Blue tooth setting in window 7 starter - Computers & Internet
  • 902 Answers
If your computer doesnt have blu tooth then it wont work. win 7 starter wont support it out of the box without drivers for it . ( your blu tooth adapter)
Posted on Mar 17, 2011
Toshiba nb505 atom bluetooth driver
1) Go to the following link:http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2861099&rpn=PLL50U&modelFilter=NB505-N508BL&selCategory=2756709&selFamily=2336267
2) go down and select your operating system3) click where it says "all categories" and select blue tooth.
4) two download links will appear. Download and install the second one first (driver package). Then if you have windows 7, download and install the first one (blue tooth stack) but only if you have windows 7. no need to install "BLUETOOTH STACK" if you have windows xp.
i hope i was helpful.
Sep 07, 2012 | Toshiba NB505N508BL 10.1" Intel Atom...
My computer is not picking up the head set. I've tried to do it manually also.I have a gateway touchscreen with windows 7. can u help please?
You must put your blue tooth device into discovery mode ,most manufactures use the power button for this feature ,,by holding it for 6 to 10 seconds when turning on your blue tooth device,thenwhen searching they will pair,you will have to enter a pairing code .Most blue tooth manufactures use a 4 digit pin or pairing code they are as follows 0000,1234,9999 or 1111 i hope this helps
Feb 20, 2011 | Dynex Mono USB Headset with...
Bluetooth video is blocking my webcam on my labtop. i can not get access to my webcam it says that the bluetooth is blocking it.
If your not using blue tooth try turning it off. You didn't say what operating system your using. On windows 7 you can just click the window icon and type blue tooth in the search window. It should find your default program and get you to where you need to be to turn it off. :You may have some thing on your task bar that allows you to turn off blue tooth. Also try opening control panel and selecting device manager, Look for anything that list blue tooth and disable it. You might have a program on the the program bar under accessories that is listed as blue tooth. Somewhere you should have a way to turn it off.
Feb 17, 2011 | Computers & Internet
How can i connect htc p 3400 mobile with sony vio window 7.
you can connect your phone via blue tooth,data cable or infrared.switch on blue tooth of your both devices than let your other device discover your phone.It will ask to connect allow it to connect.
Jan 07, 2011 | Computers & Internet
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
I want to know where i can download free driver for isscbta blue tooth dongle?
isscbta blue tooth dongle originally comes with blueSoleil
which can be downloaded at http://www.bluesoleil.com/download/Detail.aspx?PID=1
Works with windows XP, Vista and windows 7
Jun 22, 2010 | Computers & Internet
I have downloaded windows 7 ultimate on my sony vaio vgn-cr353 notebook but mine blue tooth and wi fi is not working what i can do for that
Go to your blue tooth website and wi fi website and download the drivers for windows 7 and if it is 34 bits or 64 bits, this should work.
May 23, 2010 | Computers & Internet
BLUE TOOTH DOES NOT WORK...WITH 4736
Go into your devices manager and check to see if the drivers for your bluetooth are installed,you may have to install them yourself
Apr 12, 2010 | Acer Aspire 5500 5570-2609 Laptop
Blue-tooth problem with windows 7 in my vostro 1510
This should be it
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R155395&SystemID=VOS_N_1510&servicetag=&os=WLH&osl=en&deviceid=13911&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=1&libid=5&typeid=-1&dateid=-1&formatid=-1&fileid=207293
Go to the website and download the driver
There is help on downloading drivers on Dell's website
I hope this helps!
Nov 21, 2009 | Dell Vostro 1510 Laptop
How do I turn bluetooth on and connect a Mobile phone to a Acer Aspire 5710G
Windows Mobility Center includes Acer-specific settings like Bluetooth Add
Device (if applicable), sharing folders overview/sharing service on or off, and a
shortcut to the Acer user guide, drivers and utilities.
To launch Windows Mobility Center:
Start Windows Mobility Center from the Control panel
Start Windows Mobility Center from the Accessories program group in the
Start menu
You should be able to turn on blutooth from there.
Please let me know if this helps.
Mar 17, 2008 | Computers & Internet
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
