Question about Bosch MUM6630 Universal Series Stand Mixer
Bosch universal mixer 800W. How do I change a 110 volt to a 220 volt? Is it possible?
  • 1,536 Answers
Bosch is not very good about putting manuals or other documentation online for older products, so I'll have to give you generic advice.
Some electric motors have optional voltage connections. If your motor has this feature, there will be a box or removable plate on the motor with 110 Volt and 220 Volt connections inside. You would need to replace the line cord with a 220 Volt cord having the correct plug for the location you plan to use the mixer, and connect the motor "hot" wire to the 220 V connection in the motor junction box instead of the 110 V connection (the neutral wire goes to the same neutral).
If there is no such option available on the motor, you would also have to replace the motor with a 220 Volt version. Check the labeling on the speed control (inside the mixer) to be sure it is rated for 240 VAC, and check the power label by the power cord. If the label gives a single range of input voltages spanning both 110 VAC and 220 VAC (e.g., "Input 97 V- 265 V") then you only need to change the plug. Unless the electrical parts are all rated for 240 VAC or higher, conversion is not safe.
Some products (especially desktop computers) have a recessed switch on the back that lets you select either 115 VAC or 230 VAC input power. If you have this on the mixer, all you have to do is use a small tool to push it to the other position.
An alternative is to get a 230 VAC - 115 VAC transformer or inverter rated for at least 800 Volt-Amps and wire it with a 230 Volt plug on the primary side and a 115 Volt socket on the secondary side; then you can just plug in your unmodified mixer to this. If you cannot find a box like this, you can buy a "control transformer" from an industrial equipment supplier and put it in a suitable metal box. I recommend including a power switch and a 4 Amp dual-element fuse or breaker on the primary side circuit; you don't want somebody burning up the transformer with a 1200 Watt microwave oven or griddle.
Posted on Mar 17, 2011
Never used new bosch universal plus making bread started rattling sound
I do not know a lot about this machine. I am a DIY fix anything. It sounds like one of the mounting points on either the motor or the gearing gave way. Regardless it is new, send it back & have it fixed or replaced. Sorry, I know that is not what you wanted to hear, but is safest considering your investment.
Mar 10, 2014 | Bosch Universal Plus 6 Qt Mixer With 800W...
I plugged my 110v KG25H3XWH mixer into a 220v outlet via a voltage transformer and turned it on. It immediately sparked, popped, emitting a burnt smell and tripped the circuit breaker. Is it possible for...
First here is the link to a good suuplier with OEM parts for 110 and 220 volt http://www.appliancezone.com/SearchProducts.aspx?ID=9707627&x=12&y=7
you can change any KA mixer from 110 to 220 and 220 to 110, you need the armature stato phase control board and speed swith for eith conversion, the 220 madel number or 220 model has a letter in front of the ka which is the indicator for 220 volt go to http://www.kitchenaid.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10552&langId=-1&storeId=10202 for a exploded parts list and part numbers look any where for a KA 220 volt model and you can find the same thing
Oct 04, 2013 | KitchenAid Food Mixers
I need a replacement motor on a KitchenAid Professional HD Stand Mixer (Model KG25H7XSL).
The loud pop was probably the soft start circuit board on the motor. You can buy this board at repair sites or Ebay. And yes, they make 220V versions of this mixer.
http://www.samstores.com/product-kitchenaid-5ksm5ebu-heavy-duty-mixer-for-220-volts-%28cobalt-blue%29-16220.html
Dec 31, 2012 | KitchenAid Food Mixers
I stay in msia and recently i bought a PRO450 kitchen aid mixer from us. Msia's voltage is 250V while the mixer is 300 watt. I used adapter and the mixer does work but the engine is making noises. Is...
The voltage in US is 110-120 volts and the amperage is 60 amps. In your country the voltage is 250 volts which appears to be high as the general voltage in Asian countries 220 volts and the current is 50 amps You have to use a transformer/adopter which can reduce the voltage from 250 to 220 Or it is a universal adopter where this aspect is covered up. In that case you have to check the amperage. 300 watt is the power consumed and has nothing to do with low/high voltage.
Oct 07, 2011 | Food Mixers
Hi .. am in a country that has 220V power outlets. What do I need to use my kitchen ais that has 120V, 60hz and a maximum of 330 Watts requirements?
You need a Step Down Voltage Converter (also called a Voltage Transformer)
which steps down 240, 230, 220 volts to 110 volts and
allows you to use 110 volts Devices from USA in 220 v / 230 v / 240 v Countries
Aug 04, 2011 | KitchenAid Artisan KSM150PSSM Stand Mixer
I need to convert power fro 220 to 110 volts
Mixer provides the facility to convert the power to another one.
In the mixer you will provided the key to convert 220 volt to 110 volt.
Drag that key to 110V.
Dec 23, 2010 | Kenwood KM800 Major Classic Stand Mixer
Universal Plus 800W, blender section got liquid in it, is it easy to pop the cover off and regrease the drive? It looks like the whole cover is one piece
I don't know about easy, but it should be serviceable. Use only food grade grease available at appliance parts supply.
Oct 31, 2009 | Bosch MUM6612 Universal Series Mixer
95 year old hobart mixer: two pole single throw switch
Im a tech for hobart and have seen old mixers but not that old.Hobart wont have parts but you could goto an electrical supply place,take the switch and ask them for something universal.
Dec 16, 2008 | Hobart HL600 Legacy Stand Mixer
Kitchen aid mixer, voltage issue
i want to buy a kitchen aid
and i was wondering about the voltage since i'm in Qatar
and i found this answer , Hope its useful
http://www.110220volts.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=750-WATT&Category_Code=DownVoltageTransformer
Nov 10, 2008 | KitchenAid KITCHEN AID 5 Quart Artisan...
Bosch MUM6630 Universal Series Stand Mixer Logo
597 people viewed this question
Top Bosch Food Mixers Experts
Paul Bade
Are you a Bosch Food Mixer Expert? Answer questions, earn points and help others
