Question about Whirlpool Washing Machines
RCA Whirlpool Front load washer model GHW9150PW4 error code F06 Motor tries to start and makes noise and stops
  • 2 more comments
  • Ellendale6 Aug 02, 2008
    Tried reset did not work so I will try 2nd comment to test. But noise from motor is a concern.
    Ref: Front load RCA Whilpool GHW9150PW4 error code F06
    I found a couple of socks and junk between the door seal and tub. I think there might be a plastic or metal piece somewhere towards the back of the moving tub. I hear a noise toward the rear of tub? Could I take off the drain hose and reach inside or let it run and maybe it would fall our?
    How do i accept solution?
  • Ellendale6 Aug 03, 2008
    My friend and I took the drain hose and vent hose off and found a nail lodged in the tub. We were able to remove it with long nose plyers. The machine is running like new. By the way it is 2 years old.
    Thanks for your help
    Guru:
  • 1,894 Answers
Please try a hard reset by leaving the unit plugged off from the wall power for one night
the error code may vanish
also this seems to be like a motor starter problem
Posted on Aug 02, 2008
  • 4 more comments
  • dewan nafees ahmed Aug 02, 2008
    error code F06 means
    Drive Motor Tachometer Error
    The control is unable to properly
    detect motor speed and the machine will shut down. If a failure
    occurs during high-speed spin, the door will be unlocked after 3
    minutes.
    Check wire harness connections
    between the Drive Motor/Tachometer and the Motor Control Unit
    (MCU), and between the MCU and the Central Control Unit (CCU)
    Check the Drive Motor
    Check the MCU
    Check the Wire Harness
    You need to check connection from drive motor to motor control (circuit
    board located by motor). Then check connection from motor control to
    main control up top. Make sure wires have not come out of their
    harness. After that you need to do diagnostic. Set selector to
    drain&spin. Set option to no spin. press extra rinse 4 times. Make
    sure you do this right after you turn power on. Diagnostic should
    start. This will tell you if communication is ok with all components.
    minutes.
    Check the MCU
    i would suggest you to let it run for time being. see for 2 or 3 weeks.
    if it does not come out then you can move further.
    also please don't forget to accept the solution..
    thank you
    am not sure about it. but it seems there is some accept button on your side.
    why am not sure because i have never been on customer side even once.
    its ok. if you are not able to accept the solution leave it as it is. no problem.
    thank you for the cooperation.
  • dewan nafees ahmed Aug 03, 2008
    wow that is a very good news sir
    cheers..
    just see to that there is some place to accept my solution. if so i will get the credits immediately when you accept the solution. else i wlll be getting the credits after 7 days.
    thank you
What is error code F06
The "F06" fault code indicates a drive motor error. This means the control is unable to properly detect motor speed and the machine will shut down.
Mar 17, 2016 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet is showing error codes f06 and e02 and wont unlock door or run cycle, what can I do?
Janice,
Here is a link to a website that gives the F06 code, but I cannot find the other code.
http://www.appliancepartspros.com/repair-help/whirlpool-fault-codes.
Scroll down towards the bottom to find the Duet fault codes.
Jul 28, 2015 | Whirlpool WFW94HEX Duet 5.0 cu. ft. Front...
What does and F6 error code mean on a whirlpool duette front loading washing machine mean and how do I fix it?
Error code F06 means Drive motor tachometer error.
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
1/ Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
2/ Check the Drive Motor
3/ Check the MCU
4/ Check the Wire Harness
Replace failed component or contact an authorized repair agent.
Oct 15, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load washer, F06 error
FROM WHAT I CAN FIND OUT YOU HAVE A DRIVE MOTOR PROBLEM,
IF YOU TYPE IN YOUR SEARCH BOX (WHIRLPOOL FAULT CODE F06) there are several several sites that tell you how to fix it
Nov 25, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My front load has a f 6 code flashing
F06 is an error code that meansthat the control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Whirlpool Duet Front Loading Automatic Washer Fault Codes#ixzz1goJUbb8i
Dec 05, 2011 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
My maytag washer model MFW9600SQ0 has an F06 error code. It was previously vibrating during the spin cycle then the error code showed up. I took the back off and found one of the springs that the drum...
The F06 is a drive motor tachometer failure which means the motor control is not able to see the motor is running. This can be a difficult problem to pin down, but there are some things you can do yourself if you like. Check the connections between the motor control and motor. Also check connections on the central control are all tight. Push on all of the connections and see if there is any improvement. The images below will help with access on some Maytag front load washers.
Image 1
Image 2
Sep 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: i have a code it is f06 and then washer stops spin...
Drive Motor Tachometer Error. The control is unable to properly detect motor speed and the washer will shut down.If a failure occurs during high-speed spin the door will be unlocked after 3 minuts. Check wireharness connections between the drive motor/Techometer and the motor control unit also check between the motor control unit and the central control unit. Check the drive motor, the motor control unit, and wire harness.
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F06 error with a ghw9150pw4 model whirlpool front loader washer
HI There
Here what you need on error codes.
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the MCU
Hope this helps let me know. Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL GHW9150PW4 DUET WASHER DOESN'T SPIN AFTER START
F/06 Drive Motor Tachometer Error
  • Check the MCU
Mar 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
140 people viewed this question
Dan Webster
Dan Webster
Sal De
