Question about Whirlpool LER5636P Electric Dryer
Whirlpool dryer runs but does not heat
We moved to an older home and when we set up our washer and dryer the dryer stopped working. It woked but did not heat up. the clothes were still wet. We took it to get repaired but they told us there was nothing wrong with it. we tried it again. Few months later we decided to just buy another one. It is a Roper and did the same thing. I mentioned to my husband that it may be somthing with the vent which goes down to the basement...not outside. We also checked the voltage it measures up to 220, .......please help.
  • angelabrown2 Aug 06, 2008
    dryer blows cool air only, dryer is only 2 and a half years old
  • 481 Answers
The problem could be the wiring in the house. the dryer not only needs 220v but also a good ground/neutral. this is a common misunderstanding when people test their outlets with a meter. this is happening too frequently to be a problem with the dryer(s)
whirlpool dryer runs but does not heat - 9bed73e.jpg pic borrowed from fixitnow.com
Posted on Aug 06, 2008
  • Mike Durland
    Mike Durland Aug 06, 2008
    • to angelabrown2: first turn your breaker off then back on and try it.
    • if it still doesnt work then let me know.
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
I have a Whirlpool LER4634PQ1 it was working just fine then all of a sudden the dryer just keeps running the knob on the dryer doesn't move and the air isn't warm. Any suggestions on what to s
there is a cycling thermostat in line with the high limit thermostat and timer circuit,on timed dry its disabled and the timer will run no matter what,on any sensor dry setting it uses the heat of the element to heat this cycling thermostat to move the timer as the clothes get drier as the heating element heats the timer doesn't move,when the heater cycles off from the high limit thermostat then timer moves again,you need to find out if its a bad heating element,thermal fuse or possibly even a circuit breaker in the homes electrical panel tripped out on one of the 2 phases that gives you the 240 volts required to operate the dryer element,the breaker may not show its tripped,so shut it off and back on and try this first
Dec 11, 2012 | Whirlpool Dryers
Whirlpool Duet Dryer Tripping Breaker on Heat Cycle
It caused the problem. Appliance repair person
May 13, 2017 | Whirlpool Dryers
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
The dryer runs, but absolutely no heat.
look in the back and see if the heat box come lose this can happen from moving the machine as well as lots of use the heat box usually is held in place with a spring binders they can break but you can fix with a spring from the hardware store older machines have this issue as well as out of balance machine combos not all units have this set up but it is a start make sure it is unplugged before working on it hope this helps
Aug 30, 2010 | Whirlpool LTE6234D Top Load Stacked...
Tumble dryer isn't woking
You may need to replace the thermostat or the heating element.
Apr 13, 2009 | Hotpoint -Ariston Aquarius WD645 Front...
As long as the timer is on your heating element will be on.Sounds like you've have lost both.
Feb 11, 2009 | Whirlpool LEQ9858P Electric Dryer
It runs, but no heat
i dont believe at this time its anything mentioned at top most people dont realize that dryers are split cuircuts
is this a 220 setup
and if its a 220
the cuircuit breaker for this is set by 110 each one for the heating element one 110 for the guages and motor
goto circuit breaker and flip the breakers this should return your dryer working ability
other thing is are the guages working properly
dryer doesnt have to run to test guages turn to the highest setting and let them run completly threw cycle if they stop on a particular setting for a long length of period then the guages are bad
May 29, 2008 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool LTE5243D Top Load Stacked Dryer heats sometimes and not others
couple things this could be lets start obvious
faulty door switch even though door latches doesnt mean its working properly
bad guages easy to check dont have to run dryer just guages
turn on setting let run threw cycle if it stops on cycle and dont move for a length of time this will be the problem
these 2 things are main causes of why a machine wont work or partcially works at times everything else is easy
Nov 27, 2007 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool LER5636P Electric Dryer Logo
99 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
