Question about Logitech G25 Racing Wheel
Down shift, left paddle will drop two gears sometimes. This will cause a spin for sure. How to repair the paddles?
3 Suggested Answers
Rasmick
  • 13 Answers
SOURCE: paddel on right side
Have you tried reinstalling the latest software from Logitech ...I have a Momo wheel and a reinstall has fixed a couple of issues for me ...
Posted on Jun 03, 2008
  • 30 Answers
SOURCE: wingman ff gp gear paddles
The drivers were made to work on XP, but I think I found one that may work on Vista for the steering wheel.
http://www.opendrivers.com/driver/240041/logitech-wingman-series-joystick-driver-5.01.256-windows-xp-vista-free-download.html
Now I am not sure whether it will work or not, there are alot of complaints for the wheel's pedals not working for games, but all the buttons working. Go into the control panel and look for the menu for controllers and input devices. Make sure all the settings are correct.
Posted on Apr 16, 2011
My mixer turns on and the paddle turns, but when I add any ingredients to the bowl, it stops turning!
sorry to say but you have an inside gear problem, not catastrophic in and of itself, but it will require a full tear-down, the worm gear is either worn down or stripped, It is made of nylon and its supposed to wear out or give out if there is a problem. It appears that there is enough gear left to turn the paddle but as soon as you have any load on it well not enough tread left to keep spinning the paddle. Service center will cost from $150.00 to 200.00 depending on where your nearest KA service center is (that includes shipping) If you are good with mechanical stuff you can do it yourself for about $50.00 dollars. There are sites on the web that will show you how and your parts list from the kitchen Aid site will show you what you need to order off of ebay to repair it.
Jul 14, 2014 | KitchenAid K5SS Heavy Duty Commercial...
The paddle in my new 1.5 L ice cream maker is not turning - is this normal?
Hello Maryo803,
It is not normal for the paddle not to move in these units. First we have to determine weather the paddle is striped or the gear is stripped. At the bottom of the paddle there is a hole that attaches to the turning gear on the machine. Look and see if it still matches the sprocket in the bottom of the ice cream maker. If it does not still match I would suggest buying a new paddle. You can purchase a new paddle from Cuisinart for $8.00 and here is a link to the page. http://www.cuisinart.com/parts/ice_cream/ice-20.html
However, if it is not the paddle please post back to this thread and I will see if it is worth changing out the bottom gear.
Thank you for choosing FIxYa.com
Justin
Mar 11, 2011 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Where can i buy a washing machine drum paddle (for inside the machine) one has snapped off today.
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the laterwashing machines often come loose and come off altogether. They can bereplaced. call them lifters. You usuallyinsert a small screwdriver down one of the holes (it's the 3rd one on ) andgently press down while sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
Mar 23, 2010 | Indesit W 123 Front Load Washer
One blade does not turn
The left blade on a BD 2300 bread maker did not turn when neading the dough. I took it apart by removing the six screws in the bottom of the case and the screws inside around the bottom outer edges of the metal insert. I then removed the screws holding the motor assembly to the base. I found that the metal plate attached to the paddle shaft driven by the gear had torn through the plastic gear, and was no longer driving the paddle. I made a new plate with the end bent down 90 degrees so that it fitted into a slot in the plastic gear. This is much stronger and the breadmaker now works fine. This is a weakness in the design and the failure could occur on either paddle. failures of the left paddle could be due to the toothed belt breaking, this drives from the right paddle gear. There is also a belt between the motor and the left paddle gear.
Dec 14, 2009 | Black & Decker B2300 Bread Machine
Just bought a 2005 grand pris gxp the owners manual dosent tell how to use the paddle shift
Hello! TapShift is very easy to use. First you have to put the console shifter in "M", at that point you are disengaging the automatic shifting in the transmission. If you're at a stop, the TapShift will default to 1st gear, if you're driving, it will determine the current gear and assume it. To shift using the paddles, you push them forward to upshift, and pull back to downshift. You can use either paddle individually, or together.
Hope this helps and thanks for using FixYa!
Oct 22, 2009 | 2005 Pontiac Grand Prix
Replace broken drum paddle on indesit wixl123 washing machine and were to purchase part
On hotpoint, creda, Ariston ,indersit and someother makes see video
To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine.
Huge selections of lifters are available on thewebsite DrumPaddle lifters
Oct 19, 2009 | Indesit W 123 Front Load Washer
Kayak drifting to the left
These boats are very short and have a smooth hull with very little keel. Because of this they will not track well and will have a tendency to turn.
You don't say how experienced a paddler you are.
Check also that you are holding your paddle equi distant from both blades. You may be unconsciously paddling harder with your right hand if you are right handed. Most of us are one-side dominant. You may also be sitting slightly diagonally in the boat without realising it. Experiment with shifting your position. Also consider a backrest if one is not already fitted.
You can fit a skeg to the stern whichwill improve straight line tracking. Abit like a fixed rudder. Use heavy duty elastic to hold it onto the boat stern.
Aug 24, 2009 | Boating
Plastic lug securing paddle in drum have broken off
It is easy to fit.
To remove paddle ,grasp firmly and pull it towards you, then slide new paddle into slots and push firmly towards rear of. drum
You should feel it clip into place..
Make sure you get right paddle as there are at least 3 versions of drum paddles
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint WMA64 Front Load Washer
Shift Bicycle Gears
To shift gear properly, while riding the bike you be sure you are turning the paddles, and shift the gear.
Try to avoid shifting gears while riding standing up, this stress the gear system.
Oct 29, 2008 | GMC Denali 700C Road Bike
Drum Paddle broken Hotpoint Aquarius
The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out.
Mar 08, 2008 | Hotpoint Ultima WF860 Front Load Washer
Logitech G25 Racing Wheel Logo
80 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Lyle Siemens
Lyle Siemens
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
