Question about EuroCave V256 Wine Cooler
I need to replace the compressor on a EuroCave unit - where is the best place to get this and how much should it cost?
How do you remove and replace Eurocave performance control board Eurocave 283
The control panel is held up by two hidden screws (that are not removed) that slide into slots of the top front of the panel and 2 removable Philips screws at the back of the control panel which hold up both the controls and circulation fan.
Unplug the unit. Open the door, remove both chrome screws in the ceiling behind the control panel and put them where you can reach them.
While holding up the fan assembly, slide the control panel forward. It may bind a bit so work it forward carefully to prevent scratching the black finish.
As you pull it forward the fan will want to drop down, so once the control panel has moved forward enough to clear the fan panel (about 1/2") you can insert the screws and finger tighten them to hold up the fan as you remove the panel.
Label the wires before unplugging as they are not all individually keyed and look very similar. Note any unused connectors. You need to unplug the large black power connector, black wire for fan connector, and a white temperature sensor wire(s) before removing the panel. You can leave connected the white wires for lights, display and local humidistat that are part of the panel until the panel is removed.
The power supply board and display board are mounted to the control panel assembly with screws and connected by a ribbon cable and wires. Label any remaining connectors and wires before removing the circuit cards. I think the ribbon cable is only removable on the display board and permanently attached to the power supply board. There are replacement parts available from WineEnthusiast.com as well as 3rd party Eurocave circuit card repair services you can find on the internet.
When reassembling follow the opposite order and note the fan panel mounts ABOVE the control panel on the ceiling of the unit. Gently slide the control panel into backwards into place lining up the slots onto the fixed 2 screws while holding up the fan panel and then install the 2 screws behind it to hold both in place.
Jul 05, 2014 | EuroCave Performance 283 Wine Cellar
When plugged in, the compressor doesn't activate. When you press the test button, the compressor turns on. After doing that about fivetimes, the compressor won't even flip on? This is a Eurocave Model...
if you keep starting it it will quit any way . but this sounds like a start relay or a bad or run cap / but you could have a bad compressor also . and if running on a long ext cord it cause this problem so ck these / hope this has helped mm feed back pls ..
Nov 25, 2010 | EuroCave S256T Wine Cooler
Eurocave comfort 264: Problem, ice formation inside the unite , half the way the middle section of the unit ( Racks 8-10)
It's likely that you need to change the filter. Have a look at this post: http://blog.wineenthusiast.com/2009/04/20/caring-for-your-eurocave-3-simple-steps-towards-long-lasting-wine-protection/
Sep 30, 2010 | EuroCave Comfort 260 Collector's Package...
Model no. 210e/3 which when plugged in throws the trip switch . owned by Bob Earl, Earls Court, Cotham, Newark. NG23 5JS
This is a serious malfunction and is most likely caused by the compressor or fan motor being defective or a severely damaged cable.
First, with the mains plug removed from the mains socket check the plug for being loose or any damage. Take off the top cover and check that the wires are still firmly anchored to the connecting posts and the securing screws are tight. Check that there are no stray wires showing and make sure that the outer cable sheath is firmly secured by the nylon securing strap. Then check that the mains cable from the plug to the appliance has not been cut, crushed or appears to be damaged in any way or has been lying in water. Also make sure that there is no fluid leaking out of the unit.
Then try plugging the unit into a different socket to make sure that the socket itself is not defective. If this is OK then the most likely case of the problem will be a compressor or fan motor seizure. This will need a service engineer visit to rectify the problem. Contact EuroCave directly on 0207 935 4679 if you are in the UK or your nearest fridge servicing engineer.
Sep 21, 2009 | EuroCave Refrigerators
Problem with compressor
it is entailed process and you would need axcess to torch oxy-acc w #2 tip and silver solder, a evac pump, deep vac pump and container to capture the old freon usually compressors come with a new filter and the electrical parts per normal without sweep charge this process can take up to 4hrs to perform not for the unskilled if you do not remove the moistier from the system the new will fail shortly.....sorry for the news its be done by a professional...
Aug 19, 2009 | EuroCave Comfort 260 - Black Solid Door
Eurocave digital thermometer
The digital temperature display on the EuroCave has a small lithium battery that can be replaced by removing the bezel around the display. This was all that was needed to solve the problem.
Jan 22, 2009 | EuroCave Comfort 260 Collector's Package...
Eurocave Repair
can you tell if if it's running by putting your hand on the compressor,then we can go from there
Dec 17, 2008 | EuroCave Comfort 260 Collector's Package...
EuroCave V256 Wine Cooler Logo
669 people viewed this question
Top EuroCave Refrigerators Experts
Jim London
Jim London
Tom Chichester
Are you an EuroCave Refrigerator Expert? Answer questions, earn points and help others
