Question about Microsoft Windows XP Professional SP3 Full Version OEM for PC
Slave Harddrive I have an extra harddrive that I wish to install as a slave, unfortunately I cannot at the moment, due to some problems. First, the current harddrive I have is a Maxtor I believe, and it is a master drive, the jumper is on the right spot, but it says it isn't set up to have a slave, and it doesn't have a jumper instruction picture like usual, nor can I find one on Seagate.com. Also the extra harddrive may have a small virus on it, and I cannot get it onto the internet to get an antivirus, so I may have to usb transfer one. Any help would be great!
  • Aaron J. Mar 19, 2011
    I will,don't worry, :)
    Scholar:
  • 114 Answers
Dear soviet guy
these are the jumper settting for both the drives
please check that they are on the right place before if you want to use seagate as a slave try placing the jumpers as mentioned.
Maxtor Jumper Settings
Seagate Jumper Settings
Thanks
GAGAN GUPTA
Posted on Mar 17, 2011
Testimonial: "It was teh exact jumper settings I need, very happy :D"
  • Aaron J. Mar 17, 2011
    Thank you I shall try these methods, and hope it works, cuz I NEED the extra memory haha
  • Gagan Gupta
    Gagan Gupta Mar 17, 2011
    if this is helpful then please rate how helpful it is to you with the help of thumbs
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 149 Answers
Virus can't manipulate your hardrive as slave, as long i know. but you can try cable data must be change and about jumper i think all hardisk must be same for position Master and Slave, and if you don't know what as master or slave, system just check 1 HDD as Bootloader system and the other must be as slave. but you after installed HDD, you must check on BIOS System if HDD have detected on system.
Wont see slave Hard Drive in a Dell Dimension 2400
Did you set the Master harddrive as master?
Or is your reference that you set the jumper cap, on the jumper pins; of both harddrives to Cable Select?
What are the manufacturer names, and model numbers of the two harddrives?
If you just see something like - WD2500JB, that will work.
How many wire is the Flat IDE ribbon cable?
There are 40 wire versions, and 80 wire versions.
Notice I stated - Wire.
They will both have 39 socket holes that are used.
(40 socket holes, with 1 blocked off)
80 wire IDE ribbon cable has Master harddrive in middle.
Slave harddrive at end of cable.
Little weird, huh?
40 wire IDE ribbon cable, has Master harddrive at end of cable, Slave in middle.
As for, "Computer will not see it."
Not trying to insult your intelligence. Am trying to see if we are both on the same page.............
1) You go to My Computer, and there is no drive letter assigned to that harddrive you just installed?
If it is there, you double-click on it to open that harddrive.
Please post back in a Comment.
Regards,
joecoolvette
Mar 30, 2013 | Dell Dimension 8400 PC Desktop
How to add 2nd hdd to hp 513n
As I recall busy_bee96 the harddrive technology used is IDE. (Also known as PATA)
Let's see if there is information on HP Support;
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07813&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=90384
Yes, if we scroll down to the heading - IDE UDMA Modes, we see ATA 66/100 listed.
IDE (PATA) harddrives are used.
The HP pavilion 513n Desktop PC came with an IDE 60GB harddrive.
I don't know what size Slave drive you are going to install, but there may be a size limitation.
On the back of an IDE harddrive are jumper pins. For the original harddrive these may need to be set to Master.
To perform this function the jumper is placed on the two pins for the Master setting.
These are examples of a Jumper,
http://en.wikipedia.org/wiki/File:Jumperblock-shunts.jpg
Small plastic blocks that are hollow inside. There is a rolled spring clip inside the hollow block, that goes over two pins. Connects the two pins together.
General example of the back of an IDE harddrive, showing the Jumper Pins,
I'm going to use Western Digital's IDE harddrive jumper pin settings,
http://wdc.custhelp.com/app/answers/detail/a_id/463/session/L3RpbWUvMTMxODI2NDI0OC9zaWQvSjEzTHVkR2s%3D
Where it states Dual Master is the setting for the Master harddrive.
Where it states Dual Slave is the setting for the Slave harddrive.
Look at the label on your harddrive, and see if it shows the settings for Master.
If not write down the Model Number, and search it online.
OR, post the Model Number in a Comment, and I'll look it up for you.
It may be where there is NO jumper used on the Master harddrive.
Look up the information for the 2nd (Slave drive) harddrive, if it is not stated on the label.
You need to know where the jumper pin settings should be, when using two harddrives.
Past this point you need to look at the flat ribbon cable.
There are IDE ribbon cables that have 40 wires, and 80 wires.
Both styles have 40 contact pins.
(39 actually. 1 is not used)
With the 40 wire IDE cable the Master harddrive is plugged into the MIDDLE connector, on the cable.
The Slave drive is plugged into the END connector.
With the 80 wires IDE cable, it is reversed.
Master harddrive goes to the END connector, Slave drive goes to the MIDDLE connector.
http://www.mikeshardware.com/howtos/howto_connect_ide_hd.html
These videos may also help;
1) http://www.youtube.com/watch?v=4inX3nC6M1E
2) http://www.youtube.com/watch?v=OMTOgt3UiB4&feature=relmfu
(Ol' James is an Electronic Engineer. The lighting was bright, lol!)
For additional questions please post in a Comment.
(Believe upper right of your page. FixYa is undergoing major improvements)
Regards,
joecoolvette
Oct 10, 2011 | HP Pavilion 513n (P9850A#ABA) PC Desktop
Hello to all experts out here, i have this problem.i have an 80Gbts harddrive in my PC. and i want to add 2 harddrives of 40Gbts each. i have tried to do this by my self but i have this diffault. i...
Try these things,
Keep the main, original hard drive pin selected to "master", make sure the original hard drive is connected to the motherboard at the default connection.
IDE's it should be the last connector on the cord and not shared with the cd/dvd rom cord.
Sata's it should be the number "one" connector on the motherboard. The board is typically labeled and with numbers.
The new hard drives you should try putting them into "cable select" since you said setting them to "slave" doesnt work. It's a good idea to just go into bios to make sure those connectors are enabled. Some desktop bios are set to off or disabled.
Do you have a CD/DVD player? Sometimes I have seen they can interfere with adding hard drives. Why not remove it for the time being just to see if it works.
Aug 11, 2011 | Dell Computers & Internet
Mother board came with pc with 160 gb hard disk I have added 500 gb hard disk in addition thepc isworking well and it cannot recogognice the extra hard disk and I have to tighten the jumper connection of...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to ......,press escape then press f10 to save to cmos to restart
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is
Dec 16, 2010 | Asrock P4I45GV R5 Motherboard
How to make IDE slave hard drive?
You can make it slave with jumper settings check in back side of harddrive you can see jumper which is connected to 2 pin of harddrive.
Read instruction on harddrive you can read how to set jumper for make it slave.
Then you ca use it as slave.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 01, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
How do i install a used hard drive into an eMachines T2341? The hard drive still has information on it. do i set it as master, slave, or cable select? hard drive is an IBM 10.1 gb
There are two possible solutions depending on how your desktop is setup.
#1 install the 2nd hard drive and put jumper to CABLE SELECT. When you start the computer it should now appear in the bios as a SLAVE or 2nd hard drive. If not go to #2 below
#2 Turn system off again and change jumper on 2nd hard drive to SLAVE.
Now when your computer restarts it will appear in your bios correctly as the 2nd drive/SLAVE.
Do not make it "MASTER" or you will be trying to boot up to this drive and it may not work as you planned.
FYI: "Cable Select" means the hard drive determines which one is Master and which one is Slave by where it is on the data cable.
Good Luck
Dec 30, 2009 | Computers & Internet
Diamond max 20 hard drive won't install - jumper problems - want as slave, my old one as master
on the back of the drive there should be a black, white or yellow jumper. If you look very carfully at the back of the harddrive where the jumper is, it will tell you which position you need to have the jumper in for slave and which position you need to have it in for master. If it is already in the master position, carefully pull it out then push it back into the correct position to act as slave. Some hardrives simpley have a M for master and a S for slave while other harddrive will actually have the words. I hope this helps.
Oct 23, 2008 | Maxtor Hard Drive
Hi i work in a engineering company who have a old pc,it must be 20 years old nearly,its a compaq deskpro 386/20e,and i need to back it up,it has procim files and .ncf files,ive tried to back it up ,ive...
I have a customer were a similar problem, the machine is so old it will not support any new hardware and obviously the Windows version it is running will not support new software.
Because his machine is starting to fail the first thing I did was connect his harddrive to a more modern machine (XP) as a Slave and make what is known as an Image of his harddrive using Acronis True Image. Now we have a copy of the whole harddrive which can be copied onto another harddrive should the need arise like his harddrive failing.
This is great but what about the updated data? this image is only as uptodate as the day it was made. You can install a simple backup program that is not installed during the install of Windows 95,98 or ME but is available on the Windows CD.
You can find instructions here:
http://support.microsoft.com/kb/264541/en-us
You can download a free trial of True Image here:
http://www.acronis.com/homecomputing/download/trueimage/
The machine I service is set to make a backup everyday and the woman who operates the machine burns a CD of the backup files once a week. Once a month I go and make another Image of the entire harddrive again.
Bear in mind if that machine is as old as you say the BIOS will probably not support a harddrive larger than 4gigabyte and any USB ports are likely to be USB1.1, so backing up to an external harddrive will be slow. You could try installing a Slave to the machine and running True Image on the machine then creating an image on the Slave harddrive.
Sep 30, 2008 | Compaq Computers & Internet
I have a major virus cuasing trouble with most my programs being able to update including my anti-virus software and windows updates, i cant download anything either because i get a message about...
If you have access to another computer with internet access, make sure that computer has the most upto date antivirus and malware scanners installed and slave your harddrive to it. As a slave you will be able to scan your harddrive without initialising your copy of Windows and therefore not initialising the virus on your harddrive.
Aug 21, 2008 | Computers & Internet
Open Questions:
See all Microsoft Windows XP Professional SP3 Full Version Questions
Microsoft Windows XP Professional SP3 Full Version OEM for PC  Logo
264 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
