Hi I have a TH50PZ80U that is flashing two red lights when I plug it in. If i press the power button for 5 seconeds it will flash 10 times. When applying power the AC relays click, after pressing the power button the fans turn on and the optical audio port is red. It will stay 'on' for 3 seconds and then the relays will click on turn off. No red optical light. If I test the P25 connector pin 1 voltage it will go to 15 Volts for about a seconed and then 0. This is only achieved by plugging the TV in and then pressing the power button. Then reseting to do it again. I followed all the troubleshooting tips in the flow chart and results are inconsistant. Some things tell me to replace the P board and other things say to replace the D Board. Also I'm unsure if the problem is in the larger P board or the smaller. Thank you for any help you can provide.
  • 6 more comments
  • bschaub796 Mar 17, 2011
    Thanks so much, but I need something more specfic.
    Here is why I think the power supplys work; when I plug AC power in, the relays fire and the A board get volatage and the Optical audio laser turns of for 10 seconeds, when i push the power button the optical audio light turns back on, fans spin, and then it powers back down.
    Then the power switch does nothing and I can only replicate this power unplugging and plugging it back in.
    There also seams to be a inductive lamp on the smaller P board which does not light up.
    Hi, thanks for the reply.
    I'm still kinda confused. I get two flashes when
    1. Apply power
    2. Press power button
    3. Two flashes
    or
    1.Apply Power
    2. Press and hold power button
    3. 10 flashes.
    So I don't really know if the D board needs to be replaced or the P board.
    Thanks.
  • bschaub796 Mar 21, 2011
    Ok, I ordered the D Board. I'm just confused how this will help, because the TV won't power on and shows no since of life replacing a power supply over the format converter makes better sense. But I'll take your word on it.
    We will know more when the board arrives.
    Although this did help things... The Main CPU IC9003 has multiple functions. It provides the command to turn on/off the Power Supply
    and the Panel Drive circuit within the D board. It also monitors a number of voltages and circuits
    providing protection by shutting down the TV when an abnormality is detected. This condition is
    communicated to the Main CPU in the A board. When this happens, the power LED blinks a specified
    number of times indicating the circuit that has failed.
    On page 77 of that it shows common symptoms of the D board. Once again, I have no video. The TV does not power on at any point.
    This is why I think it may be a combination of two problems. AKA, two boards being out.
  • bschaub796 Mar 22, 2011
    I replaced the D Board. No change in behavior. Still the exact same issue.
    This is why I believe the P Board is bad. Everything that says to replace the D board says that there is almost always some sort of image on the screen. My unit won't even power on. So I've now ordered the P board.
  • 325 Answers
I'm 100% confident that a D-board replacement will fix this issue. I've worked on 8 of these and a D-board replacement fixed the issue you are having now. I had all the same problems with them but it is all related to the D-board (from previous experiences)
Thank you!
Posted on Mar 17, 2011
  • 2 more comments
  • Andrew P.
    Andrew P. Mar 18, 2011
    Please view this link.
    http://www.scribd.com/doc/24963802/11th-...
    Depending on your skill set this will allow you to understand your blink errors and replace components versus entire board replacements.
    This document is for many models, but because of duplications of electronic components it covers your flat screen as well..
    On page 19 your flat screen begins being covered and page 33 begins the blinking error codes and the components responsible for the error.
    Hope this helps you :) Please rate if it does
  • Andrew P.
    Andrew P. Mar 21, 2011
    This very well could be two boards. That is why manuals like this help to pin-point what is responcible for the blinking errors. I was just giving advice off previous experience with this model of tv. This very well could be two boards as electronics don't always follow the same types of defects. I have gotten lucky many times with the D-board replacement for this tv, but this doesn't mean that you could very well have two boards out.
    Let me know what happens :)
  • Andrew P.
    This very well could be two boards. That is why manuals like this help to pin-point what is responcible for the blinking errors. I was just giving advice off previous experience with this model of tv. This very well could be two boards as electronics don't always follow the same types of defects. I have gotten lucky many times with the D-board replacement for this tv, but this doesn't mean that you could very well have two boards out. Let me know what happens :)
  • Andrew P.
    Andrew P. Mar 22, 2011
    I would agree with the image idea, in general, however there is no true math to this sort of thing. This is why learning from experience is key because you will develop an eye for electronic repair if you just keep learning. The things I used to have to look up are now in my memory and can go through any electronic with a multimeter and "usually" pin-point what is responsible. I'm sorry the D-board didn't work but it has for me many times in the past. I wish you the best with the P-board and keep an eye out for future "weird" things going on with the tv. Hopefully, in the future, you can do component repair on it instead of board replacements :)
    BEST OF LUCK!
    Genius:
  • 1,622 Answers
Power LED Blinking timing chart
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred to the unit, the protection circuits operate and set the unit to stand by mode. At this
time the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
Fault maybe on the A board 3.3V SOS give me your email & i send you the full timing chart
* Note blink charts can be different depending on the model and the year of the T.V.
1 - blink STV 5v sense DG Board
2 - blinks 15v SOS D Board
3 - blinks 3.3v SOS D Board
4 - blinks Power SOS P Board
5 - blinks 5v SOS D Board
6 - blinks Driver SOS 1 SU / SD / SC Boards (SC energy recovery circuit)
7 - blinks Driver SOS 2 SU / SD / SS Boards (SC floating voltage area)
8 - blinks Driver SOS 3 SS Board (SS energy recovery circuit)
9 - blinks Panel Config. SOS
10 - blinks Sub 5v SOS / Main 3v SOS DG Board DTV 9v SOS / Tuner Power SOS
11 - blinks Fan SOS PB Board
12 - blinks Sound SOS H Board
13 - blinks Communication error DG Board with IC8001 (Pesks Lite 2)
Here you go...
constreet.com/PanasonicPl...smaProblem.htm
Hope this helps you out.
  • 2,098 Answers
Hi bschaub796,
10 times blinking of your unit indicated that the processor sense the missing 15v from the power supply. This problem is quite technical since I've already read your post that you have a reading of 15v in P25.
Now, we have to examined it deeply to determine where the fault came from between the two board.
If you have a 15v coming from the power supply but its go to 0v after a while which trigger the 10 blinks, you have to check the feedback circuitry of the power supply for faults. If you can't find any faulty parts on that section means that the feedback circuitry trigger to shutdown because it sense fault in the D board.
Remember that it has a good regulation output from the power supply, the issue here is the feedback circuitry that sense the fault. If you are going to ask my opinion I've suspected that the fault is in the D board.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
  • 5 more comments
  • Jdvillanueva
    Jdvillanueva Mar 17, 2011
    its ok, click this link it will help you more http://www.scribd.com/doc/24963802/11th-..., have a nice day///1, feel free to ask question if you need my help...
  • Jdvillanueva
    disconnect one-by-one all the load from the D board to isolate them from fault.
  • Jdvillanueva
    2 blinks is related to 15v missing supply from the D board. I've already said this a while ago that I didn't suspected youre P board as the defective parts. Since the last feedback(command to operate the 15v from the P board) star-up check will be coming from the D board, high chance that you're P board is good. Proved it by the reading with your meter (15v coming then goes to 0v). In this case the P board was disable because it has encountered the problem from the D board.
  • Jdvillanueva
    If the P board is defective, you can't get a 15v. This was disable after a start-up check because of the feedback circuitry designed to shutdown the power supply once sense faulty/shorted on its load to avoid further damaged.
  • Jdvillanueva
    Another option if you're not comfortable with my answer is, look for a shop that will check your P board for faulty parts. If the shop confirmed that there is no defective parts on this board then this is the time to replaced the D board. If they found faulty parts there then I'm wrong that the D board was faulty...
  • frantz toussaint Oct 28, 2011
    where can I buy the D board
  • frantz toussaint Nov 08, 2011
    do you know where I could get the D board
Cricut mini flashing red light
1-Open Cricut Craft Room with circuit on and flashing green/red
2-Hold power & feed button together until both are solid green
3-You'll be prompted to update firmware
4-Press & hold two buttons again (keep holding)
5-initiate firmware update
6-Let sequence go until 99% ...you may hear a sequence of beeping, don't be alarmed
7-Release buttons
8-You'll be prompted to restart your machine
9-Unplug all plugs from Cricut
10-Wait 30 seconds
11-Plug in both cords
12-Power on Cricut
13-Light should be solid green
14-Press OK on Craftroom prompt on computer
15-Done
Jan 03, 2014 | Provo Craft Cricut Disney Font Cartridge
Tip
How to Reset Your Water Filter Light
<b>Amana:<br /></b> <ol> <li>Press and hold the <b>dispenser lock</b> and <b>auto light</b> buttons on the dispenser for 4 seconds until the filter status indicator begins to flash, then release the buttons.</li></ol>or<br /> <ol> <li>Press and hold the <b>dispenser lock</b> and <b>water</b> buttons for 4 seconds until the filter status indicator begins to flash, then release the buttons.</li></ol>or<br /> <ol> <li>After replacing the water filter, press and hold the Reset Filter pad for 3 seconds. The Order and Replace indicator lights will blink and then go off when the system is reset.</li></ol><span style="font-weight: bold;">Brita:</span><br /> <ol> <li>Press firmly and hold start button for 5 to 10 seconds.</li> <li>Four bars will appear in the display, one after the other, and flash. Do not release the start button until the 4 bars appear and start to flash. If you have difficulty pressing the start button, a capped ballpoint pen may be used to press the button down.</li> <li>A small flashing dot in the lower right corner shows the indicator is working.</li> <li>Every 2 weeks a bar automatically disappears. When only 1 bar remains make sure you have a new filter on hand.</li> <li>After 2 months, when all bars have disappeared, an arrow will flash at the top of the display reminding you to change your filter. </li></ol><b>Frigidaire<br /></b> <ol> <li>Press and hold the <b>reset </b>button on the dispenser until the green light flashes (up to 15 seconds).</li></ol><b>GE:<br /></b> <ol> <li><b>P</b>ress and hold the <b>reset water filter</b> button on the dispenser for 3 seconds.</li></ol>or<br /> <ol> <li> Press the reset button on the dispenser for 4 to 8 seconds then release. </li></ol><b>Hotpoint:<br /> </b> <ol> <li><b>P</b>ress and hold the <b>reset water filter</b> button on the dispenser for 3 seconds.</li></ol> <b>Jenn-Air:<br /> </b> <ol> <li>Press and hold the <b>lock</b> and <b>light</b> buttons (<b>lock and water</b> on newer fridges) on the dispenser for about 4 seconds, until the indicator light blinks.</li></ol><b>Kenmore:<br /></b> <ol> <li>Press and hold the button next to the filter light for 10 seconds.</li></ol><b>KitchenAide</b>:<br /> <ol> <li>Press the <b>light</b> switch 5 times within 10 seconds. If the fridge has a <b>filter button</b>, press and hold it for 5-10 seconds.</li></ol><b>LG:<br /> </b> <ol> <li>Press and hold the <b>reset</b> button for 3 seconds.</li></ol><b>Magic Chef</b> <br /> <ol> <li> Press and hold the light and lock pads until the change filter light flashes. (approximately 3 seconds)</li></ol> <b>Maytag:<br /></b> <ol> <li>Press and hold the <b>lock</b> and <b>light</b> buttons (<b>lock and water</b> on newer fridges) on the dispenser for about 4 seconds, until the indicator light blinks.</li></ol>or<br /> <ol> <li>Press the refrigerator's light switch five times within ten seconds.</li></ol><b>Samsung:<br /> </b> <ol> <li>Press the <b>ice type</b> and <b>child lock</b> buttons simultaneously for 3 seconds. NOTE: Hold the buttons for only 3 seconds. If you press these 2 buttons simultaneously for 5 seconds, the reset function ceases.</li> <li>Release the buttons and repeat the same step one more time. The water filter indicator light should turn green.</li></ol>or<br /> <ol> <li><span>Press and hold the "Alarm/Hold" button for 3 seconds.</span></li></ol>or<br /> <ol> <li><span>Press and hold the <i>Fridge </i>and <i>Power Cool</i> buttons for 3 seconds.</span></li></ol><b>Whirlpool</b>:<br /> <ol> <li>Press the <b>light</b> switch 5 times within 10 seconds. If the fridge has a <b>filter button</b>, press and hold it for 5-10 seconds.</li></ol>
on Jun 17, 2011 | Refrigerators
I have requirement of region code cracker for sony 3d E370
hi,
To make your BD player you need One for all universal remote control
Full procedure for a oneforall remote is as follows:
1. Press DVD
2. Hold the magic button until the DVD button flashes twice.
3. Press 0533
4. Hold the magic button until it flashes twice.
5. Press 994
6. Press Magic Key (don't hold)
7. Press 00189 (if your oneforall remote uses 4 digit or 3 digit codes, use less leading zeros)
8. Press 1 ( this sets it to key 1 - it flashes twice )
9. Hold the magic button until it flashes twice.
10. Press 994
11. Press Magic Key (don't hold)
12. Press 00255
13. Press 2 ( this sets it to key 2 - it flashes twice )
14. Hold the magic button until it flashes twice.
15. Press 994
16. Press Magic Key (don't hold)
17. Press 00095
18. Press 3 ( this sets it to key 3 - it flashes twice )
19. Hold the magic button until it flashes twice.
20. Press 994
21. Press Magic Key (don't hold)
22. Press 00221
23. Press 4 ( this sets it to key 4 - it flashes twice )
24. Hold the magic button until it flashes twice.
25. Press 994
26. Press Magic Key (don't hold)
27. Press 00079
28. Press 5 ( this sets it to key 5 - it flashes twice )
The remote is now programmed and ready to use, to make the BDV-E370 region free:
1. Use the remote that came with the player to bring the player out of standby, make sure there isn't a disc in it.
2. Press 1, 2, 3, 4, 5 on the oneforall remote. The 24p light will start flashing. (Centre light)
3. Put the player back into standby with the Sony remote.
4. Hard reboot machine (remove power)to prevent the 24p light flashing indefinitely.
5. Next time you turn on the player it will be region free for DVD playback.
ok
Aug 08, 2011 | Sony Televison & Video
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
I have a Sony BDP S370 and I would like to make it region free for my DVDs.
hi,
u can make your dvd for region free DVD play back. but for that you have to purchase an universal remote (ONE FOR ALL URC-7950). through this remote only you can make player DVD region free.
first of all u have to set( program) the remote for the same purpose.
Full procedure for the OneForAll URC-7950 remote is as follows:(preparing remote)
1. Press DVD
2. Hold the magic button until the Power key flashes twice.
3. Press 0533
4. Hold the magic button until the red led flashes twice.
5. Press 994
6. Press Magic key (don't hold)
7. Press 00189
8. Press 1 ( this sets it to key 1 - it flashes twice, if not repeat steps 4 to 8 )
9. Hold the magic button until the red led flashes twice.
10. Press 994
12. Press 00255
14. Hold the magic button until the red led flashes twice.
15. Press 994
17. Press 00095
19. Hold the magic button until the red led flashes twice.
20. Press 994
22. Press 00221
24. Hold the magic button until the red led flashes twice.
25. Press 994
27. Press 00079
The remote is now programmed and ready to use, to make the BDP-S370 region free
2. Press 1, 2, 3, 4, 5 on the OneForAll URC-7950 remote. The power light will start flashing. (blue middle light)
4. Next time you turn on the player it will be region free for DVD playback.
OK
Jan 13, 2011 | Sony BDPS370 BluRay Player
I have a Panasonic th50pz80u and a rather unique problem. Very often, if I turn the tv off the red power LED light flashes continually. If it is flashing then I can't turn the set back on. I have to unplug...
This Unique problem is Quite Common with Most Brands. Have you tried to Turn it OFF using Remote?
If not Try it.
If yes, and the problem still persists, you will have to contact manufacturer for software updates for the TV or a main board in witch the problem is happening from. if they don't have software upgrades for the unit you will have to get a new main board.
Usually 10 Blinks on This Model is a Real Bad News - The 10 blink code is indicating the A board has failed and will need to be replaced, unfortunately you will need to wait on that repairman to complete this for you. I can however give you a good idea of what it will cost so he doesn't try to pull any wool over your eyes. I have looked up this part and would say the cost should be somewhere below $650+tax according to my resources.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 03, 2010 | Panasonic Televison & Video
Panasonic LiFi model number PT-50LCZ70. Have red lamp light flashing on front 2 times. Have tried to turn it on and get no picture and no sound at all. I checked and the fan is running. What now?
After the red 2 flashing starts, press the power button on the front of the TV and hold pressed down for ten seconds.
You will hear a faint click comming from the back of set.
After 10 sec release the button and wait 10 more seconds then press the start button and release right away.
The green light flashes and the bulb attempts to start.
I found my picture will turn on on the third attempt of the bulb restarting.
When you do this and the room is dark you can see the bulb attempt to restart, My bulb has restarted on the third restart every time.
(note: The three start attempt happen after I do the button pressing
1 time and I do not need further button pressing restarts.
I think panasonic needs to let us know what the problem is.
I called Panasonic and they told me to plug it into a wall plug by itself.
I have it plugged into a multi plug adaptor now and have not tried this yet.
Nov 06, 2009 | Panasonic PT-50LCZ70 50" HDTV
I have a digistat scr with a flashing red light and no heating there is nothing wrong with the batteries, this only occured after a poweer cut.
Try this first before condeming the unit.
1. Turn off the power supply to the Digistat SCR (receiver unit)
and leave for 5 seconds.
2. Turn on power to SCR unit and check red light is on.
3. Press override button No.2 and check the green light comes
on and boiler fires.
4. Press & hold down button No.1 (Keep depressed), then
press No.2 and keep depressed. {The Red LED light will flash
a couple of times and then it will go out}
5. Now release both the buttons – {the two LED lights should
come back on}
6. Get the Digistat+2RF/+3RF unit and stand two metres away
from the SCR unit with the Digistat+2RF/+3RF unit in your hand.
7. Remove the battery cover and fit the batteries.
8. The Red LED light on the SCR will now flash for approx. 7
seconds.
9. This confirms that the radio signal is being sent and
received.
10. The Digistat+2RF/+3RF and the SCR are now successfully
linked by a dedicated RF address.
Mar 21, 2009 | Water Heaters
Cannon BJC 80
5 times try this:
1: Unplug Power Cord
2: Hold POWER and RESUME buttons
3: Plug in Power Cord
4: Release buttons after the printers starts up
5: Hold CARTRIDGE and RESUME
6: Press POWER
7: Release all buttons after the beeps
8: Press CARTRIDGE 16 times
9: Press RESUME
10: Unplug the Power cord
3 times, probably something wrong with the cartridge.
Nov 21, 2007 | Canon BJC 80 InkJet Printer
Televison & Video Logo
409 people viewed this question
Top Televison & Video Experts
Electro Med Services...
