Question about Craftsman Air Tools & Compressors
Have a sears model 919.155190 air spray gun and the paint doesn't come out, (water base) also need a manual for it
SOURCE: problem spray painting water based paint
I spoke to a friend who was a spraypainter in his last job, apparently due to the thickness of the paint, I needed a larger nozzle on the gun. I couldnt get a nozzle to suit this gun so I purchased another gun with a cuple of different size nozzles. All seems to be working fine now.
Posted on Nov 20, 2008
  • 3 Answers
SOURCE: IR 210g - using thicker paint
thinning the paint is always best,but some gun manufacturers dont put on an air cap recommended for latex paint try using an air cap with biggers holes this will allow the paint to flow through better.It could be that the air cap you use now has to small of holes for the paint to flow through.
Posted on Dec 18, 2008
  • 35 Answers
SOURCE: Spray painting operation advice for Binks mach 1 hvlp spray gun
Hey paul its paul. I posted on here so hopefully you will give me some feedback. That is a very nice gun. One of my favorite. I'm guessing you know how to use a HVLP gun but if not here are a few tips. Make sure it is clean. Very clean. Your gun probably came with a manual, you should read it. It will help you greatly. First off, you want to have a regulator, about 40 psi is what i start with. You need a space you can practice some painting before laying down a new coat on the corvette. Haha. So next you will have a pressure adjustment knob, you want to start with this all the way closed and with the trigger pulled, just half way so just air is coming out adjust the air until it sounds even. Next you can try to spray. If it seems like the Fan, like the width is not enough you can adjust the fan, another knob, closer to the back of the gun, you ussually want about 5-6 inches of fan, if you are spraying at the normal 6-8 inches back from the piece. Last adjustment is the fluid adjustment, you want to put on a decent amount of paint, clear or primer, and not cause runs. This is going to take some practice because everyone moves at a different speed.
So you are going to have to play with your gun and figure out which knob does what. After that these instructions should get you a bit further, with some practice you will be laying down a nice paint job in no time.
Paul.
Posted on Feb 26, 2009
  • 86 Answers
SOURCE: spray gun for water and air
You can buy them here for about $22 US.:
http://www.detailyourcar.com/airwater-guns-and-hose-c-51.html
They're used for detailing cars, if you don't like these, Google "air water guns"
Posted on Mar 08, 2009
SOURCE: Hello, the gun has been
again you have to change the fluid nozzle it help me with my spray gun
Posted on Oct 22, 2010
Won't spray
There are a lot of variables while airbrushing. If you are having trouble with a new airbrush(or one that isn't hugely gunked up) you likely need to do 1 or both of the following to get it to spray the paint:
1) Thin your paint, use the correct medium based on the paint type. Water can be used to thin water-based paints but too much will result in a bad coat and finish. You are looking for a milk-slightly thicker than milker consistency.
2) Crank up the air through the airbrush. Assuming you have a regulator you may need to turn the pressure up to get thicker paints to spray. If you are using a siphon feed you may need a couple extra PSI to recoup for what you are losing from the syphon. Make sure to check the max pressure your airbrush can handle before cranking it too high(most can handle at least 30 PSI).
Hope this helps.
Jan 23, 2013 | Airbrush-Depot Master Airbrush Model G23...
In trying to spray oil base paint, I get very low fluid flow (if any) from the cup to the gun. I've cleaned the gun and insured the hoses weren't clogged. Changing the adjustment valves...
How does it spray if you dump the paint out and put paint thinner in the cup? If it sprays paint thinnner, but not the paint, your paint is too thick. Thin it down by 25% and try a little. Keep adding thinner until the paint sprays out of the gun in an acceptable manner. Your gun probably has a 1.1,or 1.4 fluid tip. this is for spraying lacquers or automotive paints that are very thin. to spray oil based paint, your would need a 2.0 or 2.5 or bigger. not really what this gun was made to spray.
Jul 20, 2011 | Binks Hvlp Spray Gravity Gun With 1 Liter...
On a Campbell Hausfeld DH5030 spray gun, there is a screw valve at the base of the unit with arrows labeled S and P for turning clockwise and counterclockwise, respectively. What is this for?
The "P" stands for pressure feed. turning it completly to this side forces air into the cup pushing the paint out.
The "S" is for siphon feed where the air through the tip sucks paint from the cup.
If your using thin materials like lacquers or polyurethane or solvent based enamels the siphon feed is used.
If your using thicker materials like water based latex or heavy stains then go with the pressure setting.
You can always go in between for some pressure with the siphon action....depends on coatings used.
Jun 22, 2011 | Campbell Hausfeld DH5300 General Purpose...
Spraying kitchen cabinet doors 40 degree weather airless graco sprayer enamel water base paint at first finish is great then bubbles start to form
first problem is the waterbase paints ( ****) the other is how did you mix your paint , you cam trap air in the paint if you padle or stired it without a shaker mixer air will gas out of the paint, tofix this use a foam brush to flaten air bubbles
Jan 23, 2011 | Air Tools & Compressors
What is the correct concistancy the paint needs to be mixed at for the dynatec psg 45 electric spray gun
It depends on 3 things.
What you are painting.
Whether you are applying latex, oil-base, or primer.
What size TIP you are using.
We use spray equipment and use size 17 and 19 for latex, and 11 for oil.
Double-check the size that came with your gun and look at tips at Home Depot.
Old tips wallow out and the spray pattern is irregular/uneven and the gun blows out too much paint and our material costs go up.
The manual says "dilute correspondingly"
http://www.airless.com.au/Airless%20Sprayer.pdf
Let's say you are spraying oil-base stain: I would NOT dillute this material.
Oil-base primer: 1 thinner to 4 paint
Latex primer: use a roller and brush so you have a good undercoat for the paint.
Oil-base paint: I would add 1/8 thinner with 1 paint, and be careful of runs
Latex stain: try 1 water to 4 stain
Cheap interior flat latex: 1 water to 4 paint
Latex semi-gloss interior: 1-1/8 to 4 paint and apply very thin coats and let dry between coats.
Cheap exterior flat latex: 1+ to 4 paint, and add more or less water as needed
Good exterior latex paint: use a roller and brush because the purpose of latex exterior pain is to apply heavy protective coat over outdoor materials ... dilluted exterior latex will not give sun and mildew protection.
We use heavy spray equipment and apply exterior latex straight form the can. It's the only way to give lasting job, unless you're doing a temporary playhouse.
The key to successful spraying is to strain your paint to get out the lump and clogs - BEFORE putting paint into the gun.
We always strain the paint unless it's a freshly opened can.
If can was opened yesterday, we strain it.
That because paint gets a dry film that will clog the sprayer.
First you need to mix your material, so you need a couple buckets.
Pour the paint and thinning material in 1 bucket, and then to mix, pour back and forth between two or three buckets. This action will mix the paint thoroughly and save you an hour of rotating a paint stir stick.
Next, you need to strain the paint.
Wash out a 5-gallon bucket.
Buy 5 gallon strainer that fits into bucket.
Pour material into bucket with strainer, lift strainer up and then grab end of strainer and squeeze out all the paint.
Immediately put lid over paint so no drying film will form.
Wash out strainer.
You're ready to put paint in spray gun.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on paint project.
Jan 06, 2011 | Garden
Can I use my Kirby Spray Gun for coating a paint over the wooden items like windows, wooden shelters etc.?
It can be used, but be sure to use a water based, non-flammable paint or stain. Blow the dust out of the hose before attaching the spray gun.
Sep 01, 2010 | NRS KIRBY UG/DE&G3 SPRAY GUN ASSEMBLY
Porter cable spray painter PSH1 it says what you can spray with it and I want to spray water base paint can I do it with this painter it is new and I didn't relize it was onl for laciur paint thank you...
Be sure to filter the paint you are trying to use so that you aren't dealing with large lumps of paint. You will need to experiment with hose pressure to get proper spray quality, and set the mixture control for a fairly fine mist as the paint is likely to be more fluid. Fan control is set so that you don't get an unpainted space in the middle of the paint swath. Make sure to wash the gun thoroughly after painting. If you are doing a lot of painting, expect some nozzle wear over time as the water base paint is somewhat gritty. Don't forget to trigger 'off' before the end of each stroke and trigger 'on' after starting the return stroke to keep running at a minimum. Good luck!
Jun 19, 2010 | Porter Cable Cable PSH1 HVLP Gravity Feed...
Problem spray painting water based paint
Nov 19, 2008 | Air Tools & Compressors
i dont have so much as a solution as a couple of things you can try to figure out whats going wrong.
make sure your compressor can handle 10.5 CFM @ 50psi
hook up the gun and dry spray it to check for blockages in the air supply
if the air comes through strong and constant, fill the paint hopper with water and spray until empty
if the water comes through constant, add half of the hopper with paint thinned with penetrol or floetrol
if the paint is coming out weak or spotty, make sure the vent cap is open on the paint hopper
if the cap on the hopper doesnt have a vent, try spraying with the cap off or cracked a bit.
if that doesnt work take off the hopper and check the filter for blockages.
i suggest straining all your paint before pouring it into the hopper
Nov 19, 2008 | Ingersoll Rand Hvlp Automotive Spray Gun
Air Tools & Compressors Logo
136 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
