Question about Whirlpool 24 in. DU1050SS Built-in Dishwasher
Quiet Wash Plus 940 Series, approx. 12 years old................Machine keeps stopping on "Normal" wash and "Air Dry" light flashes............."Lock Out" light flashes when attempting any other button selection............Opening and closing door re-starts "Normal", but stops after a few seconds
SOURCE: My Whirlpool quiet wash plus 940 series is stuck on "lock out"
Have the same problem with my Sears ( made by Whirlpool ) 1603. Visited the store and the man said it must have had a power surge. Even the slightest will FRY the electrical in the Power Pad unit. Cost to repair, maybe $ 120 for new unit , installation costs, plus $65 for the man to get in the truck. Is it worth it ? They had the same, but newer Dwasher on sale for $390 , free delivery , pay for installation, take out old $20. What to do....
Posted on Feb 14, 2009
Same problem and I was about to call for service. Opened the dishwasher to get the model number and noticed a sticker stating to hold down the Heated Dry button for 5 seconds to clear the lock light. Worked for me!
Posted on Aug 23, 2009
thunderalley
  • 432 Answers
SOURCE: Whirlpool - only Heavy wash cycle works
bad timer
Posted on Sep 13, 2009
StarGGundam2
  • 24 Answers
SOURCE: Maytag Quiet Series dishwasher won't start
Sounds like you have a bad Control Board
http://www.partstore.com/Part/Maytag/Maytag/MDB6600AWW/Maytag/Maytag/99003160/New.aspx
But with the price it cost, you might be better off buying a new dishwasher, preferably a different brand, cause that washer has some bad reviews
Posted on Oct 12, 2009
Daniel S
  • 4323 Answers
SOURCE: Whirlpool gold quiet wash plus
Hi
It may be an issue with control board please reset the power to the dishwasher. After, 5 minutes plug it back and press & hold AIR DRY button for 20 seconds to check if you are still getting the same error. If yes, then it is the control board that is bad and should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Posted on Jul 24, 2011
I have a Whirlpool Gold Quiet Series Plus, Model GU940SCGT3, not working. It ran a cycle, cleaned the dishes, but the water didn't drain and the "CLEAN" light is stuck on. It is now...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 31, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a Kenmore Ultra Wash Quiet Guard washing machine Model No. 6651601. I am trying to find out how to reset my dishwaser as it keeps flashing the "clean" light but will not run.
No there is no reset button you could disconnect the power by turning off circuit break for at least 5 minutes turn it back on and see if that clears it
Gene
Aug 01, 2011 | Dishwashers
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Daniel
May 19, 2011 | Maytag Dishwasher
Talking about a kenmore 665.16389300 dishwasher. the "normal wash" button is blinking, but none of the other buttons seem to work and the cleaning cycle will not start when i press the...
Hi
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad. Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Kenmore Dishwashers
Clean light is blinking. Services manual says:
No all you do is press
Normal-Wash, Heat Dry, Normal-Wash, Heat Dry,Normal Wash, Heat Dry, Normal Wash, Heat Dry
Then all the bottons light up
Don't press anything wait a few minutes and it will work again
I know because today we just had this problem and did this from looking it up online,
Nov 22, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Blinking lights, unresponsive
I went to the Maytag site looking for a manual. None existed for my model, but I looked up won't start under the FAQs. The advice said to push the cancel button twice. My model doesn't have one, so I just started at the left side of the control panel and pushed each button twice. pushing the dry button twice made the lights stop blinking. i pushed the wash button and the unit started.
May 08, 2009 | Dishwashers
Feb 14, 2009 | Whirlpool 24 in. DU1050SS Built-in...
Whirlpool Quiet Partner Doesn't finish cycle
FIX YA IS A JOKE I WOULD LIKE TO BURY THE ************** WHO CREATED IT!
Jul 30, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore Dishwasher displays the number "98"
I have a very similar problem. When I push a wash selection, every light on the panel shows up...and when I push Start, nothing happens. When I push cancel, it trys to drain, even tho no water is in there any more. Have you ever had an answer to your problem?
Feb 06, 2008 | Kenmore 16872 Built-in Dishwasher
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Whirlpool 24 in. DU1050SS Built-in Dishwasher Logo
178 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
