Question about Panasonic Televison & Video
I have a red x on my Panasonic tv display, I get nothing else. What's the problem?
I can't get a signal because this tv don't have cable antenna terminal the tv has rgb terminal. I don't know what to do?
RGB is for a computer screen display signal and has nothing to do with TV display of channels. You must have a Component hook up, it is a yellow cable, a red and a white one. Yellow is video signal, the red and white are sound.
Sep 12, 2016 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Red x on my panasonic plasma and nothing else
This is a display problem and the TV needs attention by a qualified service technician.
Jul 14, 2012 | Televison & Video
Panasonic PT-56HX41 - I have a red light (power) that blinks 3 times and then nothing. The TV went super bright and then the display and audio went out. I plug it in and I click on the power, I then hear a...
The three blinks is indicating that the convergence circuit has failed and shut the set down. You can get the convergence repair kit for your model from www.tvrepairworld.com which has the Parts and the CD with instructions for the repair
Aug 06, 2011 | Panasonic PT-56HX41 56" Rear Projection...
Panasonic multimedia projection HDGT tv color spots displayed
PANASONIC..PT-52LCX15. STARTED TO A LIGHT COMES ON THE SCREEN. THEN TWO LIGHTS. FINALLY TV DONT COMES ON. I PUT ON THE TV, AND ON BOTTON START BLINKING AND TV DONT COME ON..I TAKE OUT THE TV LAMP..IT LOOKS GOOD NOT BURN. SHOULD I REPLACE IT??
Oct 18, 2009 | Panasonic Televison & Video
Panasonic PT-56WX33/red light blinks 3 times ovr-n-ovr
It's one of two things, a bad chipset, or bad lamp. 200-250 repair. Hope this helps
Jul 07, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Can't use VCR
There's nothing wrong with your VCR. Your remote probably set to control your TV. To fix that, simply press the VCR button on the remote, and you should be fine. The "T-U" really means "TV," but the designers at Panasonic wanted to use the standard seven-segment display to cut costs, hence "T-U" instead of "TV."
May 16, 2009 | Panasonic PV-V4022 VHS VCR
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic DMR E55 DVD Recorder
Hi James,
When in EXT link mode the recorder is looking for a signal from the TV to start recording off the TV's timers system.
There is a EXT Link button on the remote control and pressing that will take the machine back to normal mode. The button is near the bottom of the remote.
Hope this helps
Andy
Sep 09, 2008 | Panasonic DMR-ES10 DVD Recorder
Computer vga to tv
I'm guessing you've resolved this by now, but, if this is a laptop computer, it is actually a function of the computer that you are looking for and not the TV. Typically there is a key function assigned to directing the display to the laptop only, the tv only, or both simultaneously. On my current laptop it is fn+F8. On my old Dell I think it was ctrl+F8
Hope this helps, sorry so late.
Aug 06, 2008 | Panasonic PT-44LCX65 Television
Televison & Video Logo
329 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
