Question about Philips 42PFL5332D 42 in. LCD Television
AT NIGHT, TV SWITCHES ON AUTOMATICALLY AND CHANGES FROM SIDE AV TO OTHER OPTIONS, I.E. PC / HD 1 ETC. LAST NIGHT TV SWITCHES ON, CHANGED TO HD1 AND TURN VOLUME AUTOMATICALLY TO 0. CAN'T GET VOLUME UP. WHEN I TOUCH VOLUME BUTTON ON REMOTE AND/OR TV, TV CHANGES FROM SIDE AV TO HD1 OR OTHER. HAVE PROBLEMS FOR 2 WEEKS THEN STOP, THEN STARTED AGAIN. SOMETIMES WHEN WATCHING TV, VOLUME SCREEN APPEARS ON TV SCREEN AND TURNS DOWN AUTOMATICALLY.
  • 4,924 Answers
What you describe is almost impossible ..the only explaining is someone with a compatible remote control messing around with you ..so ...pay attention ..and after that if you are completely sure that this is out of case...Leave a comment and I will search for another possible cause ..
Posted on Mar 17, 2011
  • 2 more comments
  • joeyb808 Mar 17, 2011
    NO ONE IN THE VICINITY THAT CAN CONTROL MY TV. COULD YOU KINDLY ASSIST AGAIN. MY TV IS SITUATED 1-METRE FROM MY FISHTANK AND THE FISKTANK IS COVERED IN CASE OF CONDENSATION. DO YOU THINK IT MIGHT BE THE TANK? BOUGHT TV TWO YEARS AGO AND SAME PERIOD FOR FISH TANK. THANKS
  • Catalin Turcu
    Catalin Turcu Mar 17, 2011
    The fish tank can not interfere with the tv signal ..cause the signal is a infra-red based and not radio or some other kind..so in this case it is an internal issue with the Tv .. or some strange settings in the preset area ..(like the setting for to start on a certain hour by itself )
    try to get into the menu ..and look for factory default setting and engage them ..THis should reset the Tv to the factory settings and get rid of any strange settings that may be done on it ...and case these behavior..This can only be done from the Tv menu itself and not from the remote ..so ..just look in the main menu of the tv ..and you will find the factory settings ..engage and confirm with OK ..
    If after that it is still doing the same ..than you should have it checked by a professional or if it is still in warranty ...change it ..cause it is defective ..
  • Catalin Turcu
    BY the way ..this kinda tv can be controlled not just by a remote ..but from a mobile phone ..with infrared and a program that transform it in a remote.....so ..it can be someone in the house that does not like your taste in TV programs ..
    THANK YOU. I CHECKED THE FACTORY DEFAULT BUT VIA THE REMOTE. WILL FIND THE MANUAL AND TRY DO TO DIRECTLY FROM TV. HOPE I CAN FIND THE BUTTONS. THANK YOU. WILL KEEP YOU POSTED. CAN'T IMAGINE BEING DEFECTIVE, HAD TV FOR TWO YEARS WITHOUT PROBLEMS.
No picture just av1
If the cat sat on the remote, it is likely it changed the tv to AV1. Just find the AV button on the remote and press it again and again. It should cycle through the different AV channels your TV has - my TV has 6 AVs, 2 HDMI and a PC channel so if yours is anything like mine, you may need to press several time to get back to your Sky/freesat/virgin box. Alternatively, some HDMI connected kit just needs turning off and on. That then sends a signal to the TV which changes the TV automatically. For example, my Blu-ray player does that.
Experience - I have a cat that sits on my remote and does the same thing!!
Jul 31, 2012 | Panasonic 37" VIERA Full HD 1080p IPS LED...
Why does my Sony STR-K750P AV receiver automatically switch to Video 2?
Some models of systems will switch to a new source automatically if the source sees a new signal coming on. Try disconnecting the device on your Video 2 to see if this is the case.
I have seen the IC or component(s) in the switching circuits become defective and cause unpredictable or faulty operation. This can also be a fault condition you are seeing.
Apr 02, 2017 | Sony Str-k750p Av Reveiver
I have the system hooked up and it comes on but not o the tv screen do i need the hd cable to make it work it is a flat screen tv please let me know what to do i have playstation 2 already hooked up and...
Are you using the AV connector cable? If so look on your tv for an av channel. Best thing to do though is Try using a HDMI cable. Most tv's recognise when a HDMI cable is plugged in and the tv switches automatically to the HD channel.
Hope this helps.
LJ.
Apr 17, 2011 | Sony Playstation 3 (PS3) Console
Samsung plasma tv trying to get hd will not go down to hdm as not in bold print skips past have pluged in to hd1
Some HDMI cables for some reason aren't compatible with some AV equipment. If you can, I'd try a different brand of cable.
Feb 27, 2011 | Samsung Televison & Video
New Yamaha AV Receiver and Tannoy Speakers muffled weak bass only
Maybe some wire is faulty... Try to disconnect everything and connect each speaker one by one, first trying only radio tuner and then trying to connect the TV and other devices. Using that you can isolate the fault into the specific component/wire.
May 26, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Insignia NS-PDP50 Plasma TV - Remote Sensor failure
Change batteries.Reboot everythings.Tv unplug,replug couple mins later.Ur Directv box,push off/on for new update software.After that sould work.Rate me after u done this.
Jan 02, 2010 | Insignia NSPDP50 50 in. HD-Ready Plasma TV
First tv kept tuning on in middle of night now its kepts tuning off while ur watching
I don't know what might have been making it turn on in the middle of the night. It it keeps turning off while you are watching, you might want to check if:
1) someone is accidentially hitting the SLEEP button on the remote. The TV will turn off automatically 30, 60 or 90 minutes after the sleep button is hit. It can also get hit if you set the remote between seat cushions on the couch and someone moves, etc.
2) Does the TV get enough ventilation to allow heat in the TV to circulate away from the set? Drapes, tight cabinet, etc. The temperature sensor may turn the TV off automatically to protect the TV.
3) Your power cord is not well plugged into the wall or you might have some issues with the wall outlet - expecially if it is an older home (before 1980). Any wiggle of the cord may cause it to disconnect for a very short time - the TV will shut off.
4) This Brand is only available through BEST BUY and this model has a 1-year warrentee. The manual says to call 1-888-BESTBUY for service.
Good luck.
Please rate me.
Nov 23, 2009 | Dinex DX-LCD26-09 26 in. HD-Ready LCD TV
Screen dull & automatically goes into hybernate
The dim screen is going to be either the lcd or inverter. As far as constantly going into hibernation mode. go into power options and make sure where it says turn off monitor and turn off hard drive are set to never. If that doesn't work then that mean you might have a virus, trojan, etc on the computer.
Feb 24, 2009 | Acer Aspire 1640Z Notebook
My Ant A Input Not Working
Good Day, babt;
TRY THIS:
MAY ONLY BE ABLE TO SELECT ANTENNA A AND B. WITH THE REMOTE CONTROL PRESS MENU, SELECT "SET UP" AND THEN "AV CONNECTION HOME THEATER" SET "AV NETWORK" TO "OFF" AND "TV LOCKED TO INPUT 1" TO "NO" THEN EXIT THE CUSTOMER''S MENU, TURN THE UNIT OFF UNPLUG IT AND THEN PLUG IT BACK IN, IF THE PROBLEM RETURNS AN E2 RESET IS NEEDED. ACCESS THE OPTION MENU BY PRESSING "MENU 1, 3, 7, 0", USE THE ADJUST BUTTON TO SELECT "E2 RESET" AND PRESS "QV". IF THIS IS NOT RESOLVED BY THE E2 RESET REPLACE THE EEPROM, IC701 PART # 275P163010. THE E2 RESET IS ALSO NECESSARY AFTER REPLACEMENT OF IC701.
Good Luck, big IRISH.
Aug 06, 2008 | Mitsubishi VS-50603 50" Rear Projection...
Problem with viewing DVDs
Video format error. change pal or ntsc and try
Feb 27, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Philips 42PFL5332D 42 in. LCD Television Logo
162 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
