Question about LG Flatron L1951S 19" LCD Flat Panel Monitor
Hi my LG w1934s LCD monitor suddenly not working it screen is full with color lines even I disconnect the VGA cable from the system unit the screen is not change the color lines are as it is what can I do for this problem
  • 55 Answers
That have not simple solution better take it to a tv repair shop, you already disconnect the data cable and discard the possibility of computer problem.
The Monitor must have in the menu a reset configuration option but I doubt it will help, its time to get it to a repair shop.
Posted on Mar 17, 2011
Monitor displays no green
I would have said bad VGA cable, but since you said you already tried a new one, have you tried replacing the VGA adapter?
Aug 29, 2017 | Dell Model 2208WFP - 22 Inch Widescreen...
I have a lg flatron LCD w1934s-bn when I switch on the computer display coming and with in seconds monitor going in power saving mode. I change the VGA cable, change the system also same problem.
If your monitor goes into Power Saving Mode with different computers, it is most likely the signal input board in the monitor. I'm sorry to tell you your monitor is shot. It is probably repairable if you can find the correct board. Monitors are relatively inexpensive at the moment, and going by the "VGA only" input, it is time to upgrade, You will also get better resolution and picture quality.
Apr 20, 2012 | Computers & Internet
What is the problem if my LG w1934s-BN LCD monitor when the color of the screen is pink ?
The reason for that is because the main board inside of the monitor is bad and since there are no parts for that monitor available you would need to replace the monitor. The main board controls the output of colors onto the lcd.
Sep 30, 2010 | LG W1934S-BN 19" Monitor
Screen is very Blue all of a sudden. I have tried working with the controls on the back and nothing seems to change the screen color. It is as if a layer of blue is over the entire monitor!
You can have problem in the Logic\LCD driver board, I would try new VGA cable first or try unplug/plug the VGA cable, but try it on another PC also just to be sure.
Apr 15, 2010 | Hyundai ImageQuest B90A (Black, Silver)...
LG FLATRON W1934S
hi,
check first if the connector has no connector pins wha are broken or shifted. if not chack cable for hard nobs or turns maybe cable is interrupted.
take other schreen to check VGA output of PC.
if all this not helps mail me back
greetings cis
Feb 16, 2010 | LG Flatron L1951S 19" LCD Flat Panel...
The power button on my LG W1934S monitor just flashes continuously and does not show an image. I have tried several cables.
try this....
remove the vga cable at the back of your monitor or at the other one in your cpu..
get it?? the one that connect the cpu and the monitor..
then try to turn on your monitor if there is a message says like this " no signal output" or no video output"..
it means your monitor is ok and you have a problem in your cpu...
sometimes that is the problem....
Feb 13, 2010 | LG W1934S-BN 19" Monitor
My monitor cuts out after about four seconds
ludwighro805, If Lucky Goldstar warranty not valid option, or LG cash+ old unit refurbished swapout then you will need to repair unit or contract out the work to technician that fully understands failure mode of unit W1934S. Get into my FIXYA profile and READ, READ, READ. Your unit good candidate for repair. Your unit CLASSED as "BLACK" or "BLACK and BLANK" screen failure due to possible POOR factory reflow soldering process. If you do the research you may even want to try a DIY fix. If this info helpful, please rate this response on FIXYA. Good luck with repair. Explore your options before doing anything. Do an additional comment if you still require assistance. 12fixlouie on fixya
Jan 05, 2010 | LG W1934S-SN 19-inch Widescreen LCD...
LINES ON SCREEN.
Hi
there are very few troubleshooting you can do with the monitor
1.) Powerflee: unplug both the cables of the monitor from the computer and power socket. then press and hold the on button for 15 seconds this will release all the static current..
if this does not work then doa Monitor on self test.. just conect the power cable of the monitor and make sure the VGA (Blue plug) is Not pluged in with the computer. switch on the monitor and you will get a message either a question mak or No Vga cable see the color if itn ios not coming right then the monitor has gone bad
thanks
AJ
Jun 04, 2008 | HP vs15 15"LCD Flat Panel Monitor
LG Flatron L1951S 19" LCD Flat Panel Monitor Logo
107 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
