Question about Microsoft Kinect for Xbox 360
Need wiring diagram for x box kinect usb cable to see what wires are what
    Scholar:
  • 107 Answers
Can I make my Xbox 360 kinect sensor wireless as I would need a really long cord to plug it in
Sorry but no. You can pick up a Xbox Kinect extend link cable. There is a 15 foot cable for $19.99 usd. Try this site. Xbox Kinect Extend Link Cable
Dec 05, 2014 | Microsoft Kinect Sensor for XBOX 360
Microsoft kinect sensor for xbox 360 wont work unless my controller is turned off
Hi Chris, can you please check this setting:
1. Go to "System Settings" on your Xbox 360.
2. Select "Kinect Settings".
3. Choose "Chat Microphone".
How is it configured here?
Mar 23, 2014 | Microsoft Kinect Sensor for XBOX 360
3Way Wiring Diagram
If you want to run the fan and light separately and the light is on a 3 way switch you will need 2 dimmers and one of them will be a 3 way dimmer. You need a 3 wire cable running up to the ceiling fan and the 3 way 3 wire cable coming from the one switch box to the other switch box. If it runs to the light first and then to the other switch box you would need to replace one of the 3 wire cables with a 4 wire or 5 wire cable. It's hard to find a wiring diagram for your situation unless you give a lot more details. If you can't explain what you have then this is complicated enough to have someone knowledgeable on site.
Nov 24, 2013 | Electrical Supplies
Battery cable wire box
I am sorry but you will need a wiring diagram booklet from the manufacturer.
Nov 22, 2013 | 1994 Nissan Pathfinder
Wiring Diagram For Usb flashdrive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually ((red white green black)) make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
or
PRODUCT NAME
FRONTX USB Type A Internal
PRODUCT CODE
CPX101-2
BAY USAGE
Half of large bay
CONNECTORS
USB type A female
1x5 header connector female
CABLE
USB cable (UL 2725)
Length - 2.5 feet (762 mm)
WIRE ASSIGNMENTS
Red: + 5V / Voltage + / VCC
White: D - / Data - / USB -
Green: D + / Data + / USB +
Black: GND / Voltage - / Ground
Black: S-GND / Over Current / Shielding
The S-GND wire is fatter and can be easily recognized. The connection of S-GND wire to the header pin is optional.
HEADER CONNECTION GUIDES
Diagram 1: On most motherboards, the USB header/pin-out consists of 9 pins arranged in 2 rows, which allows for 2 USB connections (i.e. USB1 and USB2). Normally, the pins for USB1 and USB2 are in seperate rows.
Diagram 2: Simply plug the connector onto the 5-pins row, and make sure that the pin assignments and wire assignments are matched correctly.
Diagram 3: Alternatively, you can plug the connector onto the 4-pins row, and leave the S-GND wire unconnected.
You might have to rearrange the wires to match with the pin assignments, or change the header connector if necessary, depending on the layout of the USB header.
On some motherboards, there is a NC pin in the USB header. You can connect the S-GND wire onto this pin. NC simply means "no connection" and NC pin is an "empty" pin.
2X5 PINS HEADER
Refer to the diagram below, for 2x5 pins header, simply plug the connector onto one row of the pins, and always make sure that pin assignments and wire assignments are matched correctly. You might have to rearrange the wires if necessary.
2X4 PINS HEADER
Refer to the diagram below, for 2x4 pins header, simply plug the connector onto one row of the pins. Please note that there is no S-GND pin in this header. You can leave the S-GND wire unconnected. You might have to rearrange the wires if necessary, in such that the wire assignments and pins assignments are matched correctly.
ACTIVE PINS NOT IN THE SAME ROW
On some motherboards, the 4 active pins are not located in the same row, as shown in the example below:
To connect to this type of USB header, you need to change the header connector to 2x5. Simply rearrange the wires within the 2x5 connector to match with the pin assignments. If the green wire is connected to the USB2+ pin, the white wire must be connected to the USB2- pin. The red wire can be connected to any +5V pin, and the black (GND) wire to any GND pin. If there is no S-GND pin provided, you can leave the S-GND wire unconnected.
hope it helps
Sep 23, 2012 | Lexar Media Echo ZX 32 GB Flash Drive
The problem with the kinect is C000022D
http://support.xbox.com/en-us/pages/kinect/more-topics/errors/red-light-kinect-sensor-5.aspx Red light on the Kinect sensor Last Modified 4/22/2011
Page Content kinectred_300px.gif If the light on your Kinect sensor is red, the sensor might not be connected properly or your console software might need updating. You might also receive one of the following errors:
A problem has occurred with your Kinect Sensor (C000022D)
A problem has occurred with your Kinect Sensor (C00000C2)
Here's what to do to fix the problem:
update_error.jpg Solution 1: Update your console software
  1. Insert a Kinect game disc.
  2. Start the game from the Xbox Dashboard.
  3. If your console software needs updating, you will see the following message:
    Update Required: An update has been found, to apply this update you must restart your console.
  4. Select Yes, Restart to install the update.
If you still get the same error message, try the next solution.​ ​ ​ Solution 2: Check the cables ​ ​new360cableconnect.jpg
Xbox 360 S console
  1. Turn off the console.
  2. Unplug the sensor from the console, and then plug the sensor cable into the AUX port on the back of the console.
    Important Remove the power/USB adapter cable if your Kinect sensor came with one.
  3. Turn on the console.
Original Xbox 360 console
  2. Make sure the power cord is plugged into a working electrical outlet.
  3. Make sure the USB connector is plugged into the back of the console.
  4. The light located near the middle of the split cable should be green.
    No green light? Try plugging the cable into another outlet to make sure that the cable is working properly. If you still do not see a green light, your cable might need to be replaced. Contact
    Xbox Support.
  5. Turn on the console.
If these solutions do not solve the problem, please contact Xbox Support
Jul 19, 2011 | Video Game Consoles & Games
XBox Kinect says insufficient power I've tried unplugging and plugging into a single outlet but same problem. What can i try next?
Red light on the Kinect sensor Last Modified 16/05/2011
kinectred_300px.gif If the light on your Kinect sensor is red, the sensor might not be connected properly or your console software might need updating. You might also receive the following error:
The Kinect Sensor has insufficient power (C0051202)
If you still get the same error message, try the next solution.? ? ? Solution 2: Check the cables ? ?new360cableconnect.jpg
Xbox 360 S console
    No green light? Try plugging the cable into another outlet to make sure the cable is working properly. If you still do not see a green light, your cable needs to be replaced. Contact Xbox Support.
If these solutions do not solve the problem, the sensor needs to be repaired. To start the online repair process, go to myservice.xbox.com.
Jul 04, 2011 | Video Game Consoles & Games
How to connect the xbox kincet
If your Kinect only has one cord coming off of it, that should go into the back of your Xbox where there is a color coded slot (orange).
Feb 28, 2011 | Microsoft Xbox 360 Console
Trying to connect the kinect
First off make sure you have at least 190 mb of space in your HDD before trying to set up your kinect.
Setup:
Step 1: Make sure your xbox 360 is properly connected to the television with the AV cables and power cable to an outlet.
Step 2: Place sensor under or on top of your television on a stable flat surface.
Step 3: Depending on your xbox the sensor has two different connections. If you have the new slim xbox 360 then you do not need the extra add on connection you simply connect it to a special port for it on the back of your xbox 360 slim. If it is a older version xbox then you will need the extra power adaptor since it will not work without it.(Cable with power connection)
Step 4; (ONLY FOR OLDER VERSION XBOX 360): If you have a wireless connection adaptor unplug it from the usb port in the back of the xbox 360 and connect the kinect sensor's power adaptor into the port you took the wireless connection adaptor off of. There should be a special cable that will act as an extension for the wireless connection adaptor you unplugged this is so you can connect it directly to the usb ports in the front of the xbox 360. Then plug the end with the power outlet connector of the kinect sensor power adaptor into the wall socket.
Step 5: Turn on the xbox 360 and the kinect sensor should move up and down to adjust.
Step 6: Put kinect game in and it will guide you through kinect settings and your on your way to start playing! Have Fun!
Feb 26, 2011 | Microsoft Xbox 360 Console
I need wiring diagram for a usb to parallel db25 female printer cable???? help
You cannot wire a USB serial cable to a parallel printer cable, but you can get a USB to parallel printer adapter cable.
Click on this link for details :-
http://www.techbuy.com.au/p/82381/Generic/USB-DB25.asp
Dec 24, 2009 | HP SureStore CD-Writer Plus 7200e...
Microsoft Kinect for Xbox 360 Logo
732 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
