Question about Car Audio & Video
I need code for estereo HONDA CIVIC EX MODEL 99,
  • 4,963 Answers
HONDA do not make radios .They only affix their badge ontoradios made by the large manufacturers (ALPINE , BLAUPUNKT etc). First try https://radio-navicode.honda.com/ If the above suggestion is not successful ,then unfortunately the code will not be availablefor free (or cheap ) from anywhere onthe Internet. Will only be available from your Main HONDA Dealer or a Radio DecodingService
Posted on Mar 17, 2011
Are 00 Honda civic tail lights compatible with 99 Honda civic.
As long as it is the same body style (ex. 2 door) they will interchange from 98-00
Mar 11, 2011 | 1999 Honda Civic
How i can replace the cranksaft for a 99 honda civic ex
If you need to replace a crankshaft for a 99 Honda Civic EX, it may mean that there's more damage to the engine than is worth inputting financially for that service.
Is the engine knocking severely indicating a bad main bearing? If so, a replacement used engine may be more economical than rebuilding the one you have.
Good luck on this repair.
Dec 18, 2010 | Honda Civic Cars & Trucks
I have a 99 civic ex i need my radio code please my serial or at least the number i found in the glove box is M98D200895
if you call the honda dealership the will give you the code for the radio but they need a number form you they will either have you pull the radio and get the number off the back of it or have you hold presets 1 and 6 at the same time to get a number from the radio once they have that they can give u the code
Sep 28, 2010 | 1994 Honda Civic Del Sol
What other engine will fit a 97 civic ex?
The 96-98 Civic EX came with an OBD2A D16Y8 engine. That is the only engine that will go in as a direct replacement with your current engine ECU. It's an SOHC VTEC engine that has two extra connections not found on the other 96-98 Civic engines - a VTEC solenoid and a special oil sensor used to determine if VTEC engagement is possible. If you swap in an older Civic engine (92-95 generation) you'll have to convert the car to OBD1 (requires a special adapter hardness) and run the ECU that goes with whatever engine you use. This will break functionality of your OBD2 diagnostics port, and depending on which state you live in will cause you to fail emissions checks. If you install a D16Y8 engine from a 99-00 Civic EX, you will have to swap the intake and exhaust manifolds from your old engine to the new engine, and you will be able to continue to run your existing OBD2A wiring and ECU. The 99-00 Civic EX engines have additional sensors, since those engines are OBD2B. The easiest fix would be to find a SOHC VTEC D16Y8 from a 96-98 Civic EX, as it would be a direct plug and play replacement.
Apr 16, 2010 | 1997 Honda Civic
I need the Stereo code for a '99 honda civic ex. Serial #M98N243340
you will have to contact a local honda dealer with the radio serial number and your vin and they should be able to help you get it
Feb 28, 2010 | 1998 Honda Civic
'99 honda civic ex., 4cyl vtec- check engine light on. Would like to know if there's a way to check for the diagnostic trouble code/codes without an obd2 device...thanx
I don't believe there is a different way, Im sure you know that autozone offers free diagnostic with there store use obd2 device.
Dec 28, 2009 | 1999 Honda Civic
NEED RADIO CODE FOR 2002 HONDA CIVIC EX U2311
Factory radio? If so, ONLY the dealer can help...They might do it free...my guess is they'll charge you $40.
Good Luck
Jun 23, 2009 | Car Audio & Video
I need radio code
contact your dealer they should be able to provide you with that information
Robert
Sep 09, 2008 | 1999 Honda Civic
Jorge
como poner el codigo del radio
Jul 31, 2008 | 1999 Honda Civic
Car Audio & Video Logo
126 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
