I cannot program my dvr because the timer will only show ch.3 what if i want to record ch.72 with th timer?
    Brigadier General:
  • 10,406 Answers
Go to "setup" mode on the DVR, and do a "scan for available TV channels", to add more channels,
or explicitly "add" channel #72 as an available channel.
Posted on Mar 17, 2011
Cm7000pal dvr stuck in wizard on continue in searching for channels seams to load on hdd then goes to continue
I have 3 of these 7000pals and 2 have done a similar thing, one of them did it twice. After the Loading Channel Master screen hangs for a time, they would restart. Then the same cycle would keep repeating. It seems like after years of adding and deleting timers, the DVR's software gets "confused". I've noticed that twice it happened on the hour just as a program timer started while I was watching a program through the DVR. ZAP...Locked up! The power button would not even work to turn it off.
The steps below fixed all three instances of this failure.
To unlock the Channel Master CM7000PAL DVR:
1. Unplug the recorder from the wall outlet and DISCONNECT THE ANTENNA. Now plug it back into the wall power outlet.(This will keep the recorder from freezing and rebooting)
2. let it go thru it's normal bootup, tv guide search, etc.
3. When you are able to, hit MENU and then go up to TIMERS. Delete all of the record timers. Unplug it, reconnect the antenna, and plug it back in.
4. After a now a proper bootup, re-program you timers and you will be good to go.
5. And the best thing is, all of your pre-recorded shows will still be there on the hard drive.
I would suggest that you do a yearly "TIMER CLEAN" to avoid this trouble in the future.
Jan 22, 2014 | Channel Master CM7000PAL HD DVR
Reboots then shuts down again
I have 3 of these 7000pals and 2 have done this same thing, one of them did it twice. It seems like after years of adding and deleting timers, the DVR's software gets "confused". I've noticed twice it happened "on the hour" just as a program timer started while I was watching a program through the DVR. ZAP...Locked up! The power button would not even work to turn it off.
Oct 07, 2013 | Channel Master CM7000PAL HD DVR
The channel master locked up so I unplugged it. Now, when I plug it back in it just sits and says loading Chanel master tv but does not load. What should I do?
I have 3 of these 7000pals and 2 have done a similar thing, one of them did it twice. After the loading channel Master screen hangs for a time, they would restart. Then the same cycle would keep repeating. It seems like after years of adding and deleting timers, the DVR's software gets "confused". I've noticed twice it happened on the hour just as a program timer started while I was watching a program through the DVR. ZAP...Locked up! The power button would not even work to turn it off.
Sep 22, 2013 | Channel Master CM7000PAL HD DVR
CM7000 DVR keeps turning off and resetting when I try to enter My Recordings.
Feb 09, 2013 | Channel Master CM7000PAL
Channel master cm7000pal
I have 3 of these 7000pals and 2 have done this same thing, one of them did it twice. I would suggest that you do a yearly "TIMER CLEAN" to avoid this trouble in the future.
Jun 29, 2012 | Channel Master CM7000PAL HD DVR
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
Memorex MVDR2102 Suffix A DVD video recorder I
can't set timer, because i can only set on ch. 3. what if i want to record ch. 72?
Jan 25, 2010 | Memorex Televison & Video
Dvr is programmed but at times "chooses" not to record show and other times it does record
Be sure that a DVR timer is set to fire, instead of an auto tune. Also if it is a series then make sure you select new episodes, your dvr will not recor a program if it has already recorded the same program once, ( re run) you can also check your scehdule in your dvr to check if timer has been deleted or modified.
Nov 13, 2009 | DISH Network DVR 510 DTV Receiver /...
Doesn't stop recording
Make sure there is no time overlap on any of the programs you have on the recorder.
That is the most likely problem
Aug 19, 2009 | DISH Network DVR-625 DTV Receiver /...
Recording
Coax out from box into cable in on VCR. Coax out from VCR to Cable in on TV. Set TV and VCR to ch 3. Put in blank tape. Start show on DVR and hit record on VCR. Hope that works for you.
Feb 07, 2008 | Arris DCT6200 DTV Receiver
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
