Question about Sony PCS-1600P
Hello I config Sony PCS-1600P though ADSL which is port i need to open on Modem?
    New Friend:
  • 3 Answers
It need software Sony PCS-UC161 H.323 IP Upgrade for PCS-1600. you can call me at 919310201020 or email at yogirajbagga@gmail.com to get this software
Posted on Aug 06, 2014
1720 TCP 2253-2263 TCP 49152-49239 UDP
Best Regards,
Posted on Jun 14, 2011
  • yogiraj
    yogiraj Aug 06, 2014
    it need software Sony PCS-UC161 H.323 IP Upgrade for PCS-1600. you can call me at 919310201020 or email at yogirajbagga@gmail.com to get this software
Upgrade Sony PCS-1600P
it will need a software, you can contact me
india, 9310201020 yogirajbagga@gmail.com
May 21, 2012 | Sony PCS-1600P
Can I set this up this wireless router if I have cable internet and not DSL?
You CAN do this if you have access to the firmware of the ADSL gateway.
Connect cat5 cable from ethernet port on cable modem to ethernet port 1 on ADSL Gateway. (Must be port 1)
-Connect cat5 cable from computer NIC to other port on ADSL Gateway.
-(You may need to) Start->Run->cmd
ipconfig -release all
ipconfig -renew
Here's the trick...
-Open web browser, go to ADSL Gateway homepage (likely 192.168.0.1)
-Configuration tab, Advanced WAN->WAN
-Change WAN PORT drop down from DSL ATM PORT to ETHERNET PORT 1
-Click Edit button. Change Protocol from PPPoE to ROUTED.
-Radio button for DHCP Client to Enable.
-Click Set button.
-(You may need to) Power cycle both Cable Modem and ADSL Gateway device
Now this was done on a Westell ADSL gateway from verizon, yours may differ and you may need to look up the instructions for your specific gateway.
Aug 08, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
I followed the instruction but can't seem to connect to the internet, do i need a separate modem or is the one in my regular computer enough. i have belkin G wireless router. i have tried everything....
If you are trying to connect wireless you will need a wireless card. Routers are very peticular about the way they are set up. Unhook everything turn everything off and reboot computer, and run the software disc that came with the router. Plug the dsl into the the Blue colored port or Wlan then reboot computer and then plug cable into computer. This should work.
Nov 21, 2009 | Belkin (F5D7633UK4A) Wireless Router
Router ports require configering
I know the ADSL portion of the modem needs configuration. But the routers are settup for default as dynamic and no WEP. At least the ones I have used.
Most belkin routers have a default gateway is 192.168.2.1. Try that and go into the setup. There is also a CD to help with setup.
If you need more help explain more in detail what setup you need.
Oct 25, 2009 | Belkin Computers & Internet
I hv a netgear wireless adsl modem and i m using bsnl broadband connection can send me the settings to configure the modem at my email id mehtaankur3@gmail.com
TYPE-I Modem Configuration - Huawei SmartAX MT880 Modem / SmartAx MT882 ADSL Modem Configuration
SmartAx MT880 ADSL Modem has One ethernet Port.
SmartAx MT882 ADSL Modem has One ethernet Port and one USB Port.
Set your computer IP address as 192.168.1.2
( If you are using USB port, install USB driver first)
Open Internet Explorer in the Address bar type the URL http://192.168.1.1
You will be propted for Username and Password.
Username: admin
Password: admin
Click on Home
Click on WAN setting
Your WAN Setting should be as follows:
PVC No.: PVC0
Wan type: PPP
Connection Type : PPPoE
VPI / VCI : 0/35
Default Route : Enabled
Username: yourusername@dataone
Password: yourpassword
Use DNS : Enabled
Click on Apply.
You will be asked to save and reboot.
Select Yes
Once your modem is rebooted , the summary page will be displayed .
The "Green" status of PVC0 status indicated that you are now connected. (in Summary page)
SmartAx MT882 ADSL Modem ADSL LED will turn 'Orange' from 'green' when succesfully connected
Sep 15, 2009 | NetGear WGR614 Wireless Router
Using both USB and Ethernet to connect to the internet
Does your router suports usb ports, normally routers do not support usb ports, please check if your router first suports usb ports
Jul 22, 2008 | Paradyne 6381 ADSL2+/ReachDSL Router...
How to setup an adsl modem and a router
forget the router as it appears that it is messing with the connection
May 13, 2017 | Cnet CNIG914B 4-Port 10/100Mbps Router
How to use second access point as repeater
pls i also need solution to this problem, kindly send to my email akinomatics@yahoo.com
thanks
Feb 12, 2008 | D-Link AirPlus G DWL-G710 Wireless Range...
Siemens ADSL Modem (model SL2_141) networking
i m reset the setting in my modem
my modem no is - sl2_141
192.168.1.1 this site is not open
plz solve my prob...
Jan 30, 2008 | Siemens SpeedStream 5260 ADSL LAN Modem...
Sony PCS-1600P Logo
962 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
