There is no compression in the clutch pedal also the motor runs okay but it wont engage the transmission
    Brigadier General:
  • 10,406 Answers
The mechanical linkage between the clutch-pedal and the actual clutch is not working.
Get the vehicle towed to a mechanic, for proper repair.
Posted on Mar 17, 2011
CLUTCH ON CITROEN C2 KEEPS DROPPING TO FLOOR AND WHINING SOUND WHEN MOTOR IS RUNNING
It jump because the clutch disc itself is good, but the clutch is not engaging-the pedal is not making the clutch engage. When it does, then you can shift without grinding, then you can shift period. Clutch pedal operates a cable or it operates a hydraulic system-they both, which ever one you have, move the clutch fork on the transmission bell housing just a bit to cause the clutch to disengage the transmission from the engine's flywheel...so you can shift, see, easy, smooth shifts, no problem, no grinding. Your clutch itself is okay, the pedal is just not operating it.
Dec 26, 2013 | Cars & Trucks
Clutch not engaging
Well, it would shift easily with engine off, because the transmission input shaft is not turning. Engine running and clutch engaging good, the input shaft would again be stationary and allow smooth shifting.
What you have to determine is if the clutch disc or pressure plate is bad (a new clutch is needed), or if the pedal hydraulic system has a malfunction. When you push the pedal down, a rod from the top of pedal pushes into the clutch master cylinder bolted to the firewall under the hood. This cylinder has a reservoir filled with brake fluid. When the rod forces fluid from the clutch master down a steel line and into the clutch slave cylinder down on the transmission bell housing, the hydraulic pressure forces a plunger from the slave cylinder to extend and push the clutch fork lever a small amount, enough to force the clutch release bearing (aka throw-out bearing) against the pressure plate. This relieves pressure on the clutch disc and input shaft becomes stationary for easy shifting.
Jul 26, 2013 | 2000 Chevrolet Blazer
96 ford 4.9 5 speed hydrolich clutch wont shift all of a sudden new master cylinder
You have a leak and you have air in the system. More than likely the slave cylinder is leaking, the slave is a direct acting one and as with all direct acting slave cylinder it is located inside the transmission bell housing on the transmission input shaft collar. The transmission must be removed to replace it.
Jun 23, 2012 | Ford F150 Cars & Trucks
Poulan riding mower stalls when I release the clutch
there is other safety switches on the pedal and on the pto
Apr 03, 2012 | Garden
5 speed 1990 toyota 4wd,my transmission wont engage to first gear or reverse when engine is running but will in engage when engine is turn off
Sounds like the clutch is not releasing properly. If it grinds when trying to delect reverse this will be the case. It may be a hydrolic fault or the clutch itself. Check to see if the slave cylinder rod is actuating when the pedal is depressed.Check for loss of fluid.
Feb 22, 2011 | Toyota Pickup Cars & Trucks
1997 dodge ram 3500 with manual transmission. truck wont start with clutch engaged
Under the dash where the clutch pedal exits the cabin at the clutch master cylinder, you will see a two pronged plug. Unplug it and run a a small piece of wire from one side of the plug to the other.
CAUTION: THE VEHICLE WILL NOW START WITHOUT ENGAGING THE CLUTCH PEDAL AND WHILE IN GEAR!
I hope I've answered your question. If so please rate my assistance and leave a testimonial.
Dec 28, 2010 | 2000 Dodge Ram 3500
When i push my clutch pedal down the starter engages, what is the cause of this?
Hi!!
The clutch switch is designed to prevent vehicle from accidentally engage the starter unless the clutch pedal is depressed. (It is the equivalent to the Neutral Safety Switch for automatic transmissions.)
Pressing the clutch pedal by itself will NOT activate the starter unless the key is in the RUN position.
Check your ignition switch. it may be stuck on RUN.
Don't forget to rate this post. Good Luck!!
Jul 06, 2010 | 1993 Ford Escort 4 Door
As soon as i turn it on, the needle starts moving up and down even though i don;t have my foot on the pedal at all.
as you turn on the motor starts running. but when you press pedal there is a clutch that engages. probably the clutch keeps engaged. clutch needs to be set to engage on pressing pedal only.
Nov 06, 2009 | Singer Sewing Machines
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
