Question about Speed Queen CTSA0AWN Front Load Washer
Hello! Can you tell me what's going on when your
Hello! Can you tell me what's going on when your washer wants to act like R2-D2 and 'walk' across the floor during the rinse/spin cycle? In almost every load, small or large, our washer makes this loud sound similar to a small plane's engine. It continues during the spin cycle and the maching literally moves the 1-2". If there are any objects on top they come crashing to the ground. Is there a problem in the balance of the clothes? If so, does this throw the drum out of place? Is there anything we can do to control this or should we consult with a local appliance person? Thank you for your time and look forward to hearing from you! Sincerely, Midge Carstensen Redmond, WA
  • 177 Answers
SOURCE: 28+ year old- Speed Queen Heavy Duty top loader
It sound like you drain hose is siphoning off the rinse water, It needs a standpipe make sure the drain hose is at about the height of the top of the washer, Make sure the drain hose isnt stuck in the drain it also needs an air cap. the drain hose should not lay on the floor to run to the drain
Please let me know if this doesnt solve your problems
Posted on Oct 04, 2008
  • 145 Answers
SOURCE: Unbalanced Load Light
I don't know if this is a new washing machine or not, but I would recommend is getting a few small thin boards and making sure the machine is level. If this doesn't work there could be a bad sensor, but that doesn't seem like the case to me as moving the machine a little gets it to restart.
Posted on Apr 29, 2010
  • 909 Answers
SOURCE: Machine making loud noise on spins cycle
Well, the only time the washer (speedqueen) is noisy on spin is if one or both the bearings are faulty. Normally when you get a leak, it means the hub/flange and seal kit need replacement and this also includes the top bearing because when soap suds leak past the seal assembly it drips directly onto the bearing. The acidic properties in the soap suds eats the grease in the bearing which ends up becoming defective. One can also get an anoying squeek if a bottom base gasket is worn or removed. This would be audible even on wash cycle.Conclusion, check the bearing on top of gearbox.
Posted on Jul 21, 2010
SOURCE: My Speed Queen washer shakes and walks during the
Did you remove the shipping bolts from the back of the washer? They are located on the back, usually very clearly marked "REMOVE" and have a red or yellow plastic washer/bushing. This is a fairly common problem with front load washers, from what I understand.
They're big suckers, and they keep the drum suspension from absorbing any vibration (so the drum doesn't slam around during shipping). Good luck!
Posted on Mar 01, 2011
  • 1114 Answers
SOURCE: Speed Queen AWS51NW Top load Washer. Fills with
You will need to replace the cycle timer, or control board to resolve this issue.
Posted on Mar 21, 2011
Change time zones
Hold down the + button on front of unit until the time zone moves.Then let go when it reaches the correct time zone.
Jan 26, 2014 | Hammacher Schlemmer The R2-D2 Projection...
When I turn on the System is makes my R2 Sounds but doesn't fire up at all. The Blue Power light then turns Red...
Red ring of death?
If you did something to your x-box like a mod that microsoft doesn't allow or was detected when you connected to their on-line site it will render your x-box unusable until you take it to someone who can change your x-box back to the factory set up.
Oct 10, 2013 | Microsoft Xbox 360 Star Wars R2-D2 Limited...
R2 won't move forward on command
Have you checked to make sure his wheels are unlocked? Page 4 of the manual shows you where it is.
Feb 17, 2013 | Hasbro Star Wars R2 D2 Interactive...
On the front of the droid there is a red button that lights up when turned on & turns off after a couple of seconds, depress that button to free up the droid. Its called the wheel lock control button. That should free up your R2
Apr 15, 2012 | Hasbro Star Wars R2 D2 Interactive...
I install the software for my R2D2 wireless webcam but i get an error message. i have windows 7
1. Insert your installation disc for the R2-D2 Wireless Webcam (dont start it up or anything just insert it into your computer)2. Click "Home Button" on desktop
3. In the search bar type "compatibility" and click on "Run programs made for previous versions of windows"
4. Click Next and wait until it is done scanning.
5. Then select "not listed" (it is on the top) and click next.
6. Click "Browse" and click on "Computer" then under "Devices with Removable Storage" double-click the "R2-D2_0105" (it is easy to spot due to the R2-D2 next to the name).
7. Then click once on "R2D2MENU" and click "Open" (its next to cancel), then click "Next".
8. After it scans for a few seconds, double-click "Try recommended settings"and click "Start the program..." (when the permission pop-up appears click: Allow or yes. whichever one grants it access.) then once the menu is open click on "install Viewer/Driver and install everything.
9. when you are done, click "EXIT" and in the "Program Compatibility" window click "Next". Then click "Yes, save these setting for this program" and you are all done and it should work!
Apr 28, 2011 | Nikko Star Wars R2-D2 Web Cam and VOIP...
Interactive r2 d2 gets stuck
There could be something blocking the drive gears to the treaded wheels making making the robot go backwards.
Apr 28, 2009 | Hasbro Star Wars R2 D2 Interactive...
Speed Queen CTSA0AWN Front Load Washer Logo
54 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
