 50 in. Plasma Television
Im trying to hook up surround sounds on a 50in lg
Use the audio jacks in the Monitor Output section. See pages 9 and 19 of the manual:
http://www.hdtvsolutions.com/pdf/50PX5D-0314-50px4dman.pdf
Nov 17, 2009 | LG 50PX5D 50 in. Plasma HDTV
Just bought an LG plasma tv model 50pq30. can't
If you just bought it call where you bought it and tell them they need to send a repairman out to fix it.
Sep 11, 2009 | LG 50PX5D 50 in. Plasma HDTV
THE LG 50in PLASMS TURNS OFF ABOUT 10 sec. AFTER IT IS ON
yes ok this can be alot of things bad it could be just one of the fans not working and the unit shuts down to protech the lcd screen or i could be something bad . now when i work on thisunit i have found that the display power boards that is mounted on the left and right side of the lcd panel on of them is bad . now thee is a way to find out but i dont thing u can do it. but i wil tell u how. u have to jump out the prot transistor and un plug the plug that goes to the lcd panel if the unit stays on u will not see any picture u will only here the sound then u know that is is your panel and it is not cheep to repair. now if it stills shuts down u would have to troble shoot the other boards. iam soory i gave u bad news when u buys lcd screens u have to have big money to have it repair, let me know how it when marty
Oct 13, 2008 | Televison & Video
LG 50PX4D 50 in. Plasma Television Logo
55 people viewed this question
Computer Repairing
Computer Repairing
