Question about Air Conditioning and Heat for Mazda 323 Hatchback
Mazda 323 2002 hatchback. The aircondtioner has stopped working on dial 1,2,3 nothing happens but on dial 4 the fan works. If I have it on 1,2,or 3 before going to 4 then cold air is blown through for a while so i think the airconditioner part is still trying to work but the fan wont work on 1,2,or 3. before this happened the car had not been driven for 10 days and prior worked fine.
  • 93 Answers
Please try to pull down the resiistor block located at the aircon evaporator there are black box with a female connector four pin.use a multitester to check the continuity point the probe to the terminal number 1 and terminal 2 check weather there is a continuity go with 1 and 3.then 2 and 3 and 4 if no continuity replace the resistor block
Posted on Mar 17, 2011
I have a Mazda B2500 TD 4 wheel drive, the fan control dial does not work on 1, 2 and 3 but does on 4 but if the air con is switched on while dial is on 4 then it kicks the air con off. What is the...
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 16, 2011 | 2007 Mazda B Series
Hi, The windscreen wipers on Mazda 3 hatchback 2008 have stopped working. I think it's the fuse, but I can't find the fusebox. And I have no manual.
One fuse box is at the feet of the passenger. all you have to do is undo 2 half-twist fasteners, and the other fuse box is under the hood right behind the battery. I hope this helps. as to what fuse, i have no idea.
Dec 04, 2010 | 2008 Mazda Mazda3 Hatchback
The fwd vents are not blowing the way they should but the back vents are working fine
One of three things is happening if it's not the A/C system itself, like a leak, or a bad compressor:
1. The blower motor is going out.
2. The blower motor resistor is going out.
3. The vacuum line on the heater valve has popped off.
4. Fan Clutch is going out.
How to eliminate each one:
#1 If you turn the speed dial and the motor doesn't speed up like it should, it's probably the motor.
#2 If you have NO blower at some point on the speed dial (for example, you have blower on 1, 2, and 3, but nothing on 4, or nothing on 1, 2, and 3, but 4 works, or all positions are full blast) it's the resistor.
#3 is pretty deceptive. You will be fine while cruising down the highway, but when you hit a hill, or load the engine a little, the air will start blowing up the defrost vents. If you look under your coolant surge tank, right behind the A/C drier/accumulator (shiny aluminm cylinder thing that will be wet if you have the air on) you will see a black, round, thing with black hoses hooked to it. There should be a small black vacuum line stuck in the end of it. The line will have a 90 degree rubber end on it. If it is not there, it's popped off. I don't know why they do this, but they do. The line will be close, feel around for it, and stick it back on. Put your coolant surge tank back on and you're set.
#4 You can diagnose that by listening for a chattering or rattling sound at the front of the van while it is idling, or WITH THE ENGINE OFF reach behind the fan shroud and see if you can wiggle the fan front to back. If it wiggles, it's bad. MAKE SURE THE ENGINE IS OFF BEFORE TOUCHING THE FAN!!!!
There are a few more things it could be, but these are the most common ones in my experience. I work for a mobile fleet maintenance company and I service about 250 2007 to 2009 Express vans...I see a lot of the above 4 things. RARELY is it the A/C system.
May 14, 2010 | 2007 Chevrolet Express Passenger
My 2000 Mazda MPV heater fan works for 4 not for 1
You need to replace the blower motor resistor,it's in the heater box.Number 4 bypasses the resistor and all the other speeds go through it so it's the most likely problem.
Feb 19, 2010 | 2000 Mazda MPV
Air Con cuts in and out and so does cooling fan
I have a 2008.5 Mazda 3 GS Sport and when you turn the air flow selector to windows or windows/floor, the air condition will turn on automatically. (Can't turn it off.)
Nov 12, 2008 | 2008 Mazda Mazda3 Hatchback
Mazda 3 gas cap stuck 4x since purchased new 7/29/08
Happened to me a few times....Finally this am it broke.... boooo! Reference Service Bulletin SB-01-050/08 when you bring it in hopefully you can get it for free!
Sep 28, 2008 | 2008 Mazda Mazda3 Hatchback
Speed Dialing
hold the number that you assigned untill you see the number of the person (hold about 2 sec) when the number shows up press talk botton
Oct 19, 2007 | Uniden TRU9485 Cordless Phone
Vehicle Parts & Accessories Logo
148 people viewed this question
Top Mazda Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
JOHN LAPIER
Gary Nitowski
Are you a Mazda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
