Question about Frigidaire FRT21H8 Top Freezer Refrigerator
I have a frigidarie and water is flooding the bottom of the veggie drawer, no where else is containing water
I AM ALSO HAVING THIS PROBLEM. i HAVE LOOKED IN THE BACK FOR SOMETHING TO REMOVE AND CLEAN BUT EVERYTHING SEEMS VERY TIGHTLY ATTACHED.
Posted on Sep 01, 2012
catriver
  • 878 Answers
SOURCE: water always inside refrigerator sometimes ice forms
LadyBlues, This is a top mount freezer. What's happening is that the drain in the freezer area is frozen over. When the unit goes into defrost, the water is running into the refrigerator area instead of going down the drain hole. You will have to remove the freezer bottom panel and then the freezer rear panel to unclog the drain hole. It will be under the evaporator in the drain tray. Use some nice hot water from the microwave and pour it into the tray until the water flows down the drain tube. This should clear up your problem. Catriver.
Posted on Jul 12, 2007
  • 100 Answers
Sounds like you might have a condensation problem. Is the fan in your freezer working? If not it's not circulating the cold air. If it is you might have frost on the lower rear wall of your freezer meaning its not defrosting like it should and restricting your air flow. Last but not least you have a damper door in the upper left corner of your fridge that allows the cold air from your freezer into the fridge to cool it, that might not be opening up. Any one of these things would cause your water problem and a warm fridge section
Posted on Dec 05, 2007
SOURCE: Samsung RS253BASB leak at bottom veggie drawer
I had the same problem. I called tech support and they were no help. Being a handy man I dove into the problem myself and discovered the problem. If you want this solution, I have pictures and information. Simply email patmcclain@charter.net and I will send you this infomation.
Posted on May 13, 2009
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved.
taken from: http://www.repairclinic.com/0088_4_1.asp#Level2_6
Posted on May 19, 2009
  • 23 Answers
SOURCE: water leaking on the shelves and into veggie drawers
These refrigerators are bad for the defrost drain tube freezing up. Remove the back wall of the freezer to check the drain pan. Some people have attached a piece of wire to the heater and put the other end 2-3 inches down the drain tube to carry heat to help keep the ice cleared out.
Posted on Jun 19, 2009
Why is water pooling in bottom of fridge under veggie drawer.? Also freezing ice cubes in back part of cube drawer
Just above the veg drawers at the back is a channel that collects water when the fridge defrosts. It has a hole to drain the water which is blocked and the water is pooling under the drawers. Clear the hole with a drinking straw.
May 15, 2012 | GE Refrigerators
F1 code. No water left in machine nor on the floor, is this something we can look at ourselves?
Hi
Error F1 on your fisher & paykel means an overfill condition. One of the most common causes for an overfill fault is that the dishwasher cannot pump out the dirty water due to a plugged drain hose. Check the drain hose if it is clogged. Now remove the bottom drawer from the unit to inspect the flood switch. Remove the wire harness cover on the underside of the drawer. With the bottom cover off, unclip the wire harness, fill hose, and drain hose. Then unclip the linkage at the back of the drawer and lift the drawer off the slider arms. Now' you'll be able to look at the flood switch. Note the positions of the wires on the flood switch and remove them. Then unclip the switch housing from the base panel. The switch housing contains one switch for each drawer. The switches are wired normally closed (NC) and each switch has three spade connections, so it's important to note where the wires went. Now clean the contacts and let it dry. Hope this helps... Please post back if you need more information.
Daniel
Aug 03, 2011 | Fisher DD603FCSS Dishwasher
Subzero 650 bottom freezer is pooling water under the veggie drawer
Check you your drain line behind the 2 bottom drawers. Most likely it's clogged. You can try snaking it out with a single foot wire. See if the water goes away from the trough.
Smith Brother Appliance Repair reviews
Apr 12, 2011 | Sub-Zero 650 / O Bottom Freezer...
Both drawers on our dishwasher will start by it self and will display "F1". In our user guide - it tells us "flood switch has been activated". How can I fix it?
Hi
Jan 31, 2011 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel f1
Hi
Error F1 on your fisher & paykel means an overfill condition. One of the most common causes for an overfill fault is that the dishwasher cannot pump out the dirty water due to a plugged drain hose. Check the drain hose if it is clogged. Now remove the bottom drawer from the unit to inspect the flood switch. Remove the wire harness cover on the underside of the drawer. With the bottom cover off, unclip the wire harness, fill hose, and drain hose. Then unclip the linkage at the back of the drawer and lift the drawer off the slider arms. Now’ you’ll be able to look at the flood switch. Note the positions of the wires on the flood switch and remove them. Then unclip the switch housing from the base panel. The switch housing contains one switch for each drawer. The switches are wired normally closed (NC) and each switch has three spade connections, so it's important to note where the wires went. Now clean the contacts and let it dry.
Hope this helps...
Daniel
Aug 13, 2010 | Fisher and Paykel 24 in. DD-602 Built-in...
Have f1 fault cant get bottom draw out to check for moister build up
The reason that you are getting F1 fault might be the dishwasher drawer is flooding. The drawer not opening is perhaps due to either the keylock being activated or the controller has gone into some unkown state.
Try turning the mains water inlet water tap off and also switch off the power. Turn everthing back on and then check if you can open the drawer. If you have water inside the drawer you may need to empty it manually with a small container. If it floods again, then the solenoid that turns of the power or the water level sensor might be faulty.
Nov 12, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
My Fisher Paykel dishwasher is flashing F1 - top drawer only. The bottom drawer is working just fine.
F1 error means the flood switch in the drawer is activated. If there is water inside when you open the drawer then you will have to manually empty it with a small container.
Most likely the solenoid that controls inlet water is faulty or the water level sensor is faulty.
Try turning the mains power and water off and on again and run dishwasher. If fault persists then you may have replace the parts.
Nov 11, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Kitchenaid refrigerator mdl KTRS22M has water under veggie drawer
Hi, water could be excessive moisture, check door gasket, or check drain at back above veggie drawers, could be block, make sure produce not blocking drain hole, clean, check carefully for drain.
Aug 02, 2009 | Refrigerators
Water collecting under veggie drawers on bottom
check to see if defrost hose is clogged under veggie drawers
Aug 02, 2009 | Kenmore Refrigerators
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
74 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
