Question about Apple iMac G5 Desktop
Hot sync on my second treo p700. i had syc problems with the first and now I have the same problems with the second phone.I have an IMac G5 running 10.5.4 software.
  • sail477 Aug 02, 2008
    yes I still need help.no one has addressed the solution yet
    Problem Solver:
  • 37 Answers
Get a different phone because if you had trouble with the first and second, chances are if you get another one it's going to be a lemon.
Posted on Aug 18, 2008
G5 keeps powering up for a few mins then switches off?
Thank you for contacting Fixya Support, I am glad to assist.
There are a few steps you can try to troubleshoot this issue:
Try a PMU Reset:
* Turn of your iMac if it is already turned off
* Disconnect all connections to the iMac except the power cord
* Now disconnect the power cord for approximately 20 seconds
* Reconnect just the power cable the keyboard, mouse and power cord, and then power your iMac G5 up.
* Check to see if the iMac boots up normally without power interruption.
* If the iMac G5 shuts off again, try these steps, another recommendation would be to remove all connections including the power cord, and lay the iMac G5 on soft cloth face down and with a philips screwdriver, remove the plate on the bottom of the iMac G5 where your RAM memory is located.
Before removing the RAM however, touch your hand on the metal boot to discharge any static current you carry for approximately 5 seconds.
Now remove each RAM card and then reseat (re-install) each card.
Restore the RAM card cover with your Philips screwdriver, reconnect your power cable, keyboard an
d mouse and turn on your iMac G5.
See if this second procedure helps if the first procedure does not work.
Let me know if this helps.
Regards
-Mactechtrainer
Sep 11, 2010 | Apple iMac G5 Desktop
Isight intermittent. G5 Imac 17" The Isight cam I have now dubbed 10sec cam turns off and has to be restarted.
I understand from your problem statement that the internal iSight camera in your G5 iMac turns itself off around 10 seconds after you turn it on.
Create a new temporary user in System Preferences / Accounts. Log out and then log in as this user. Enable the camera. Does it still turn off in 10 seconds? If not, something running in your other user account (a startup program or system preference) is interfering with the operation of your camera.
If you have a spare external drive, install a fresh version of the Mac OS on that drive, then boot from that drive. Does the camera still turn off in 10 seconds? If not, you should run an OS installation with "archive and install" on your internal drive. If it does, you have a hardware problem that requires a Mac tech. If this is indeed a G5 iMac, the repair will likely not be cost-effective.
Aug 26, 2009 | Apple Computers & Internet
How do i syc my iphone with my pc
If your iPhone is detected by iTunes, it will show up on the left side of the screen. Click on it and after a few seconds, your phone should show on the main iTunes screen. On the bottom right of the screen there is a Sync button.
Jan 10, 2009 | Apple iPhone 3G
My palm 755 wont hot sync
Restart your Palm Treo 744p. Take out the battery from the phone for more than 3 min and put it back in. Switch on the phone and then try to Hot sync Again. Hopefully it will work. I am assuming that you installed the Palm Desktop software came with the phone on your computer
I have same problem once in a while when i try to hotsync with new comp and this trick always worked for me.
Nov 17, 2008 | Palm Treo 755p Smartphone
Cable hot sync is always not going through
I had the same problem on the connection and it turned out just to be so simple as some dust/dirt in the connection surface for the sync cable. I fixed it by cleaning the connection surface with isopropanol. That helped.
Nov 11, 2008 | Palm Treo 650 Handheld
My palm treo 600 has a serious issue.
Ok this problem is very common in 600`s i have good and bad news
first go to the phone application and phone info
see what hardware u have A B C
A&B are toast and nothing can correct the problem
if your in hardware C your in good luck
bad news my first treo had this same exact problem and i had to replace it:( BUT BUT BUT!! it was caused by a 3rd party program that messed would auto reset my treo everytime it came on unfourntely uninstalling it didnt work and the wireless mode never came on..
got my second treo and had the same problem but i did not hot sync and intsted beamed using infared all my data and the problem never occured but sometimes
Aug 10, 2008 | Palm Treo 600 Handheld
Hot sync treo 650 Zip-Linq cable
i have the same F***** probelm
Mar 27, 2008 | Palm Treo 650 Handheld
Hot sync problem
look at the hotsync custom options and make sure that on BACKUP the handheld overwrites pc.
Nov 01, 2007 | Palm Treo 650 Handheld
Restarts when i open a text mesasge
Have you every hot sync you phone with a ome computer or laptop? Take the Battery out of the back and use your stylus to do a soft-reset. This you refresh you treo
Jul 21, 2007 | Palm Treo 600 Handheld
Apple iMac G5 Desktop Logo
27 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
