Question about LG KU990 Viewty
I have a Treo p700.I am on my second phone because of sync problems with the first. Now, after a period of time without sync. problems failure to sync has started again. I use a Imacg5 with 10.5.4 software.I tried to fix my sync problems with sync help on the web,but this failed.your help would be appreciated.
  • sail477 Aug 04, 2008
    I do not find your help process very useful.
    Based on this experience,I would like you to reimburse my payment.
    Guru:
  • 1,894 Answers
Please update your firmware to clear any software problems with the phone.
that may work.
Posted on Aug 02, 2008
  • 2,071 Answers
PDA Sync Problems and Tips
After several days, weeks, months of successful syncs one day your pda just will not sync. You remove activesync, and reinstall and still no sync. You check device manager, remove the com port driver reboot reinstall and still no sync. This is actually a common problem, but it's not documented. Windows by default will increment the com port assignment each time it detects a new device. It does so automatically via plug and play interface. So if you see your outgoing or incoming port assignments in device manager listed with any number above 8, then your pda will not sync. Most ipaq's (and other windows mobile based pda's) sync with a windows pc but you must use a com port assignment below port 9. Also this might sound a little confusing at first, because most pda's are connected via the usb port. But note that the actual com port assignment is virtual and basically used as the interface. It has nothing to do on how your pda is physically connected. Meaning the tip here works if you are connected via serial, usb, bluetooth or even via wi-fi link. Simply removing the com port doesn't work, because as already stated windows will increment the port number each time a new device is added. Which is in essense what you are doing when you remove a com port entry, and try to reinstall your pda.
The solution is simple, select any communications port number under port 9, and you will have no problems.
To change the com port assignment do this: Right click on my computer, properties, then right click over com port 9(or whatever new com port windows just assigned to your pda) and select properties, click on port settings tab, then advanced. On the bottom of this screen use the drop down menu to assign it a different number. Remember it must be under 9. Just as long no other device is using that number then you'll be fine.
hope this may help;
Regards,
VOTIT
  • 6,487 Answers
Did you try using some kind of software to sync your unit??
Palm treo keeps turning off
this is caused by a software conflict do you sync you device? if so it can be something your syncing over to the phone from your computer you want to sync over just your contacts then tasks, and media items. if you do not sync you device then i would suggest backing it up and doing a hard reset on it because the powercyling is due to a software failure
Apr 02, 2010 | Palm Treo Pro Smartphone
Can I sync 2 phones on the same computer w/o sharing information?
Sure you can. You just have to pick a unique ID for his during the first sync. If he already has an ID, then there is no problem. If you want to change any ID easily, get changename. It's an easy ID changer. For more info, great tips and discussion of and accessories for the Treo, goto mytreo.net
Ken
Dec 06, 2008 | Palm Treo 755p Smartphone
Hot sync
Get a different phone because if you had trouble with the first and second, chances are if you get another one it's going to be a lemon.
Aug 02, 2008 | Apple iMac G5 Desktop
Treo 750 p
Personally 10 to 15 minutes is not normal, I have had my 755p battery get hot after a couple of hours of straight talking, but not right away.
I would just take it back where you got it and tell them the problem that you are having and get another Treo. I have owned all of the Treo's ever made and they make great phones.
It does take some getting used to but the pros vs the cons of owning a Treo are much greater. Blackberry has come along way with their phones and if you are used to the Blackberry then the Treo just might not be the phone for you.
To get back to your question if the phone getting hot is normal, no, but it will happen from time to time when talking on the phone for long periods of time.
Hope this helps,
Glenn
Jun 20, 2008 | Palm Treo 755p Smartphone
Double entries in Palm and Outlook
The closest I have come has been from a firmware update for the Palm phone. After the update, the phone saw my original contact list and created a second contact list from what was present in the Palm calendar.
If you have changed firmware and this issue started happening, you'll need to delete the duplicates in Outlook or it will continue to try and update/save them. Also, this is most likely why your sync sessions are taking more time...the phone is trying to read the different entries already present in outlook, and it is taking time to default when it cannot open the entries. Multiply that time by 4 or 5 times per entry and you have a very long sync session.
Hope this works for you!
Apr 02, 2008 | Palm Treo 650 Handheld
MY TREO 650 KEEPS TRYING TO HOTSYNC(and its not connected to computer)
Did it actually reset when you did a hard reset ..or does it stay powered up?
Dec 31, 2007 | Palm Treo 680 Smartphone
Unable to place a call or receive a call on treo 650
May I know since when the problem occur and what's happen if you tap phone application?
Nov 07, 2007 | Palm Treo 650 Handheld
Syncing of palm times out
this is producers mistake :(
Sep 23, 2007 | Palm Treo 750 Smartphone
Palm treo call log
Purge call log.
That's it!
Cant get to call log without it shutting down?
Call your self, leave message, then hang up. Then get to call log from there.
Tap upper left corner I think under file and find purge.
found out how to do that in the Treo book and on this website together. My wife got a new Treo phone out of it though thinking it was broken. Even the "techs" had not a clue. They could have looked online.-Found this site in 8 minutes.
Aug 15, 2007 | Palm Treo 600 Handheld
Treo 650 Sync w/ Outlook 2003
Please try the following: 1. Pop the Software Installation disk that came with your treo into your pc and allow it to autoplay. 2. After the disk begins playing, you will be prompted to choose your language-do so. 3. After a second a new dialog box will appear-Select the option "Change your syncronization method" 4. Select "Use Microsoft Outlook to manage Calendar, contacts, tasks and more. 5. Perform a hotsync 6. Open your versamail and hit the sync button
Sep 19, 2005 | Palm Treo 650 Handheld
LG KU990 Viewty Logo
171 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
