Question about Kitchen Ranges
The rectifier wires were pulled off. Have 2 blue wires and a red and a black to put back on 4 terminals of the rectifier , need a schematic to refit the wires
  • 396 Answers
You can check with a voltmeter and see which 2 wires have AC voltage in them.
Go with a 500 VAC (Volts AC) and carefully test the wires. Only 2 will have voltage.
The other 2 will be dead. My guess is the 2 blue wires will be AC. BE VERY CAREFUL.
Have a helper there to unplug the unit should you touch what you shouldnt.
After you determine which have AC unplug the stove and look at the rectifier. It should have
a ~ looking stamped in it where the AC goes on 2 of the terminals. The other 2 should have a
+ and a - . Red usually being positive connect Red to the +. Black being negative connect Black
to the - . Should do the trick. Let me know if it doesnt look that way.
If you want a schematic, give us Name Brand and exact model number. We will try to find
it for you.
Posted on Mar 17, 2011
Schematic for logitech z313
I couldn't find a schematic but...
The red and black wires go to the subwoofer.
The white and black wires are main level inputs that go to the toroid.
The blue, green and black wires are the output from the rectifier.
Tthe green is your negative rail while the black is 0v and the blue is positive
Sep 05, 2016 | Logitech Audio Players & Recorders
Wiring rectifier correctly?
You are discussing a bridge rectifier, the + connector is directly opposite the negative connector, the remaining two connection points are the AC side of the rectifier + AC
AC -
Apr 05, 2015 | Kipor Generator Kge2400 - 2400 Watts
Help with element on a wta2000 dryer
Terminal block goes:
1 white/brown
2 light blue and dark blue
3 not used
4 black/white and Black (t/stat)
Element
Far left pair terminals - black(t'stat) and black from loom
Right pair of terminals - red
Single terminal - blue from reset stat
Feb 18, 2013 | Bosch Dryers
I need the wiring for the mic
Here is the wire diagram for several common mics in relation to a 4 pin CB. Most recent 4 pin CB's such as Midland, Cobra, Connex, Uniden, etc can use 4 pin mics. The wiring is actually depending on the mic rather than the CB so long as the CB's are 4 pin as well. Once you go back to late 80's the 4 pin design was a little different. Anything new it is simpler.
Stock Mic 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - 4 wire 1- Shield 2- White 3- Red 4- Black
static - 6 wire 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500 Cobra CA Series 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - 4 wire 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta 1- Shield 2- White 3- Brown 4- Green
Turner RK56 Road King 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Regards, Tony
Apr 07, 2011 | Connex Radio Communications
How to connect a four wire pigtail
The white wire goes to the middle terminal post on the dryer.
The red and black wires go to the outside terminal posts.Doesn't matter which.
The green ground wire needs to be attached to the outside metal case...anywhere. The easiest way is to put the eyelet on the screw that attaches the terminal cover plate when you put it back on. Sandwich it between the screw head, the plate and the case.
Hope that helps. Let me know if you need more info
Best, G
Aug 02, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Wiring a TPH553 Surface Mounted Jack by RCA.
TPH553 T568A T568BPin 1 - BL White/Green White/Orange Pin 2 - OR Green Orange Pin 3 - BK White/Orange White/Green Pin 4 - RD Blue Blue Pin 5 - GR White/Blue White/Blue Pin 6 - YL Orange Green Pin 7 - BR White/Brown White/Brown Pin 8 - WH Brown Brown
REF: wikipedia
Feb 17, 2010 | Computers & Internet
Lakewood heater 7101 schematic
The power cord goes the switch terminal 1 and 3.
Terminal 2 must be the opposite of terminal 1, such that when switched on, 1 & 2 connects. Terminal 4 must be the opposite of terminal 3, such that 3 & 4 connects.
Under this setup, you may connect red to terminal 2
and black to terminal 4.
Be sure of the 1 & 2 pair, as well as the 3 & 4 pair.
then, connect the red and black wires.
Hope this will help you.
Jan 06, 2010 | Lakewood Oil-Filled Electric Radiator...
I have a Cobra 21- 23 channel CB and the wires pulled out of the plug. The mike wire has red,yellow black,blue,whiteand a ground. My plug has only four prongs to solder to. What four colors do I use?
Hello there
Here is the diagram for you
Cobra 29LTD, 29LTD ST, 29WX ST
Documentation Project
CBTricks.com
TIPS:
You need to have Acrobat Reader version 5 or newer installed to view the files with pdf_1.gif icon.
If the files with jpg.gif or gif.gif icon will not display see the Site FAQ for help on printing, viewing and using this information.
Click Picture to See Close-up
DIAGRAMS
Page 1 to 11
Page 12 to 34
29LTD
29 LTD Classic Schematic Diagram pdf_1.gif(Courtesy of Rick Jackson)
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Astatic (4 wire)
1- Shield
2- White
3- Red
4- Black
Astatic (6 wire)
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
Galaxy DC-521S (4 wire)
1- Shield
2- Yellow
3- Red
4- Black
Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue
Sadelta
1- Shield
2- White
3- Brown
4- Green
Turner
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
Nov 17, 2009 | Cobra 29 LTD CB Radio
I have an E38 7 series I need to know the wiring connections to the 2 wiper relays, I have 3 small wires and the power feed wire that have corroded and become detached from the relay holders. What...
Got this from Mitchell
On left Relay Red/Brown 8
Brn Blue 4
Brown 5
Red/White 2
Red/Blue 6
On Right Relay
Red/Brown 8
Brown/Black 4
Black/Brown 5
Black/Brn 2
Red/Blu 6
Nov 04, 2009 | BMW 750 Cars & Trucks
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
