My Superwritemaster speedplus dvd writter not working properly, when i insert dvd/cd into the drive & click on the dvd icon it was opening and but shows empty
  • Computers & ... Master
  • 27,725 Answers
Make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Mar 17, 2011
Create boot disk
Insert a blank diskette into the floppy drive. Click start click on computer you should see all of you drives.
Right-click on Drive A. You will see the option to format the drive.
Click on Format. Depending on your operating system, you will see an option that reads either "Create a system disk" or "Create a MS Dos system disk." Click the box next to this option.
Click the "Start" button to begin formatting the disk.
When completed, you will have a bootable floppy disk.
For CD Rom or DVD disks
Open the software that you use to burn or write files to the CD-rom or DVD drive.
Click on "Make a Data CD or DVD." Insert a blank CD-R or DVD-R disk into the drive.
Look for the option to "Make this disk bootable." You may have to scroll over the various icons displayed to find this option. Click on the option.
Burn the CD or DVD as usual. Once completed, this disk can be used to boot your computer.
hope this helps
Aug 22, 2012 | Seagate Computers & Internet
My dvd drive i.e. samsung speedplus is not at all functioning. when i am inserting a disc it is not reading the disc properly. so how to solve it.
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 28, 2011 | Samsung TruDirect SpeedPlus DVD-RAM...
I have lg dvd writer, model no. GSA-H55N .IT was running properly but today morning suddenly stopped.my project disc is inside the writer and it is not opening at all.also their is no dvd logo on my...
u observe ur dvd writter cleanily k there will be a small hole in it insert pin in it the dvd writter opens k :)
Hope this helps & please remember to rate my answer. Thanks
Feb 18, 2011 | LG Computers & Internet
I am not able to play my movies recorded dvd but cd is working well, help me,,
Insert a DVD movie.
Open "My Computer".
Right-mouse click on the icon for your CD/DVD drive, and click "Explore".
If the hardware is working correctly, you should see a list of files & folders.
Search online for the free 'VLC' software for playing DVD-movies. Download it, and install it, to "play" your DVD-movie.
Sep 30, 2010 | LG 16x Internal Blu-ray Disc/ HD DVD...
Neither reading nor writing any data , though green light is blinking when i start computer or when i insert any disk , cursor also showing disc icon for a time and when i eject caste tray from my pc it...
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Sep 30, 2010 | Samsung Speedplus SH-S223 22x DVD?±RW DL...
Problem of dvd/cd writter
check the IDE/SATA cable,if its connected,now u must to become sure from lens.maybe it need to cleaning.therfure,if after cleaning this problem still apear,so u must change the board or somethings in it by testing
Jul 07, 2010 | LG GSA-H42N 18x DVD RW DL IDE Drive...
DVD duplicator
I contacted EZ Dupe directly. They were very helpfull & recommended the proper drives.
Sep 15, 2009 | EZ Dupe EZDupe CoolCopyD5 DVD 1 to 5...
Cd/dvd driver can't read Cd and some DVD
Im having the same problem with my acer. although i can play all cds, just not some dvds. Ive already had a suggestion, heres the link.
Apr 10, 2009 | Computers & Internet
CD drive is not working
CD is damaged or the drive is damaged. Doe sit do this with any CD? If so the drive is broken - they cannot be fixed.
Jan 25, 2009 | Lenovo 3000 N200 Notebook - Intel Celeron...
Computers & Internet Logo
David Payne
David Payne
