Question about Acer Intel VGA Driver.zip
Vga 800x600 resolution...where to download KOB845Gx vga driver,s
  • 39 Answers
  • Acer Master
  • 3,606 Answers
This is probably a mercury mainboard you have.
Try finding the driver here:
http://www.mercury-pc.com/download/uploaded/drivers/
Unzip the file before you install it.
Try to seach for the 845 chipset vga driver.
There is an another posibility install a agp graphic card in the socket on the mainboard. Just make sure you have the driver for it.
Good luck
Posted on Nov 20, 2012
Have male vga w/audio cord. computer says it doesnt support the setting is this true.
What resolution is your laptop using, e.g., 640x480, 800x600, 1024x768, 1280*1024, 1400*1050 ?
What manufacturer/model-number of VGA display?
What resolution(s) does it support?
Choose a lower resolution on your laptop, to see if the VGA display can handle that resolution.
Jun 08, 2011 | Computers & Internet
Can I increase the screen resolution on my EV700B monitor higher than 800x600? How?
Open Control Panel - Display - Settings tab - Screen Resolution move the slider to the right to increase the screen resolution.
If you cannot increase the screen resolution, it means the correct video driver was not installed generic VGA driver was installed.
In this case install the video driver for your graphics card and change the screen resolution.
Apr 14, 2011 | Gateway EV 700 17" CRT Monitor
I am using ubuntu 10.04 linux operating system ,but it,s screen resolution is not good .is there any possibility to download and install any vga drivers to get better resolution
Go to System, on the top bar, then Preferences and select Monitors.
On the Monitor Preference screen there will be different resolution settings that you can choose.
If there are any resolution settings higher than 800X600 like 1024X768 etc. select it and apply.
If there is no other settings available go to System then Administration and select Additional driver.
When the Additional drivers screen appears check if it recommends a a driver to be downloaded.
If it does, download the driver and then you will be able to get higher screen resolutions.
If there is no additional driver to download it gets a bit tricky.
You will need to edit your /etc/X11/xorg.conf file.
The file will look someting like this:
Section "Monitor"
Identifier "Philips 190S"
ModeLine "1280x1024" 108.0 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync
Option "PreferredMode" "1280x1024"
Option "DPMS"
HorizSync 30-82
VertRefresh 56-76
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Philips 190S"
Device "Default Device"
DefaultDepth 24
SubSection "Display"
Depth 8
Modes "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480"
EndSubSection
Depth 24
EndSubSection
EndSection
Section "Module"
Load "glx"
EndSection
Section "Device"
Identifier "Default Device"
Driver "nvidia"
Option "NoLogo" "True"
EndSection
It will be wise to make a backup of this file if you are going to edit it. (xorg.conf.old)
Inside the file you will see your screen and its resolution. (Preferred mode)
You need to change the resolution, save the file and restart your session.
If all went well your resolution will be set to what you specified, if your display freaks out replace the xorg.conf file with the xorg.conf.old file.
Hope one of these options solves your problem!
Regards
Nov 28, 2010 | Vga (CAT5-1000S/R) (EXTCAT51000)
Hi, Monitor is acer x193hql 18". Have just reformatted my HDD and installed XP (Was XP previously) Resolution now seems to be stuck at 800x600. Have tried Control...
So you say you formatted hey? This seems to be a problem with the GPU (Graphics Processing Unit) and not the monitor itself. Try re-installig and VGA drivers for your graphics card, if you are using on-board graphics, then install the VGA drivers that came with the motherboard.
Nov 15, 2010 | Acer AL1916W 19" LCD Monitor
FPD1960 TFT LCD Monitor that turns on and you see the Windows Screen, and then goes black. Each time I turn it off and then back on, it repeats this pattern. All cables are securely fastened, I am using...
Windows is using a video mode the LCD monitor can't display. The cable doesn't matter in this case. It's an issue of the refresh rate and the resolution set in the system.
When the system boots, hit F8 just before the Windows splash screen would come up. Start the computer in safe mode with networking support. It should be able to come up in safe mode because the resolution will go to 640x480 or 800x600 by default.
Once you get to the desktop, go under the desktop properties. Hit Advanced. then go under the monitor tab. Make sure the monitor is defined. If it says generic display it will give you resolutions and refresh rates you can't use. If it isn't defined, you can install the driver under properties.
Finally, set the default resolution to something easy like 800x600 and try the refresh around 60-65hrz.
Jun 16, 2010 | Gateway FPD1960 19" Flat Panel LCD Monitor
Resolution issue. Need hack.
use the F8 menu, select ENABLE VGA MODE that will force a 640 x 480 resolution for that boot.
Dec 03, 2009 | Samsung SyncMaster 793MB 17" CRT Monitor
KOB845Gx
Try thsi website. If not tell em and I will continue to use my resorces.
RCF
vhttp://www.drivers-software-download.org/tag/toshiba-kob845gx
Sep 06, 2008 | Computers & Internet
Screen goes black then says VGA then says No connection
1. Video Driver (download the latest video driver for the video maker)
2. Wrong resolution is being used. try step 3
3. Use a lower one 800x600 or 640x480
4. Monitor can't handle the Video Card set to the max try step 3
5. Video Card is faulty (replace it)
Aug 02, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
1,590 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
