Question about Car Audio & Video
Amp hook up
How do you hook up 2 amps and 2 12'' 1 10''.... the amps are 2000 watt and 750watt, 12''s to the 2000 watt 10'' to the other????
  • Paul David
    Paul David Aug 02, 2008
    hey thanks , i read the stuff over like 4 times it will be help full.
  • 631 Answers
To do it safely, you need to fully understand everything about the system. It would take too much to explain everything here. If you're really interested in doing this properly, read through the following site. Read the 'Fuses' page twice. It will help prevent an electrical fire.
Basic Car Audio Electronics
Posted on Aug 02, 2008
How do i get full power out of my kenwood kac-1520s amplifier hooked up to two 12" audiobahn 400 watt subwoofers
Your amp is under powered for those speakers (350 max. watt). Even if your subs were 2 ohm your amp will only put out 75 watts X 2 at 2 ohms, if you bridge that amp you might be asking for trouble . I'm guessing there both 4 ohm. Look around for a 2 ohm stable mono amp with more power and you won't be sorry. Ray
Apr 23, 2014 | Car Audio & Video
I have to hook up 4 amps in my car. 4 channel 700 watt ken wood, 2 channel 800 watt Sony, 4 channel 740 watt Jensen ,and a 2 channel Rockford fosgate. Which is best way to hook them up so I'm not ki
Pace posted on Saturday, March 05, 2005 - 01:08 GMT Your subs are dual 4 ohm voice coils so if you want to bridge your 2 channel amplifier to your two subs then wire them parallel, meaning the + to + and - to - ( Do this to both subwoofers), Then run a wire from one positive and one negative on each sub and bring the two positives together and the two negatives together and hook both positives to the far positive connection on your amp and connect both negatives to the other negative on your amp,
This will create a 4 ohm load on your amp.
Although if it's a two channel and you have two subs it's usually pointless to bridge them because if you use one channel per subwoofer its going to be the same as if both subs were bridged. example) 800 watts x 1 bridged power of your amplifie (4 ohms) is the same power as 400 watts x 2 at 2 ohms.
Nov 26, 2012 | Computers & Internet
Yes does anybody know how to run speaker wires from a two channel 750watt amp to two 12" kicker comp 8ohm subwoofer's
Is this a trick question? An amp only has speaker outputs (plus and minus) and the speakers have corresponding inputs. Each channel would probably drive one sub.
Jun 14, 2011 | Pioneer 750-Watt Home Theater System,...
Just bought 2 12 in d3 dual 2 ohm subs with d5 600.4 amp. Need to know how to wire subs. They were in a box already I assumed they were wire at 2 o When i hooked One up to my amp it hit really for Jus...
what wattage are the subs and amp? if your subs are more wattage than your amp, your amp will blow fuses as cant handle the output to your subs. for example. you have 2 500 watt subs and a 300 watt amp, that is no good as amp isnt powerful enough. if you have 2 500 watt subs you need at least a 1200 watt amp to power them both. 200 watt more than the combined wattage of subs as amps should never be turned up to max as they tend to blow and overheat more quickly. 80% volume on amps is reccomended by installers and manufactures.
Feb 27, 2011 | Diamond Audio D5-600.4 Car Audio Amplifier
GENERATOR WILL NOT MAKE POWER AT PLUGS ONLY MAKES 23 AMPS
Your manual says only plug 20Amp loads into each 120 receptical. See manual at: http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=fequxHX-nfBhU7y
that would be 4 recepticals tmes 20 = 80 Amps'
80 Amps times 120 V = 9,600 Watts This means that you cannot hook up all 4 outlets at the same time as that would overload the generator all you can hook up would be 2 outlets of up to max of 23 Amps
The manual restricts you to each load no more than 20 amps because some devices such as drills, water pumps exceed their running load upon start up, and would exceed the 20 Amps momentarily, thus 23 amps.
The maximum power load of the generator is 5000 watts and 20 amps at each outlet.
You certainly are within the useful range.
Volts time Amps = Watts
Jan 10, 2011 | Briggs & Stratton Briggs and Stratton...
How i wire my sub to my jbl gto301-1iiamp with 2 Hifonics HFi12D4
If the amp is 1200 watts at 2 ohm stable you will want to set up the speakers as parrallel and bridge the amp. That means conncect the speakers with + to + and - to -. Look at the amp connections. Usually thereare connects that look like this:
If yours look like this use the diagram on top. You will use the + for the left ouput on the amp to the right - on the amp. This will allow you to use all the power from the amp. Be sure to lower the gain as to not pop the speakers or amp.
Nov 17, 2009 | JBL GTO 301.1II Subwoofer Mono Amp - 200W...
Can i hook up a powered 12'sub to a Pheonix Gold xs2500 amp without blowing the speaker
First I hope you remove the speaker wires from the speaker that come from the built in amplifire. You cannot hook the powered sub to the amp without doing that first. Then all you need to do is run speaker wire from the sub out of the box to the amp. In no way can you hook up any other part of the powered sub, but the sub itself, to the amp. If you know the wattage of the sub and the ohms then wire it to the amp correctly. Your phoenix amp will put out 125 watts x 2 at 4 ohms and 250 watts x 2 at 2 ohms and 500 watts x 1 at 4 ohms bridged. Remember, only the sub itself in the sub enclosure can be connected to the amp. Hope this helped you. Let me know if you need more help.
Aug 23, 2009 | Phoenix Gold XS2300 Car Audio Amplifier
240v/750watt heater on 20amp
Yes, a 20-amp, double pole breaker will easily support that heater.
The calculation:
Watts = Volts x Amps
750 watts = 240 volts * x
x = 3.1 Amps
Charlie
Aug 22, 2009 | Heating & Cooling
I have 2 kicker l7 12s 4ohm speakers and was
Hello gonenutz14,
It depends on how you define the "best way". Driving each sub with a separate 750 watt amp will result in about 50 percent more power than having them share the output from a single 1000 watt amp. But with 2 amps, there's more wiring issues to contend with and the adjustments are more complex. The 2 750 watt amps will cost more than a single 1000. Plus if the 1000 watt amp is stable to 1 ohm, the power difference will actually be less than 50 percent because of the lower impedance. But if the 750 watt amps are also stable to 1 ohm and their outputs can be combined, we're back to 2 being better than 1.
I'd say that the simplest, most economical way is to use a single amp. If maximum power to the subs is the highest priority, and cost and wiring is not an issue, then 2 is better.
Hope this helps.
Jul 12, 2009 | Car Audio & Video
I have a memphis amp that puts out 250 watts @ 4ohms and 500 watts @ 2 ohms. I want to hook up 3 sony 12'' explods @ 4 ohms a piece. How do I wire them to the amp to get the maximum output of 500 watts?...
well to be honest your amp probly cant handel 3 speakers because of the impedance levels so just hook up 2 bridges out to + to - on one Speaker then from that same speaker run + and - to the next one
A= amp
S= speakers
A:::::::::::::::::::::::::::::::S:::::::::::::::::::::::::::::S
Mar 22, 2009 | Car Audio & Video
Car Audio & Video Logo
101 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
