Question about Dryers
I have adryer and it won't start has power. Any advice?
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Mar 20, 2011
Laptop won't boot - Compaq
Do you see anything on the screen? Does the HDD LED blink? You can start by removing the HDD and testing it or have it tested.
Jun 06, 2013 | Compaq Computers & Internet
New battery still won't start 2007 Lexus RX 350
Did Robert Garcia's advice work for you? I have the same problem
Jul 16, 2012 | 2007 Lexus RX 350 FWD
Still waiting for an answer about my Chrysler 2002 Town & country. QUESTION : Fan won't blow when car is ideling will start after I start driving again.
I would need more info to give any advice.
I assume you mean the blower for the ac and heater.
How is it not working but works on high ?
And what power are you turning off that makes it blow harder ?
Jul 12, 2012 | Cars & Trucks
My dishwasher won`t start. NO light are open. The electrical power it's ok.
It is possible that themachine does not start off the cycle because there are errors or feedback fromthe inputs. For the program to start up the main program controller mustinitiate the INLET/PUMP MOTOR/DRAIN to workwhen it is commanded .If this does not happen then the voltage at thesepoints must be checked or the faultrelates to no voltage/drive from the controller. This means the controller is asuspect.Check howto remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html If thewater flows then the flow should be good, if not the inlet valve is bad or thereis dirt in the filter. Also check the flow at the inlet of the water line. Whatis most important for the motor to start functioning is that the door switchmust be ON when the door is shut or this will be an error for starting themotor. The water pressure must be good and the spraying must be seen to begood. If there is low pumping or pressure then the spray arms will not turnaround to inject with pressure. If sothe pump must be checked for clogging.To replacecheck this link:http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html Finallyafter the wash the drain valve will be activated, the water is allowed to comein to rinse and then finally the drain valve/pump activated so as to drain offall the water.Make surethat a fault in any of the cycle will relate to the specified action, so checkthe command from the program module and then the executing device be it thevalve or motor or pump. Please check the link below:http://www.espares.co.uk/advice/dishwashers/a/3
Jan 27, 2012 | Blomberg DW 15140 Full Console Dishwasher...
Maytag LAT9635AAE won't start wash cycles
you can try to check the water level sensor Assembly this unit controls the fact that your washing machine will not wash until the proper water level is reached, this unit has a rubber hose attached to it and a wiring plug or connector for the electrical power to activate the motor.
Jan 10, 2012 | Maytag Washing Machines
Got spark and gas can't get it running what is the conpression supposed to be
i have a honda power washer EXHA2424, I replace new spark plug, new gas., cleans the cabureetor, and it still won't start please advice me what to do
May 21, 2011 | Devilbliss DeVILBISS Devap DVH2600...
Gps won power up when car charger burn frm fuse
Unfortunately it sounds like when the car charger went bad it also did in the board on your tt. It would be cheaper to just purchase another unit than to get this one repaired out of warranty. My advice would be to sell it on ebay. People buy these all the time for spare parts.
Hope this helps
May 09, 2009 | Tomtom GPS
How to replace the rear felt seal on a whirlpool electric dryer
http://www.repairclinic.com/SmartSearch/smartsearch.aspx?SearchText=`ADryer
May 11, 2008 | Dryers
Dryers Logo
29 people viewed this question
Top Dryers Experts
