Question about Canon iP4700 InkJet Photo Printer
An errorr 6a80 has been occured to my printer and it could not be solved by turning it on and off!! i removed paper that was jamed but it was not solved!!!what should i do?
  • 902 Answers
Two possibe solutions i found researching this for you
  • Switch the printer OFF
  • Press buttons 1 + 2 + 3 and 4 (simultaneously using four fingers)
  • Keep pressing this four buttons for 10 seconds
  • Release the On/Off button (number 4) (Keeping pressing the others)
  • After a few seconds (when the printer go ON), release buttons 1, 2, 3
if that doesnt work try
  • I discovered that the head was blocked from moving all the way to the right by a white nylon lever and discovered that there was a thin, small pad that had come loose and was blocking the mechanism to activate the head motion.
  • One pad was about 1/2 inch by 1/2 inch and a second was a narrow 3/32 x 1/2 inch pad both about 1/16 thick.
  • I removed these pads and the printer returned to normal
please let me know asap if this works
Posted on Mar 17, 2011
Canon MX870 error 6A80
Hello friend,
APP position error or Error Code 6A80
Condition: An error occurred in the APP motor.
Problems and Solutions:
  • Check for foreign material or paper debris around the purge drive system unit
    - remove foreign material.
  • Check for foreign material or paper debris around the ASF unit
  • If other solution fail, replace one off the following part
    - Purge drive system unit
    - Logic board
From http://pcmediks.blogspot.co.uk/2010/11/canon-pixma-error-codes-and-solution.html
Aug 25, 2014 | Canon PIXMA MX870 Wireless Office...
Jamed paperc86 paper is jamed
Epson Stylus InkJet Clear a paper jam in printer
Jan 05, 2012 | Epson Stylus C86 InkJet Printer
The paper is jamed into the roller, by how i removed this paper from the roller.
Remove back cover. Remove the paper. Otherwise remove fixing unit and then remove paper. If the problem occurs often check the tefflon sheet. If you find tonner spread on tefflon change the tefflon sheet.
Feb 07, 2011 | Canon LASER SHOT LBP 3300 Printer
Hi, I have a "dead"
    - Logic board
for more info visit: http://pcmediks.blogspot.com
Dec 28, 2010 | Canon Pixma MP450 All-In-One InkJet...
My cannon printer MX700 just now paper have jam inside. After i taken out of paper that jam inside my cannon printer have a error of 6A80 and it can't fixed. Pls help. Thanks.
The 6A80 indicates that the mechanism called the `purge unit' does not work correctly. In some cases after a paper jam, some paper gets in the unit. Try this:
Turn on the unit and open the cover. Hopefully, the printhead will come to the center. If it doesn't, unplug the printer and try to move the printhead by hand, to the left. Do not force it. If you are able, get a flashlight and inspect the area inside the unit to the right. There may be bits of paper in that area. Being careful, remove it with a tweezers or some such tool.
If you cannot see anything, then the machine will need to be dismantled for service. I recommend authorized service.
Sep 20, 2010 | Canon MX700 Office All-In-One InkJet...
I have a Canon MP550 and after pressing ON button in few seconfs appeares message: ERROR CODE 6A80
[6A80] & Light Blinking 12 times = APP Position Error. An error occurred in the APP motor. Maybe foreign material or paper debris around the PURGE UNIT (at the printer most right hand side) or Auto Sheet Feed area.
May 24, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Printer error 6A80 when printer is turned on. No paper jam noted. Tried unplugging, and turning off and on.
6A80
6a90
c000
6C10 feeder unit and / or purge unit defective.
Blocked Zahnrad-/Kupplungs-Verbindung between the two systems / defective.
Troubles with purge pump and or purge tube plugged (clogged). Needs service tech.
Nov 24, 2009 | Canon PIXMA MP620 All-In-One InkJet...
What does 6A60 error message indicate and how do I resolve on my Canon MX700 all in one machine.
6A60 error is an APP (Application Printer) position error. It means that an error has occurred when the motor was running during the purging operation on start up.Check the sheet feeder and purge unit.Sometimes pieces of paper stuck in purge unit.
Thank you!
Nov 02, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Service Error 6A80
That error says there is something jammed in either the purge assembly or the sheet feeder on the back not able to turn. The purge assembly is on the right where the printhead parks for cleaning.
Oct 29, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Paper jamed
Hi
Thanks for using FixYa. Perform the steps below in order to solve this incidence:
  1. Disconnect the power cord or power supply adaptor from the rear of the HP All-in-One product.
  2. Remove the paper pack remaining in the input tray.
WARNING - Do not try to remove the jammed paper sheet yet. Trying to clear a paper jam from the front of the device can damage the print mechanism. Always clear paper jams through the rear access door.
  1. Open the rear access door or the two-sided printing accessory.
  2. Gently pull the jammed paper sheet out of the rollers.
  3. If the paper tore when it was being removed from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If not all the pieces of paper are removed from the device, paper jams are likely to occur again later.
  4. Replace the rear access door or the two-sided printing accessory.
  5. Restart the printer to continue the current job.
Please seee this link for more details--
HP Photosmart C5280 Paper jam error
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | HP Photosmart C5280 InkJet Printer
Canon iP4700 InkJet Photo Printer Logo
42 people viewed this question
old marine
old marine
