Question about Behringer FBQ6200 Home Equalizer
My behringer FBQ 1502 produces static sound even there is no input conneted.plz help me because there is no technical support here in our country
  • Brandon Belletieri May 11, 2010
    Is it a low frequency hum sound ( grounding issue ) or a high frequency sound, or static intermittent poppy sound ?
  • 682 Answers
Please bring a balanced cables in your input.(3 pin connector and cables)
Posted on Aug 22, 2008
I have behringer fbq 1502 eqlizer, if we switch on the unit output indicater will blink with noice so please help me to solve this issue
Short circuited component/s at its main board. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 02, 2016 | Behringer Music
How do I connect my mixer to a Behringer Ultaragraph Pro FBQ 3102 and a Behringer Virtualizer Pro DSP2024P in sequence
A bit more info about what you're you;re trying to do would be useful. You would normally use both these as inserts either on the main bus or more likely on an individual or subgroup bus, as you want them in sequence you'll come out of the insert send (tip) into the first unit (whichever you feel is best first) and then from its output into the input of the second unit, then from the output of the second unit into the insert return (ring)
Dec 20, 2015 | Behringer Music
I have pioneer sx 20 tuner/amp and behringer ultragragh pro fbq 1302 graphic equaliser linked together with mono cables via tape i/o rca ports lights on graphic eq lights in sync with sound on sliders but...
It is a bit fuzzy for me, how everything is connected, but just plugging in cables where they fit won't always work. Special not with tulip plugs and cables.
Not sure you Amp has speaker switches, but you could start there. NEVER switch on an amplifier, while the volume button is open. Not even when it is half way. Please every time you want to change something, first lower the volume.
First try to get any sound from the amplifier in the speakers. When you have something like noise in the speakers, then you can test an input on the amp. You could put in a pice of wire in and choose the correct input button and then turn up the volume.
If it starts humming, you are on the correct input. On that input you plug in a device giving enough power (voltage must be within the range for that input) and check if it works.
When you want to know anything about voltages going in an amplifier I add a wiki page, and for all other inputs you can find the levels on Wiki too.
Line level Wikipedia the free encyclopedia
Jan 27, 2015 | Behringer Audio Players & Recorders
Manual behringer fbq 1502
you can download a manual at this link (it's a link direct to the manual, so you only to save or print it, it will appear on your screen)
http://www.behringer.com/assets/FBQ6200_FBQ3102_FBQ1502_M_EN.pdf
There is a quickstart guide also, on the page where I got the manual download from
http://www.behringer.com/EN/Products/FBQ1502.aspx
24.August.2014
Aug 24, 2014 | Behringer Audio Players & Recorders
Factory reset Behringer FBQ2496
After my FBQ 2496 began to go "wild", it finally went blank with a ticking sound. I tried pressing and holding the "Reset" and "Bypass" buttons, simultaneously during power on. It worked after 3 or 4 tries.
Feb 24, 2014 | Behringer USA FBQ2496 Ultra Fast 24 Bit 96...
Circuit diagram for ultragraph pro fbq 1502
and you are skilled at large scale smt replacements..
Feb 18, 2013 | Behringer Fbq1502 Ultragraph Fbq Pro 15...
What are the sound effects provided on the Behringer epa150 PA?
The effects should be the same as the EPA900 unit. Get the brochure here and look for "Effects Table." Hope this helps! http://www.behringer.com/assets/EPA900_P0431_M_EN.pdf
Dec 20, 2012 | Behringer Europort EPA150 Ultra-Compact...
Behringer Xenyx 502 Mic buzzing...PLEASE HELP
Get yourself anti-static spray and spray over the connector before inserting into the jack, most times its dust or static buildup which causes that buzzing sound and in other times replace your mic
Mar 02, 2012 | Behringer Xenyx 502 Audio Live Music Mixer...
shut down all neon lamps and check---------change your input and output cables and check------make power cord direct connection to your equalizer-----not share with other home appliance.
Aug 02, 2008 | Behringer FBQ6200 Home Equalizer
Behringer FBQ6200 Home Equalizer Logo
414 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
