Question about Sony Car Audio & Video
Sony XPlode Amp XM-2150GSX, whats setoff sensor mean? Amp keeps cutting out!
  • 902 Answers
You have a short or your over heating. or more lkely bad ground or you bridged your subs and you should not have that what will give you those erros. OH most common tho is the remote cable from the cd player is loose or the rca cables are loose.
Posted on Mar 17, 2011
Have mex bt2600 sony xplode car cd player ::: also have sony xplode amp model no.xm 754sx problem is i want to hook up a subwoofer and the amp to the head unit (also currently have 2 sony xplode 3ways...
If the Sony front end unit (stereo) has RCA jacks (Left and Right) in the back it's an input to the Xplode amp. If that's right then the Subwoofer putputs should plug or wire into the Xplode amp. I haven't hooked these up for some time but try a search on Youtube with the units you describe I'm more than 90% sure that there are videos there.
Nov 19, 2017 | Sony MEX-BT2600 Car CD/ MP3 Player
Overcurrent lights comes on whenever my amp is on
this can only mean 2 things, either your over working the amp, which means your amp is trying to push power that it don't have, and it's getting hot which is known as thermal mode. and the other reason can be that make sure amp rms. matches the rms. of your subs.
Mar 13, 2010 | Sony XM-2150GSX Car Audio Amplifier
I have Sony XM-2150GSX amp on offset cant get it off
check for a short on one of the edges or a resistor on the edge of the board
Jul 04, 2009 | Sony XM-2150GSX Car Audio Amplifier
Keeps shutting off at the lowest volume setting.
Check the switch wire connection. It's the one that turns the amp on when you turn the head unit on.
Jun 02, 2009 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Wiring 2 diamond crossovers into a sony xplode amp & cd player
The crossover wires have absolutely nothing to do with your cd player, all you do is wire your crossovers into the speaker slots on the amp and then wire your mid-range speakers and tweaters into the crossovers. All a crossover does is it splits the power from the amp to your mid-range speakers and your tweaters.
Aug 13, 2007 | Sony XM-2150GSX Car Audio Amplifier
My sony xplod XM-2150GSX amp has a problen whenever i turn up the volume on my radio the amp turns on the current overload LED cAN enybody help me out i opened it but i just cant seem to find the problen...
Often this is related to speaker wiring. Make sure your speakers aren't below the minimum rated impedance for your amplifier; 2 ohms per channel, or minimum 4 ohms in bridged mode. If you have two 4-ohm subs, you can't run them both in bridged mode if they're wired in parallel. If you have a blown sub, it can cause this problem also.
Jul 30, 2007 | Sony XM-2150GSX Car Audio Amplifier
Amp overcurrent problem
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down (overcurrent), the amp likely has blown output transistors.
Sep 20, 2006 | Sony XM-2150GSX Car Audio Amplifier
Car Audio & Video Logo
53 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
