How do I set the alarm to only work on the weekdays and not weekends?
    Brigadier General:
  • 8,546 Answers
Model number first, then the manual. Then (maybe) a solution.
Maybe run it by the manufacturer
Posted on Mar 17, 2011
Tip
How to reset alarm with Emerson smart set alarm?
First, make sure the time is set correctly – Eastern Standard Time (EST) is the defaultPress the Alarm Mode button – it has options for Weekend, meaning Sat and Sun only; Weekdays (Mon-Fri), and Everyday
While holding either the ALM 1 or ALM 2 button, press up or down to set the correct wake-up time
Release ALM 1 (or 2) when you are finished.
This will help.Good luck.
on Mar 08, 2010 | Watches
How do i set the alarm on my ihome alarm dock?
Once the time is correct, users can move on to setting the alarm itself. Many iHome systems come with dual alarms allowing couples to set different times for each person or individuals to designate a weekday and weekend alarm. Each alarm has its own time, wake-to source, and frequency. The process of setting the alarm is the same for both options, the only difference is what button, either 1 or 2, users depress when setting it.
Once ready to set an alarm, users need to push and hold the button down, waiting for the alarm time to appear on the clock's display. From there, the up and down arrows or plus and minus buttons adjust the time backwards or forwards accordingly. Once that is complete, users select the frequency of the alarm by pressing the alarm button again and then opting for 7, 5, or 2, which correlates with all week, weekdays, and weekends respectively.
The final part to set is the wake source of the alarm. Users press alarm buttons one more time, and then use the same directional buttons to choose from iPhone and iPad on some models, radio, buzzer, or playlist. If users choose playlist, they must also setup a playlist within their Apple device titled iHome.
Because frequency is part of the alarm setting process, there is no need to turn on the iHome alarm manually as one would do with a normal alarm clock. However, users can check to see if the alarm is active by looking at the screen of the clock for the earliest alarm time, displayed on its lower part.
In the mornings, when the alarm sounds, users have two options: Snooze and disarm. The disarm process turns off the alarm until the next day in its frequency chain. Users disarm the alarm by pressing the power button. On the other hand, users must manually program the snooze button. Users do this by pressing and holding the snooze button and then toggling to the desired snooze time, generally between one and 29 minutes. Once this is set, users simply press the snooze button in the mornings to delay the replay of the alarm for that amount of time.
Jul 18, 2014 | iHome Audio Players & Recorders
Manual for clock radio timex T435B
For Timex T435B (LCD Weekday/Weekend Dual-Alarm AM-FM-MP3 with weekday calendar, try :
http://timexaudio.com/media/uploads/product/files/T435_IB_922.pdf
Jan 02, 2012 | Timex (T439S) Clock Radio
I have the emerson smartset clock radio. model cks1702. i need the mannuel so i can set it to go off through the week
There are several SmartSet clock Radios by Emerson. Which model do you have?
It's possible that you have alarm 1 and alarm 2 both set for weekends (if a two-alarm version). For the SmartSet radio, CKD5811, that I am used to, you can change the alarm mode between Everyday, Weekdays and Weekends. Press and hold the Alarm 1 (or Alarm 2) button then press the Alarm Mode button to toggle between the modes. Then release both buttons. If you press the Alarm 1 button, you will see the current alarm mode indicated by the indicators by the day that are lit. The Alarm Mode button is between the On/Off button and the Alarm 1 and 2 buttons on the CKD5811. Make sure that you have the Wake to Radio, Wake to Buzzer or Wake to CD slide set for the alarm in question. For Wake to Radio, set your station. For Wake to CD, make sure that the CD in the unit is one that actually plays in the unit (scratches, etc). Also check the volume (although that seems like less of a concern since it does wake you on weekends).
The manual for the CKD5811 is here:
http://www.emersonradio.com/resources/owner_manuals/manual_1312917117.pdf . Additional manuals are here: http://www.emersonradio.com/owner_manuals.php . Scroll down in the drop down menu for the SmartSet manuals (clock radios all start CKD). The manuals are in alphabetical order.
I hope this helps.
Oct 29, 2011 | Emerson Smartset Clock Radio
I lost my manual in moving and not sure how to set the alarm. It worked a couple of times and then didn't.
There are several SmartSet units by Emerson. The manuals are here: http://www.emersonradio.com/owners/SmartSet%20Series/ .
For the CKS2000N, you set the alarm by pressing Alarm 1 or Alarm 2 (both are on the top, one to the left and the other to the right) then hold the button while you use the up or down arrows to adjust the wake time. Press and hold the Alarm 1 or Alarm 2 button and then press the Alarm Mode button to select the days of the week you want that alarm to ring (Weekdays, Weekends or Everyday).
Finally set the Alarm selector (on the left side at the back) switch for each alarm to Radio, Buzz or Off. If the alarn selector is off, the alarm will not ring.
I hope this helps.
Jan 31, 2011 | Emerson Smartset Clock Radio
The green set lights up for sat and sun--the days I don't need to get up. How do I set the clock for days m-f. thanks
HOLD DOWN ALARM 1 OR ALARM 2 AND CYCLE THRU USING ALARM MODE FOR WEEKDAYS, WEEKENDS, OR ALL DAYS...
Aug 17, 2009 | Emerson SmartSet CKS1850 Clock Radio
Smart set alarm clock - resetting instruction
Here is a link to the manual:
http://www.emersonelectronics.ca/emerson/en/product/view/17796
-Tha Mp3 Doctor
Jan 15, 2009 | Emerson SmartSet CKS1850 Clock Radio
Lost instructions for Emerson
to change the alarm mode setting for alarm 1, hold alm1 setting button and press the alarm mode button until the day indicators show thedesired mode setting. weekday only,weekends only,or everday operation. release the alarm mode and alm 1 setting buttons and the display will return to correct time.
Dec 05, 2007 | Emerson CKS2237 Clock Radio
Emerson clock radio model cks3029
When you set the alarm make sure that it is set to go off on the day of the week desired. This clock has the feature to allow for weekday, weekend, or both. The alarm mode button while the alarm set button is pushed to change. Observe the LED's below.
Jun 27, 2007 | Emerson CKS3029 Clock Radio
20 people viewed this question
 Grubhead
Grubhead
