Question about Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer
Wont stop at end of cycle unless u push of button alrady replace timer and motor and motor brd
  • 314 Answers
Hi christian742,
I highly recommend for you to read the Manual which came with the machine.
it should include detailed instructions on how to stop at the end cycle without pushing.
Posted on Mar 17, 2011
Timer won't stop after cycle finished.
Dryer will not shut off:
The timer: Located in the control console of the dryer the timer consists of a small motor connected to a series of gears that rotate cams, which turn electric contacts off and on inside the timer. The timer contacts control the dryer motor as well as the heat circuit and the timer motor itself. A defective timer motor or a defect in the timer's electrical contacts can cause the timer motor to fail and the timer will need to be replaced. The contacts can be checked for continuity with a multi-meter. This test should only be made when the dryer is unplugged. Another test u can do is observe by eyesight and see does the timer advance or is it stuck on one cycle?
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Lastly check the moister sensor for OHMS according to ur schematic as it must show a certain amount of ohms as per ur unit. When unit has been on short while
May 20, 2015 | Dryers
Fridge stops to defrost and wont start again unless i do it manualy by turning the timer with a screw driver.
A mechanical timer defrost cycle is approximately 23 minutes, and it occurs at intervals of between 6 and 12 hours depending on the timer. If it does not come out of the defrost cycle on it's own, your timer can be bad. Be sure the heater actually comes on while in defrost. Also be sure the evaporator (freezer) fan is on when in the cooling cycle. If both of these occur. Replace the timer. It's important that the timer be replaced with an identicle timer.....6 hour for 6 hour, and that the 4 numbers by the electrical contacts be in the same order. In addition, if there is a loose wire from the timer motor with a slotted contact at the end, make sure you follow the instructions as to where it goes.
Aug 08, 2011 | Bush HD220RWN (6 cu. ft.) Bottom Freezer...
Washing machine will not advance through the wash cycle, machine will fill tub and begin wash cycle but will not move on to the rinse cycle. The washing machine will remain in the wash cycle and can only...
Hi, Your timer motor burnt out, or timer faulty, remove top back panel (back of timer) and check timer motor, if timer motor are built-in (electronic type) you'll have to replace timer, or if timer motor can be remove, replace it, check back of timer, (knob you turn to change cycles or programs) locate timer motor, you can check appliance store to purchase timer motor, or let mechanic check, surely it's your timer motor or timer, check let me know,
Aug 12, 2009 | Whirlpool WTW5800SW
Kenmore washer 110 24642300 will not go past spin cycle. it will just get towards the end of the spin cycle and will keep on spining. unless i lift the lid and push in the start button. thanks
if your machine is getting stuck in aspin cycle and no longer advancing out on its own, sounds as if you have a dead spot on the timer, reccomend replacing timer
Jun 09, 2009 | Kenmore Washing Machines
Maytag mah4000aww wont stop running.
It sounds like your timer needs to be replaced. The timer runs the washing machine in a pre-determined pattern. It provides the electricity to all of the washing machine components at the correct time and for the correct length of time.
Jun 07, 2009 | Maytag MAH6500 Neptune Front Loading...
Coil is freezing on freezer
Yes, the seal will let outside air into the unit causing the coil to ice up. When it ices up the air cannot blow through the fins in the coil, thus no cold air goes to the refrigerator section.
Dec 20, 2008 | Whirlpool GB2SHKRLS Stainless Steel Bottom...
Kenmore dyer
sounds like the timer, unless it has a Evenheat contol board and a seperate motor relay, in which case its most likely the relay, or could be the computer
Sep 29, 2007 | Kenmore 64892 Electric Dryer
Dryer won't stop running
the dryer wont stop running only when open door will it start a fire?
Sep 14, 2007 | Kenmore 62802 Electric Dryer
My Dryer Starts, then stops as soon as I release the button.
Its possible the dryer heat selector is at fault. If the timer inside does not move to the end of the heat cycle you may have further problems. Depending on how old the dryer and how long it has taken to dry garments, you may want to check that the motor has not gone bad causing an electrical overload. Faulty timers will cause extended drying times eventually putting a strain on the motor's bearings and electrical windings. You may want to get a replacement or get a repair estimate to repalce the belt, motor, drum rollers and heating coil components.
May 12, 2007 | Kenmore 63932 Electric Dryer
Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer Logo
27 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
