Question about Aube Technologies Aube 7-Day 40-500w Light Switch Timer
It just blinks on/off no matter how i program it and manual mode does not allow me to turn on. everything was fine until i switched to daylight savings time
You posted under Aube timers.
Resourceful do-it-yourselfer would include brand and model number for ease of identification and best possible free answer.
Open following link to identify timer and access on-line manual
http://waterheatertimer.org/Aube-timers.html
Most digital programmable timers say 'reset' if timer stops functioning as expected.
Aube reset button can be pushed using paper clip. Usually hold-in button for 3-4 seconds.
Other timer brands and models use different method for reset, including holding down on-off button while reset is pushed.
If timer will not re-program or function correctly after reset, then timer is probably defective.
Aube timers have internal rechargeable battery that is not replaceable.
Most in-wall and plug-in timers have 1 year limited warranty. If Aube timer was exposed to cold temperatures, then warranty is probably voided since cold temperatures adversely affect battery life.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 18, 2011
Setting the clock on a brinks timer 44-1011
I finally found the instructions for the Brinks timer 44-1011 and they work.
    • BRINKS DIGITAL TIMER 44-1011 INSTRUCTIONS
    • CURRENT TIME SETTING
    • 1*Press and hold the OK button for 4 seconds. Hour Display flashes.
    • 2*Press +/MANUAL or - to select the hour. Press OK to confirm.
    • 3*Minute display will now flash. Press +/MANUAL or - to select the minute. Press OK to confirm.
    • 4*Press MENU to exit the time setting mode. Now the timer is in clock mode.
    • PROGRAM SETTING NOTE: This timer can be set up for up to 2 different programs. We will use PROG 1 for this example, however these steps can be repeated for any of the 2 programs. To cycle through the individual programs use the +/MANUAL or - after pressing MENU in step one until the desired PROG "#" is flashing. To clear a program setting hit the RECALL button when you have the program selected.
    • 1*Press MENU button, PROG 1 "ON" will flash, press OK.
    • 2*Hour will flash. Cycle with +/MANUAL or - to desired hour, press OK.
    • 3*Minutes will flash. Cycle through minutes +/MANUAL or - to desired minute, press OK.
    • 4*Program will be flashing again. Press +/MANUAL to get to PROG 1 "OFF" blinking, press OK.
    • 5*Repeat steps 2-4 to complete PROG 1 setting.
    • 6*When done setting programs press the MENU button to return to clock mode.
    • 7*Press +/MANUAL to have LCD showing either "AUTO ON" or "AUTO OFF" for the timer to execute the programmed settings.
    • DAYLIGHT SAVING TIME SETTING (DLST)
    • 1*In clock mode, press RECALL to turn on or off the Daylight Saving Time.
    • 2*Turn on DLST, the below of LCD shows +1H. Time is adjusted by adding one hour.
    • 3*Turn off DLST, +1H will disappear and LCD shows the real time. MANUAL OVERRIDE AND ALWAYS ON/OFF When in clock mode the +/MANUAL sign cycles through
    • 4 settings that serve as manual override. **ON - Indicates that the timer is in the ON mode, and will always be on regardless of the programmed setting. **AUTO ON - At this selection, the timer will come on regardless of the programmed setting, but it will follow the next programmed command. **OFF - Indicates that the timer is always off (i.e. the wall socket is turned off) **AUTO OFF - Indicates that the timer is in the OFF mode until the next programmed step that turns it ON.
    • NOTE: For normal timer function, the selection must be either "AUTO ON" or "AUTO OFF". RESET At any mode, press RESET for 5 seconds. All settings will be cleared, return to clock mode, 12:00 MO, AM, AUTO OFF will be shown on LCD
I hope this is helpful. It was a bear to find.
Dec 24, 2012 | Hardware & Accessories
My directv remote will no longer work t v re programmed it for another tv and works fine the orgial remote will not work either funny thing this happened today after replacing old batteries
10 Steps to Program Your Directv Remote
1. Turn on television.
2. Locate the switch at the top of your remote that allows you to toggle between receiver, auxilary, and TV modes. Slide switch over to"TV".
3. Hold down MUTE and SELECT until a small green light at the top of the switch blinks twice.
4. Enter code 9911.
5. Press and release the CHANNEL UP button repeatedly until television turns off.
6. When TV turns off, press SELECT.
7. Next, press the power button. This should turn the TV back on.
8. With television on, press and hold down MUTE and SELECT again until the small light blinks twice (same as in step 3).
9. Entercode 960.
10. Slide switch back over to "DTV". Your remote is now ready to use!
Nov 01, 2010 | Westinghouse SK-32H240S Television
How do I reset my Intermatic wall switch timer?
If CR2 battery went dead or if battery removed more than 1 minute, then time-date disappeared, but programming stays in timer indefinitely even if power is off.
To reset time-date. (From Section 5 in manual)
Press MODE until screen displays SET UP
> Press ON-OFF until HOUR shows ... use + key to change hour
> Press ON-OFF until MINute shows ... use + key to change minute
> Repeat same sequence for Year, Month, Day
> Press ON-OFF until DST daylight savings time ... use + key ... choose AUTO if area has DST ... choose MANual if areas does not have DST
> Press MODE to exit and save settings
Other programming steps are long.
Manual shows programming steps:
http://waterheatertimer.org/Intermatic-st01c.pdf
Walk through programming steps:
http://waterheatertimer.org/ST01C-program.html
Sep 18, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I lost the manual and i dont know how to program it please help its an older direct tv remote?
4. Enter code 9911.
9. Entercode 960.
Jul 01, 2010 | Philips DIRECTV R15
Audiovox Pursuit Pro keyfob reprogram
if thats the picture of the transmitter to program it you have to : turn the ignition to on position. press and release the programming switch 3 times... press and hold,for 3 seconds, the buttonof the transu wish to add until the parking lights flash. this would mean the transmitter has been learned. repeat step 3 for each transmitter... turn the ignition off to exit the program mode..
do not let 15 seconds pass between steps.
Feb 11, 2010 | Car APS921 Remote Starter - Keyless Entry
I have a utilitech 0192773 self adjusting timer that will not program. Only works with manual on / off switch. How do you adjust to dusk to dawn
Do not go to Utilitech.com; it's a different company. It's actually at place called TheNCC and is in tiny, tiny print at the bottom of the instructions.
Instead, go to:
http://thencc.com/ncc/support_results.asp?criteria=192773&Submit=Go&SearchRun=RunGo
You should find a PDF for the product and then zoom in to be able to read the instructions. I was not able to read instructions that came in packaging.
Jan 27, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I HAVE LOST THE MANAUAL FOR MY PHILIPS MAGNAVOX UNIVERSAL REMOTE
You don't need the whole manual for the Philips Magnavox remote fortunately.
If you want to reprogram it for the Apex TV, follow my directions exactly.
  1. Hold down the Code Search button (on the remote) until the light on it turns red and stays red.
  2. Let go of the Code Search button.
  3. Make sure to switch modes at this point to which device you want to program, I'm going to assume TV Mode since your post says "Apex TV." If you need help with Apex DVD codes, I can answer that one too :)
  4. As you Press the mode button and release it, the light should blink for a bit, so keep your eye on it because after it's done blinking it'll stay red.
  5. At this point the remote want's you to press a sequence of numbers also known as Code[s] or Code Entries. Either way these are what are in a table inside the manual that you lost.
  6. I'm going to give you two codes in case one doesn't work: 044 and 335 (one of those hopefully will work)
  7. If the code worked you'll know right away because the light will get mad and start blinking again, otherwise if it DID work, it'll just turn off (the light will anyway).
  8. That's it, I reccomend you test out your remote with the TV now and make it everything works. If something doesn't, try the other code. If it still doesn't work right, I'll give you some more codes.
Hope that helped,
-Cheers-
Direct Philips Magnavox Universal Remote Code Entry PM335
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
The red indicator blinks, then stays lit.
3. Enter the 3 digit code from the code tables. Note:
after a valid code entry, the red indicator turns off.
For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the
device responds, no further programming is
required. Note: If some buttons do not operate your
equipment, try one of the other codes for your
brand.
APEX 044
Mar 21, 2009 | Philips Televison & Video
Cannot change from 24 hour to 12 hour also did not change to daylight savings time
To change from 24 hour to 12 hour, you hold down the "Mode" button until it switches from 24 hour to 12 hour or vice versa. To change the time zone, you hold down the "Set" button until the time zone that you set it in flashes (like "LAX" on my watch). Then you press the "Receive/Start/Stop" button to choose the specified time zone you want. To set for daylight savings time ("DST" on the watch), after holding the "Set" button and having the time zone flash, you could press the "Mode" button. It will give you a few options for the daylight savings time (Auto, On, or Off). I chose the "On" option, which immediately changed for daylight savings time. If you manually want to change the time, you could hold down the "Set" button and keep pressing the "Mode" button until the time starts flashing on your watch, then pressing the "Receive/Start/Stop" button until you change it to the time that you want. You could also set the watch to beep or chime after pressing the set button if you wanted to know that piece. You hold down the "Set" button when you are done to get it to stop flashing. These instructions worked for my Timex T5G341 Universal Radio Control Watch. I hope this helps.
Mar 08, 2009 | Timex T5G341 Sports Radio Control Watch
Atomic clock
There is a setting on the clock to turn on "DST"- daylight savings time feature. You have to push the set button on the back of the clock repeatedly until you see "DST" blinking. You should also see "OFF" blinking at that point indicating that the feature if turned off. If you now push "+" button on the back of the clock once it should show "ON" blinking instead of "OFF". Hope this helps.
FixerUpper
Nov 04, 2007 | SkyScan 86709 Atomic Wall Clock
Aube Technologies Aube 7-Day 40-500w Light Switch Timer  Logo
152 people viewed this question
Top Aube Technologies Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you an Aube Technologies Hardware and Accessory Expert? Answer questions, earn points and help others
