F1 error means that the flood switch has been activated. To reset the flood switch you need to remove the bottom dish drawer to be able to access the reset buttons. To remove the drawer you press in the rectangle buttons and slide them back under the drawer, they are located right behind the front panel at the bottom of the drawer. It may help to have someone help hold the drawer for you. Once they are slid back all the way place the bottom drawer on the floor to the left side of the washer as you look at it. This will give you the access you need. Lie down on the floor so you can see in the bottom. There you will see a white coloured plastic box on each side, one is for the top drawer the other is for the bottom drawer. Make sure the power is off to the dishwasher. Place your finger underneath the box and you will feel a small pin/lever. This is attached to the magnetic flood switch and resets it when you click it one way and then the other. Once you have done this turn the machine back on before you put in the bottom drawer as if it does not work then you will need to activate it maybe a couple of times. Once the F1 alarm disappears you are good to go. Place the drawer back in the opposite way to removal. Slide one rack forward and rest the drawer on it. Then slide the other side out and it will snap lock into position.
The link below is a video that explains how to fix the F1 error code on your fisher paykel dishwasher. This is a veer common issue and can normally be repaired without parts.
Fisher Paykel Dishwasher Repair Video
Appliance & Refrigerator Repair
F1
means that your dishwashers have flooded. You can
download the video in the link below to see how to get rid of the error
and fix your dish drawer for numerous other problems. If your drawer is
noisy you may want to replace the rotors at this time as well.
Appliance Repair Video
Order Fisher Paykel Rotor in this link if needed
SOURCE: fi code washer wont stop beeping
See this site for a full explanation of how to fix this problem, I don't want to type it alll again. F1 error code is 'overfill' most frequently due to a clogged drainhose. If not see here;
http://fixitnow.com/2004/10/appliance-repair-revelation-fisher.htm
SOURCE: My dishwasher started beeping and
Hi
Error F1 on your fisher & paykel means an
overfill condition. One of the most common causes for an overfill fault is that
the dishwasher cannot pump out the dirty water due to a plugged drain hose.
Check the drain hose if it is clogged. Now remove the bottom drawer from the
unit to inspect the flood switch. Remove the wire harness cover on the
underside of the drawer. With the bottom cover off, unclip the wire harness,
fill hose, and drain hose. Then unclip the linkage at the back of the drawer
and lift the drawer off the slider arms. Now' you'll be able to look at the
flood switch. Note the positions of the wires on the flood switch and remove
them. Then unclip the switch housing from the base panel. The switch housing
contains one switch for each drawer. The switches are wired normally closed
(NC) and each switch has three spade connections, so it's important to note
where the wires went. Now clean the contacts and let it dry. Hope this helps...
Please post back if you need more information.
Daniel
