Yesterday my ge wcvh626ohww washer was running through a spin cycle and I heard a (excuse my noise descriptions) thump like something broke loose, and it sounded like the drum was spinning very unusually freely. Today I tried to do a load and as I passed by the washer I smelt a burning rubber smell. When I opened up the front door, smoke billowed out of washer and all clothes smelt of smoke. I wasn't able to address problem immediately, because I had to go to work. When my wife took clothes out of washer she found a thin foot long piece of rubber along with clothers. I am a plumber and pretty handy if you my description rings a bell as to what my problem could be, maybe you could advise me how to fix it. Thanks.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 23 Answers
Hi,I've seen that problem plenty of times. That rubber strip is from the door boot rubbing the inner tub while spinning. First thing you need to do is check that drum. Using your fingertips push up, looking for any movement. Rotate the drum a few inches and push up again till you've gone all the way around. If you hear a clicking or a clunk that tells you the weld of the drum is broken. Check your owners manual for warranty, stainless steel drums are usually a lifetime guarantee. It's also possible that something got caught between the inner and outer causing the inner tub to go out of round. That would also cause the problem, which would mean the tub needs to be replaced or it will do the same thing again. If you don't find a problem with the drum then the door boot probably got torn and pulled into the spinning tub and an be replaced without fear of the problem reoccurring. Hope that helps.
Posted on May 08, 2017
    Problem Solver:
  • 6 Answers
I don't have experience with this particular machine but it sounds like it might be the drive belt. The following website might shed some light,... has videos. There are also sites which show parts diagrams.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/38-3-862537-/GE-Washer-won-t-spin-WCVH6800J1WW
Hope this helps a bit.
Posted on May 05, 2017
  • 87 Answers
SOURCE: Whirlpool Thin Twin Stopped Spinning at End of Cycle, H20 Will Not Drain
You have a sock caught in the pump, need to pull off outer case and remove pump and clear it out.
Posted on Jun 08, 2007
  • 9 Answers
SOURCE: Washer emitting burning smell and smoke on fast spin
Yes, the heating element is coming on when it shouldn't. A likely cause is the pressure pot (Level sensor sender unit) being blocked with sludge. You'll find this under the machine, either screwed to the RH side of the tub, near to the front of the machine secured by three Philips screws, or attached to the side of the big hose that goes from the tub to the pump,secured by a Jubilee clip, underneath the machine. disconnect the power and remove the pressure pot, in both cases it's a long rigid white plastic tube, from one end of which comes a narrow flexible plastic hose which goes up to the top of the cabinet and is attached to the pressure switch itself. This tube is likely to have a load of muck in it, as its bottom end. Clean this out, and if your element didn't burn out, then everything should now be fine.
Posted on Sep 14, 2007
  • 1314 Answers
SOURCE: Kenmore (Whirlpool) washer 110.20912 991 made banging noise at end of spin cycle. Now it wont spin at all.
i need to chat with you email me at b4829@yahoo.com need more info
Posted on Jan 01, 2008
SOURCE: frigidaire front load washer model LTF530DS loose drum
I have the same issue with the broken spider...in the us and they say it is $300 for labor and $360 for parts. My washer is only 3+ years old...what can I do?
Posted on Aug 07, 2008
mumma_1
  • 903 Answers
SOURCE: burning smell and washer will not spin
The buring smell could be coming from the belt, try looking to see if the belt i burnt or broken
Posted on Nov 22, 2008
Scraping, thumping, and whining sound as the washer drum spins. sounds like something may be loose inside. sounds like a loose belt squeeling?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
May 19, 2011 | Frigidaire Washing Machines
I have a GE front-loading washer. There is a horrible thumping noise as the drum turns. It is not constant - when I turn it by hand it seems to "thump" on every rotation of the drum. I ran it...
The thumping sound is a sure sign that the spider arms or the support arms that hold the wash drum are broken. It is a very expensive repair since you need to buy a replacement wash drum and spider arm assembly which almost cost as much as new washer. Get a few estimates before deciding whether to repair or replace the washer. Sorry.
Apr 23, 2011 | GE WSXH208A Front Load Washer
Tub broke loose from washer and is hitting the side. Can this be fixed, if so how much, can I do it myself
Had similar problem, finally found the problem. The tub is mounted with three bolts located just above the springs to the frame. One bolt was missing. Replaced the bolt. I had a terrible thump thump shaking the house spin cycle. Took the tub out and cleaned the filter too. Now the spin cycle works like it should and the tub drains faster too. This filter is a good spot to find a lost diamond. Or in my case a few sequins.
Dec 01, 2010 | GE Washing Machines
The washer shakes uncontrollably during the spin cycle also a loud banging noise is heard during the spin cycle.....
If front load check the inner drum If it is loose at all you have a lot of problem . Very expensive.
Nov 17, 2010 | GE Washing Machines
My roper top loading washer agiatates and spins out the water, however, when it finishes the spin cycle it makes a thump thump thump sound for about 8-10 secs. It is like it is trying to stop but is...
Hi, Welcome to FixYa.
Based on your description this is what it sounds like. 1) The basket drive block has worn or come loose and the spin tub from the basket drive is "clunking" as it skips by the notches in the block. 2) The basket drive spin tub may have broke from the hub/base or both are worn as a result of prolonged "thump, thump, thumping". Hopefully the prior not the later. **Unplug the washer from the wall before attempting any DIY service/repairs...safety first** You'll need to remove the agitator, (the cap) and then the 9/16" or 1/2" or possibly a 7/16" bolt in the center...it may look nothing like a bolt, it may be a plastic block but it still screws off counter-clockwise.
Pull the agitator and inspect the block/hub in the center directly below the agitator which holds the basket in place. if it looks worn or is out of place, you'll likely need a tech.
If you can tackle it yourself, the block number is #389140. You want to be sure the spin tube still has the two notches in it though, otherwise the changing of the block will be futile.
Check that, and let me know how it goes and what you find.
Good Luck macmarkus :)
Aug 01, 2010 | Roper RAS8445KQ Top Load Washer
Washer making loud noise and wont spin
Check and see if the inner drum is loose and floppy.if it is, it's likely the bearings have collapsed, and require replacement...If the drum feels stiff and tight, it could be that something is jammed between the inner and outer drums. Both situations could be costly...Get quotes....Good luck...Nomess
May 22, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Loose washer drum, load noise on spin cycle
your basket hub is stripped and to gain has a specific tool to remove and not destroy the locking nut for basket the agitor and items need to be removed it may be best to call a tech in your area
Sep 01, 2009 | Kenmore Washing Machines
Loud noise when aggitating code says motor not rotating properly
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
or something stuck up in spinning motor assembly.
thanks and plse do not forget to accept the solution.
Apr 02, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Loud clicking/thumping in rinse and spin cycle
It doesn't look like a motor problem !!! It seems like an unbalanced tub issue. The machin has suspension dampers and suspension rods, and it's look like one of them was damaged or "run away" from its location during machin's movement. Goog luck !!
Jun 14, 2006 | GE Profile Prodigy WPSE4200A
Washer makes loud thumping after finished spin cycle
I replaced the drive block and it solved my problem. (thumping noise at the end of spin cycle) Easy repair. Videos on utube show all the steps.
Jun 07, 2006 | Whirlpool LSR7333 Top Load Washer
Washing Machines Logo
116 people viewed this question
Top Washing Machines Experts
