My you tube screen when in min. is to small to see, how can i fix it?
  • 512 Answers
Please check if you don't have too low resolution settings at your video adapter.
Posted on Mar 17, 2011
How do i fix my home heater, fired it up, ran for about 3-5 min. But never fired up. Replaced bad pressure switch, n heater venting tubing!
If you have a code indicating pressure switch thid is 50% of the time the barbed port on the induced draft assembly where the pressure switches tubing connects. Carbon builds up in this port requiring reaming, I use a small drill bit and insure I can feel, sense the blower wheel to insure it is clear, it is easy to be fooled as the carbon is tough at times.
If this is not it you have a bad board assuming the pressure switch is closing and opening as it should which can be determined by using an ohmmeter. or voltmeter.
Will it run without the new tubing you installed?
Nov 02, 2013 | Heating & Cooling
I have a empire corcho r-115 pilot is real little and shuts off after 5 min. and see flame under pilot
You have a leak on the pilot tube under the pilot hence the small pilot .
leak needs to be fixed you maybe albe to tighten the pilot suppy to stop the leak and also clean the pilot .
Mar 05, 2012 | Heating & Cooling
My heater would run for ten mins at a time the other day. today it will only run for like two mins every time. Its only been used like ten times.Ive cleaned the nozzle the cover on back of motor. I cant...
Travis, If you have a R60 you can find the fuel filter in the bottom of the pickup tube. Pull the pickup tube out of the fuel tank, then take a small screw driver and pop the small cone shaped fuel screen out. I take either carb and choke cleaner or brake cleaner and spray it out then blow out with compressed air. I'm having trouble with mine also, and I had to turn down fuel pressure (fuel pressure on R60 is suppose to be 3.4psi) but I don't have a fuel pressure gauge that goes that low!! Go to DESA TECH.com they have a lot of good info there. Hope this helps you out!!!
Dec 21, 2010 | Reddy Heater 60,000 BTU Kerosene...
I recently dropped my Averatec laptop and the screen went dark. The computer still works and functions otherwise (including the sound), except for the screen being almost black. If I shine a flashlight...
The majority of LCD screens, with exception of the latest models, use a thin fluorescent tube (or tubes) to provide a back-light for the image you can still see. This is a very fragile tube(s) of small diameter and are powered via a small, narrow board that produces the high voltage needed to ionize. Either the tube(s) or the inverter for them is damaged.
If it is the tube, these are not costly but very fragile and often have soldered leads on their ends which requires some careful soldering to install them.
Nov 23, 2010 | Averatec 3200 Notebook
TV Sony is working for 3 min., after screen is
Get a check of your picture tube. It may have been destroyed. If yes get it replaced. P.S: Older picture tubes are of great quality compared to new ones.
Apr 21, 2010 | Sony KV-35S45 35" TV
There is no visual image on the screen and the green light
Sounds like your tube is out. Unplug your TV for 10 min's and plug it back in. Now try to turn it on. Wait a min. or two. try to push the menu button on the screen to see if it will come up.
check the small things first like cables and inputs. If it is still not showing anyhting............time to buy a new tv as a repair would be expensive.
Hope I helped
Mar 16, 2010 | Daewoo Televison & Video
Sony 65 inch screen tv
The lines you saw, i;m sure they are the ones called retrace lines but know the failure could be located on the red CRT board. Most likely the video amplifier is defective and not necessarily the CRT.
What is the model number of your TV?
Jun 17, 2008 | Televison & Video
Yes the red tube is shorted. I will post a link to the site where I work as they have an entire AV48WP30 with a bad tuner they are selling parts off of including the Tubes. they also provide free info on how to switch out the tubes as a unit which is a fairly easy job. Heres the link.
http://servicemanuals.vstore.ca/
May 21, 2008 | JVC AV-48WP30 48" Rear Projection...
TV colors are wrong
Hi,your problem is not with the tube but with the degausing circuit,a very easy repair which should not cost to much,a small componant called a possister in the primary power supply,a 5 min job for a competant tv engineer
Apr 21, 2008 | Beko 324250WN 28" TV
Red to pink screen after 5-10 minutes of play....
This is not the tube, it's most likely the colour controller and system function ic has gotten scrambled, taking this to a tech to re program should not cost more than about $150 AU
Feb 09, 2008 | RCA TruFlat 27F520T 27" TV
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
