Question about HP P2035N LaserJet Monochrome Printer
Using HP laserjet P2035N model. It is connected to the network with IP. When giving printing private software named "GP" we need to press the botton at the top of the printer. Then only the print is coming. The software's paper settings is A4. But in printer properties in the general tab the "paper available" is showing letter. I can't change it to A4. Pls sent the solution
mickspaceNET
  • 115 Answers
SOURCE: my hp laserjet 4 plus printer cannot print excel files
wherer are you printing this, A4 is european, north america would use letter, etc..
if you go to control panel, open the printers and faxes folder, right click the printer in question, a window will pop up, click on properties.. a new window should open. click on "Printing Defaults" or "Printing Preferences" then click on "Advanced" ( I believe it should be to the lower left) that will open another window, in paper size make it Letter if your in N America, A4 for Euro.. this will set the deafult print..
Click ok, then print a test page from the general tab..
The reason you getting this LOAD LETTER message. your excel page setup is set to print to letter, your machine is set to print top A4
If you open Excel then go to Print then a window should pop up where you select the printer you want to use, click on Properties, then Lay out, then Advanced, and input the correct paper size before you print.
does this happen with all excels files, or one particular?
Create a new Excel file, and try printing it.. possibly could be in that particular file. I have seen this happen alott particulary with PDF files.. Where the incorrect paper size is in the file..
Posted on Oct 23, 2008
  • 85 Answers
SOURCE: HP Laserjet 3050, need to press ok each time printing
did it work before? check paper size for trays - suspect it is set for a4, change to letter size
Posted on Mar 13, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: I would like a copy of HP printer manual for HP
The manual and other documents for this printer can be downloaded from HP here. Hope this helps. Thanks for using Fixya!
Posted on Feb 02, 2010
SOURCE: My laserjet p2035n will not stop printing. I am
I had the same problem running WINXP 32bit and WIN7 64bit Pcs with P2035n installed on home network. I uninstalled the printer and reinstalled with WIN7 64bit drivers. See Hp link below:
HP LaserJet P2035 and P2035n GDI Plug and Play Package
Posted on Mar 27, 2010
Open Devices & Printers --->
Highlight the P2035n, right click, and select 'Printer Properties' -->
On the Ports tab, uncheck the box 'Enable Bidirectional Support'
Posted on Nov 01, 2010
Hp color laserjet 2550l need driver for my mac
Sir/Madam
The latest HP printer driver for devices listed below are built into Mac OS X 10.6. You do not need to download or reinstall any HP software for full printing functionality.
HP LaserJet print drivers are included in Apple's Mac OS X 10.6 Snow Leopard DVD and also available via Apple Software Updates.
Please Visit official HP Printer website Below Link URL:
http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?spf_p.tpst=kbDocDisplay&spf_p.prp_kbDocDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c01844302-4%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken#N1000E
Snow Leopard - HP LaserJet printer setup instructions
  1. Upgrade install from Mac OS X v10.4, 10.5:
If updating a Mac using the Snow Leopard DVD, the install process should automatically detect your previous HP printer queue, delete, and then create a new HP printer queue using the latest HP printer drivers included in Snow Leopard.
USB printers:
  1. Make sure printer is turnedOnand connected.
  2. Open a document to print, and then choose File , Print .
  3. Open the Printer pop-up and choose your printer.
  4. If you don't see your printer, choose Add Printer , and then selectMore Printersbutton.
  5. In the Name column, select the printer, then clickAdd.
Network printers:
You can connect to HP printers on your local network that use Bonjour, IP, and Open Directory, as well as shared printers connected to an Apple Airport base station.
NOTE:Apple does NOT support AppleTalk in new Mac OS X 10.6.
  1. Choose File , Print .
  2. Open the Printer pop-up menu and choose your printer. It may be in the Nearby Printers submenu.
  3. If your printer does not appear, choose Add Printer from the Printer pop-up menu.
  4. A dialog appears listing any Bonjour, IP, shared, and Open Directory printers on your local network. It may take a minute or two for your printer to appear.
NOTE:On larger networks, outside the Bonjour link-local network, your printer may not show up in the list. You can connect to the printer using IP. An IP printer is a network printer that uses TCP/IP protocol (such as JetDirect, LPD/LPR, IPP) to communicate with your printer. You need to know the IP address or DNS name.
  1. Click IP in the toolbar.
  2. Select HP Jetdirect - Socket in the Protocol pull down menu.
  3. Enter the printer's information available from printers front panel or printers network configuration page.
  4. The system should automatically bind to the HP print driver in thePrint Usingpull down menu.
  5. ClickAddto create the HP printer queue for your HP LaserJet.
Your computer can usually detect whether a printer has special accessories installed, such as additional paper trays, duplex unit, or extra memory. If it can't, a dialog appears that lets you specify them. Make sure the settings in that dialog accurately reflect your printer's installed options to enable full functionality.
  1. Clean install of Snow Leopard or setting up a new Macintosh with Snow Leopard already installed:
If configuring a new Mac running Snow Leopard or if performing a new or clean install of Snow Leopard:
For USB connected printers, the install process should automatically create a new HP LaserJet printer queue using the latest HP printer drivers included in Snow Leopard.
For network connected printers, follow steps below.
USB printers:
  1. Make sure that printer is turnedOnand connected.
Network printers:
Or
In Case You Have Still Problem Then Please Foll Us On:
HP Printer Support
Feb 12, 2014 | HP LaserJet Office Equipment & Supplies
Tip
How to assign an IP address for an iPod Touch
<p>The iPod Touch is the only iPod that can connect to a computer network using the built-in Wi-Fi adapter more public and open wireless networks, a dynamic Internet Protocol (IP) for each device when accessing the network. However, private networks in a number of houses and organizations that works with static IP addresses. In this scenario, a device always uses the same unique IP address to connect to the network. You can use an IP address from your iPod Touch. <br /> <p><br /> <p>1. Tap "Settings," then "Wi-Fi." The iPod is a list of wireless networks in range. <br /> <p><br /> <p>2. Research on Wi-Fi network you want to participate, while the use of the IP addresses assigned, press the blue arrow beside the network name. <br /> <p><br /> <p>3. Tap "Static", enter the IP address you want to give your iPod. <br />
on Jul 21, 2011 | Computers & Internet
Using HP laserjet P2035N model. It is connected to the network with IP. When giving printing private software named "GP" we need to press the botton at the top of the printer. Then only the print is...
The reason you need to press the print button is because of the mismatch between the two paper sizes, this is normal. Find the manual and follow the instruction on how to change the paper size on the printer, or change the paper size in your software. Either should work. They must be the same for it to work properly.
Aug 26, 2017 | HP P2035N LaserJet Monochrome Printer
How to enter an IP address on a hp2035n
To install a HP printer (with built-in Jetdirect printserver) as a network printer you need to do the following -
1. Open the printer's menu and enablethe Network Card - these print servers use a static IP address therefore,configure the IP address of the network card so it matches the IP range of yournetwork. Eg. If your IP's are 192.168.0.*** then set the network card to a highnumber say 100. (This is to prevent a conflict with the router issuing the sameIP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0
Jul 17, 2012 | HP P2035N LaserJet Monochrome Printer
Find hp p2035n ip address
To set up a network HP printer please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559242-setting_up_hp_jetdirect_print_server_p
Jul 24, 2011 | HP P2035N LaserJet Monochrome Printer
How to assign static IP address to HP LaserJet P2035n
Plug the printer to a DHCP capable LAN. Give it a moment to connect. While the printer is on, hold down both, the feed and X buttons on top of the printer. It will print out a configuration page with the DHCP address. Type that address in a web browser. Click the network tab. Select manual address; then type the address you want. Then click save. DONE
Jan 25, 2011 | Computers & Internet
The HP 3055 network printer, connected to 3 dell inspiron laptops doesn't print...it says it's offline, even though the screen on the printer says "ready." I tried adding a printer profile and...
Check the IP of the printer, it should be manually assigned, if you are not confirmed,
  1. Press menu/enter .
  2. Use the or the > button to select Reports , and then press menu/enter .
  3. Use the or the > button to select Config report , and then pressmenu/enter .
  4. The printer exits the menu settings and prints the report.
Try re installing the printer software from the cd, or download the full version from the links below for your area
HP LaserJet 3050/3052/3055/3390/3392 Asia Pacific Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 Eastern Europe Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 North America/Western Europe Full Software Solution
(The full software solution provides print, fax and scan functionality. This software solution is the same solution as the Version 4.0 in-box CD that came with your HP LaserJet 3050/3052/3055/3390/3392.)
You can download Printer manual from the link below
Printer Manual
If you require more assistance in this regard feel free to reply to this post
Best regards-BA
Jan 20, 2011 | HP LaserJet 3055 All-In-One Printer
I replaced a hp laserjet p2015 printer with another hp laserjet p2015 printer but it can't print.what's the problem,pls help me
This HP printer is comes with the USB cable. To install the printer software, you need to install the USB driver compatible to your printer and then it will ready to print.
Dec 08, 2010 | HP LaserJet P2015 Printer
HP laserJet 3055 network connection
HOW TO CONNECT HP 3055 TO ROUTER/WIRELESS NETWORK. WINDOWS XP/WINDOWS VISTA.
I have just finished successfully connecting my HP 3055 to my router and using it over wireless on 2 computers, one with windows XP SP2 and one with VISTA.
INSTRUCTIONS FOR CONNECTING HP 3055 ON XP:
FIRST CONNECT THE PRINTER TO THE ROUTER WITH A ETHERNET CABLE. FIND OUT THE IP ADDRESS OF YOUR PRINTER. By me it was 192.168.0.66
Go to CONTROL PANEL and open "PRINTERS AND FAXES". on the top left choose "ADD A PRINTER" click "NEXT".
In the "LOCAL OR NETWORK PRINTER" window, choose "LOCAL PRINTER ATTACHED TO THIS COMPUTER" and uncheck "AUTOMATICALLY DETECT"... click "NEXT".
In the "SELECT A PRINTER PORT" window click the radio button "CREATE A NEW PORT", click the down arrow and choose "STANDARD TCP/IP PORT".
In the window that pops up click "NEXT"
In the ADD PORT window, where it says "PRINTER NAME OR IP ADDRESS, type in your printers IP address, by me it was 192.168.0.66. The bottom line will fill in automatically. Click "NEXT".
In the "INSTALL PRINTER SOFTWARE" window, if you have the disk just choose "HAVE DISK" and install from there. If not, in the left column choose "HP" and in the right column choose "HP LASERJET 3050" (by me it showed up in the list, you can download the driver from here http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1140780&prodTypeId=18972&prodSeriesId=1161389&swLang=8&taskId=135&swEnvOID=228
click "NEXT"
In the "NAME YOUR PRINTER" window, choose a name and also choose if you want to set it as the default printer (recommended) Click "NEXT"
In the next window choose whether or not you want to share the printer, and if you do assign a printer name. Click NEXT. The next window is optional if you want to make a name, you can just click NEXT and your done! Print a test page to make sure that all is fine.
Feb 11, 2008 | HP LaserJet 3055 All-In-One Printer
Plz help me am in trouble
Network Configuration page
NOTE The Network Configuration page is only available on the HP LaserJet p2015n,
HP LaserJet p215tn, and HP LaserJet p215nw printers.
A Network Configuration page prints whenever a printer configuration page is printed. You
can also print a Network Configuration page by pressing the network Reset button at the
back of the printer
The Network Configuration page provides information about the network configuration,
including the IP address, firmware revision, network statistics, protocol information, and so
on. The Network Configuration page automatically prints when you print a configuration
page from the control panel.
ENWW Printer information pages 37
Using the HP Toolbox
The HP Toolbox is a Web-based program that you can use for the following tasks:
● Check the printer status.
● Configure the printer settings.
● View troubleshooting information.
● View online documentation.
You can view the HP Toolbox when the printer is directly connected to your computer or
when you are using a supported network connection. You must have performed a complete
software installation to use the HP Toolbox.
NOTE You do not have to have Internet access to open and use the HP Toolbox. However, if you
click a link in the Other Links area, you must have Internet access in order to go to the site
associated with the link. See Other links for more information.
To install the HP Toolbox, you must install the TCP/IP protocol and the most recent version
of the Java™ Virtual Machine on the computer. You must also install the DOT4 protocol for
all USB connections, LPT connections for Windows 2000 and Windows XP, and LPT1
connections for Windows 98 S.E., Windows Me, and Windows NT 4.0. See the system
administrator or computer manufacturer's documentation for more information about
installing the TCP/IP protocol and the DOT4 protocol.
Jan 22, 2008 | HP LaserJet P2015dn Printer
HP P2035N LaserJet Monochrome Printer Logo
357 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
