Our SHARP ES-S601X Washing Machine is 8 years old already. We were still able to use it until recently when it began to show an Error "C2" and then automatically shuts off. Is there an online site where I cold check on what that Error "C2" means? Or probably you could provide me those information so I could get addiditional assistance from any SHARP Service Center nearby. Thank you!
2 Suggested Answers
  • 6277 Answers
SOURCE: MY Sharp ES-S601X washing machine
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 10, 2011
Testimonial: "Thanks a lot. It helped and worked."
Sharp es 950 top load washing machine as on same time beeping and showing e2
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Error code details to washing machines are given.
Dec 07, 2015 | Washing Machines
Error f57 siemens WM14S794GB Front Load Washer
Bosch Logixx 8 Only 4 years old. Inverter Print burned out creating error F57.
Jul 27, 2013 | Washing Machines
Sharp washing machine,ES-AG950 hangs during the spin cysle.
Sounds like its tripping the drum vibration sensor or a temp limit sensor on your motor.
Apr 09, 2013 | Washing Machines
Drum wont spin in washing mode. it only works for rinsing and dry spinning. sharp ES-M38 washing machine
Because i know nothing about Sharp washers could you tell me if it's front loading or top loading? Is it less than 6 years old? Does it give any error codes? Thanks.
Jan 20, 2013 | Kenmore Washing Machines
My Sharp Washing Machine ES-6515TS still drains even if the drain control is already closed and sometimes water goes out to the spinners tub.
PROBABLY THERE ARE THINGS THAT BLOCKING THE DRAIN, IT MIGHT BE COINS, PARTS OF CLOTHES, PANTY OR HANKY. SIMPLY OPEN THE BACKSIDE OF YOUR WASHING MACHINE, UNSCREW THE DRAIN LINE COUNTER CLOCK WISE TO OPEN THE VALVE FOR DRAIN. YOU'LL BE AMAZED OF THINGS PRESENT INSIDE THE DRAIN VALVE. AFTER THAT IT WILL BE OK FOR YEARS. I BROKE MY SPIN DRY MOTOR AND RUBBER BELOUSE, FUSE 3X. SHARP TECHNICIAN CAN'T FIND THE PROBLEM WHICH I DID AFTER 5 YEARS. I HOPE IT WILL BE HELPFUL TO YOU.---ROMMEL OF MANILA PHILIPPINES.---rtlagasac@hotmail.com
Jan 09, 2011 | Washing Machines
All lights flash and error E90 shows on my Zanussi ZWF1631 washer
e90 is a cable problem linking main board to user board on the front
Jan 12, 2010 | Washing Machines
My Sharp ES-A50S washing machine won't spin dry. the alarm warning that the lid is open always sounds off even though I closed it already. what should I do????
ok your problem is due to some problem with lid sometimes a heavy wait on lid of dry drum makes it settings wrong alignment is not correct plz call the mechanic there it will fix
Sep 14, 2009 | Washing Machines
C2 error
aeg lavamar error c2
Dec 25, 2008 | Maytag NFW7200TW Front Load Washer
Washing Machines Logo
156 people viewed this question
Top Washing Machines Experts
