My Hoover wasing machine 800RL is making a very loud winding noise on the spin cycle. could you please advise me what it is
  • Washing Mach... Master
  • 4,924 Answers
Hello ,
from what you described there could be a few things going on ..:
1..one of the rubber rings that balance the drum is either loose or broken ..
2 the bearing from the drive shift is defective ..
3 the counterweight is loose from the screws ..
4 the position on the horizontal plan is not perfectly
5 one of the screws ...is loose somewhere and is vibrating only on high speed spinning ..
But usually is either the suspension rubbers or the counterweight being loose
Posted on Mar 17, 2011
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Hoover 800rl wont spin
sounds like an issue with the progrmmer if it does everything else, or there may be an issue which a sensor has caught that causes it to desist from spinning. Probably needs a repairman to diagnose..
Jun 03, 2015 | Hoover Washing Machines
Into the spin dry cycle a loud hammering noise appears. Immediately goes away when powered off and drum speed drops. Can you please advise. Regards Geoff
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Oct 05, 2010 | Hoover H130E Front Load Washer
WHEN EVER THE MACHINE IS RUNNING, ESPECIALLY DURING THE SPIN CYLE, THE WASING MACHINE MAKE A VERY LOUD NOISE AS IT ROTATES. IT ALL MOST SOUNDS LIKE IT RUBING AGAINST SOMETHING. ANY...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
heatman101
Sep 18, 2010 | Washing Machines
Whirlpool washing machine make loud noise after spin cycle quits. Noise continues until cycle winds down. Sounds like a machine gun being fired
Hello,have to tell you that most noises from a washing machine occur during the spin cycle. If you hear loud thumping noise during the spin, the load of cloth may have become unbalanced. Stop the washer and redistribute the cloths, then restart the machine. Repeat these steps if necessary.
Thanks
Jun 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
HOOVER 510 PREMIER WASHING MACHINE ABOVE THE BELT SHAFT THERE IS A PLASTIC COG WHEN THE WASHING MACHINE IS ON WASH CYCLE IT SPINS FINE ONE WAY THEN ON THE REVERSE SPIN THER IS THIS ORANGE LEVER THAT MAKES...
I imagine you've bought a new machine by now? The plastic gearcog is the clutch housing. The arm that clicks is part of the brake lever. On these models, the brake lever is supposed to hold the clutch in place during the wash cycle so that it slips in both directions to get a forward and reverse wash. On spin, the lever moves away releasing the clutch and gearbox brake and allowing the bowl and agitator to spin together. The brake lever wears and allows the gearbox to slip during the wash cycle. When this happens, the clutch housing will "ratchet" past the brake lever tongue. this causes the "clicking" noise in 1 direction.
Oct 17, 2008 | Hoover Washing Machines
Amanna wasing machine 3.2 cu. ft. top loader
i would try removing the lower acess panel(2 5/16 screws . from there you should be able to see where the "ticjing" noise is coming from, likely source is cracks in belt assy
Oct 07, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Washer makes loud thumping after finished spin cycle
I replaced the drive block and it solved my problem. (thumping noise at the end of spin cycle) Easy repair. Videos on utube show all the steps.
Jun 07, 2006 | Whirlpool LSR7333 Top Load Washer
Washing Machines Logo
169 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
