Question about NetGear WNR2000 Wireless Router
I am unable to connect to wii - NetGear WNR2000 Wireless Router
  • 902 Answers
Make sure your wii can see your netgear if it is mac address blocked use must unblock your mac address and then let let the wii to connect then save the mac in the ok list nad turn the filter on again also if its encrypted you need the password. and make sure you are broadcasting your ssid. does your wii see yours or any network at all?
Posted on Mar 17, 2011
Unable to connect wii console to wireless internet via iPhone.
Its is impossible to connect any of the nintendo wii, ds, dsi, and 3ds to the internet unless you have the wii net connect from GameStop for $20.
May 31, 2011 | Nintendo Wii Console
I just signed up for netflix and am trying to hook it up to my wii to watch movies. The wii is properly connected and hooked up, and we have a wireless internet connection in my home, however when i go to...
Error code 51030 means you Wii is unable to connect to your wireless network.
Try unplugging your modem and wireless router, then plugging them back in after a couple minutes.
While you're waiting for your modem and router, delete your network setting from your Wii, and set them back up once your router and modem are back up.
Your wireless router's setting might have changed and your Wii might not be able to properly connect.
May 08, 2011 | Nintendo Wii Console
I have internet through cable.it runs through the sb5101u surfboard motorola modem. i bought the lan adaptor to go to the wii, for netflix, but it won't connect to the internet. error code 52020
Here is the solution from nintendo:
  1. Power off the Wii. Connect the official Nintendo Wii LAN adapter to the Wii, and insert a working ethernet cable into the official Nintendo Wii LAN Adapter.
  2. Unplug all devices from your modem. Most modems are unable to support more than one device at a time.
  3. Power cycle your modem. To do this, unplug the power from your modem and let it rest for 20 seconds. Plug the power back in. Connect the Ethernet cable from your Wii console to the Ethernet port on your modem.
  4. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input theseexactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
  5. If you are still unable to connect and you are using broadband Internet, then your ISP likely uses PPPoE to establish a connection to their network. The Wii is not compatible with PPPoE. Contact your ISP for more assistance.
May 05, 2011 | Nintendo Wii Console
Unable to connect Wii to internet
When you go to the Wii options->wii settings->internet->connection settings->connection 1..clear settings. Then go back to connection 1 and click 'wireless connection' Then 'search for access point'. Your wireless should be one of the choices(plus any nearby neighbors). If no wireless connections available then recheck your router. If you are sure there should be an access point and the Wii didn't find it, possibly defective wireless in the Wii.
Apr 03, 2011 | Nintendo Wii Console
Bought a pre owned wii and im trying to hook it to the internet but it says error 52020
What to do will depend on how you are connecting your Wii console. Please use the info below that describes how you are connecting.
Connecting directly to a modem:
4. If the connection test fails, try a Manual Setup with the Wii console, using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these exactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
Mar 15, 2011 | Nintendo Wii Console
I am trying to hook my wii to the internet and it is saying unable to connect error code 51420 and i need free advice or help.
The Wii console is not able to connect to your wired router or modem.
1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
From the Wii's main menu, select the Wii icon along the bottom left of the screen.
Select "Wii Settings".
Click the left arrow to get to Wii System Settings 3
Choose "Wii System Update"
Choose "Yes" to connect to the internet and perform a Wii system update.
2. Make sure that you are using the Wii LAN Adapter made by Nintendo (click here for a picture and connection steps). LAN adapters not made by Nintendo likely will not work with the Wii console.
3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off. For step by step connection instructions, please click here.
5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
6. If possible, try another Wii LAN Adapter. If you are unable to try another Wii LAN Adapter, or are still receiving this error code, please call 1-800-255-3700 for assistance.
For any help click here
Jan 04, 2011 | Nintendo Video Game Consoles & Games
Madden 09 giving unable to connect error
make sure you have put the correct friend code on both ends. one digit will mess things up.
Jul 31, 2009 | Nintendo Madden NFL 09 for Wii
Unable to connect wii fit board to console
This is really very frustrating when you face such kind of problems. You may check out Wii Fix Guideto fix the problem yourself. This DIY guide will show step by steppictures to fix the problems yourself without any technical knowledge.
Jan 19, 2009 | Nintendo Wii Console
The wii is unable to connect to internet
It seems that it can't establish communication to your access point.
Nintendo Forum explanation:
Wii Error Code Group: 52020, 52021, 52022
Summary: Connection difficulty with either router or modem.
If automatic configuration is not working (it expects DHCP to anser; i.e. to get an assigned IP address) try manual configuration. Enter the values as you would on your PC to connect to the network.
Consult the Nintendo Forums for detailed help.
Jun 12, 2008 | Nintendo Wii Console
NetGear WNR2000 Wireless Router Logo
56 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
