Question about Fortinet, Inc. FortiGate 310B (FG310BBDLUS) Firewall
I have Fortigate 310 fortigate firewall, which used to generate logs locally as well sent logs to remote fortianalyzer and syslog server.It is still generating logs locally but suddenly it stopped generating remote logs......when i execute command diagnose sniffer packet any 'udp port 514' 4, i get source interface as public ip of that firewall which should have been a private ip, i dont know all of a sudden how it has happened......we had this interface problem with 110C fortigate firewall also that time we had upgraded firewall and in the upgraded firmware we got an option to set source ip config log syslogd setting set status enable set server "172.16.15.55" set facility audit set source-ip 172.16.60.1 end which had solved our problem.But my concern without this command also it should work as logs were getting generated before in this FG 310B firewall without set source ip command...........
5 Suggested Answers
kvgopi
  • 74 Answers
SOURCE: Sir, We have Fortigate 800 firewall.
You shall modify the access profile on firewall and apply it to that user.
Or include that user in the same group of other users.
Posted on Jun 12, 2009
  • 186 Answers
SOURCE: hi i am Rupesh from
Only a suggestion
if i where you use web filtering, it is friendly user and very easy to use visit this site http://www.opendns.com/ i use this Web content filtering for may computer shop.. very effective and also have a malware protection.. 100% guarantee
Posted on Apr 26, 2011
dremace
  • 30 Answers
SOURCE: how to block unwanted website
Hallow,
On your browser go to options and check on security setting
Thanks
Posted on Apr 27, 2011
SOURCE: Hello, I want to block
you can go to utm profiles in fortigate and then go to web filter option in that u can find profile..click on profile u can see fortiguard categories in right side and u can make changes there to block the sites.
Posted on Oct 31, 2011
Backup the configuration of fortigate
Administrators can back up the FortiGate unit's configuration file from the System Information widget. Select Backup in the System Configuration row, to back up the firmware configuration file to a local computer, USB disk or to a FortiManager unit.
You should always back up your configuration whenever you make any modifications to the device configuration or performing any firmware updates or changes.
Local PC Select to back up the configuration file to a local management computer. FortiManager Select to back up the configuration file to a FortiManager unit. The Central Management settings must be enabled and a FortiManager unit connected with the FortiGate unit so that the FortiGate unit can send the configuration file to the FortiManager unit.
To enable central management, go to System > Admin > Settings. USB Disk Select to back up the configuration file to a USB key that is connected to the FortiGate unit. Full Config Select to backup the full VDOM configuration. This appears only when the FortiGate unit has VDOM configuration enabled. VDOM Config Select to backup the only the VDOM configuration file. This option backs up only the configuration file within that VDOM. Select the VDOM from the drop-down list, and select Backup. Encrypt configuration file Select to enable a password to the configuration file for added security. Password Enter the password that will be used to restore the configuration file. Confirm Re-enter the password.
Feb 14, 2014 | Fortinet, Inc. FortiGate 80C (FG80CBDLUS)...
Hello, I want to block all unwanted web sites or all sites which containts movies, game, songs...etc. Kindly tell me how to do this setting on fortigate 80C firewall. I Have LAN network connected to...
Aug 09, 2011 | Fortinet, Inc. FortiGate 80C (FG80CBDLUS)...
Hi i am Rupesh from Nepal, how i block url by using fortigate 50B router, in particular IP Adress
Only a suggestion
Apr 26, 2011 | Fortinet, Inc. FortiGate 50B (FG50BBDLUS)...
How to block unwanted website on fortigate 80c firewal
Hallow,
Thanks
Apr 20, 2011 | Fortinet, Inc. FortiGate 80C (FG80CBDLUS)...
Dear Sir, I am using 100A Fortigate Firewall, i wanted to reset and reinstall and configure the product. May i kindly request you all to help me in getting the installation guide to make me confident in...
You'll use your Microsoft Account for everything you do with Office. If you use a Microsoft service like Outlook.com, OneDrive, Xbox Live, or Skype, you already have an account. http://officecomsetupoffice.com/
Dec 18, 2017 | Fortinet, Inc. FortiGate 100A Antivirus...
How to export log from CISCOASA?like other cisco device logging 1.1.1.1 i want similar kind command in CISCO ASA
ASA's log is usualy stored localy on ASA itself, so easiest way to export that log is to go with telnet/ssh/console on it, do a command : show logging and copy/paste output into a new file.
but beware - this log is really short and as soon as ASA is rebooted - it's gone.
you could set asa to log to a syslog server (free on linux/freebsd or for windows use KIWI app).
that way all ASA log output is stored on pc/server running your syslog server.
Jan 03, 2011 | Cisco ASA 5510 Firewall
I wanna open port for my DVR dvr is :- ip 192.168.1.88 cmd port 9201 video port 9202 and my router is fortigate60 i hope any one can give me full solution best regards
You will need the router login info, then using a browser go to:
https://192.168.1.99
That will bring you into the settings area of the router. Then do one of two things, find Port Forwarding, and forward the public 9201 & 9202 to the DVR at 192.168.1.88 port 9201 and 9202. Make sure to do this for both UDP and TCP.
Another and easier option, is to go to your DMZ setting. Just turn DMZ on and set it to 192.168.1.88.
Doing it with the DMZ will take care of any ports that need forwarding, they will point to the 88 machine (your DVR).
EJ
From the management computer browse to https://192.168.1.99. The FortiGate web-based manager appears.
From the management computer browse to https://192.168.1.99. The FortiGate web-based manager appears. From the management computer browse to https://192.168.1.99. The FortiGate web-based manager appears.
Jan 26, 2010 | Fortinet, Inc. FortiGate 60: FortiGate Pro...
Fortinet, Inc. FortiGate 310B (FG310BBDLUS) Firewall Logo
383 people viewed this question
Top Fortinet, Inc. Computers & Internet Experts
J John
Gopi Venkatesan
Gopi Venkatesan
David Ellis Rhea
Are you a Fortinet, Inc. Computer and Internet Expert? Answer questions, earn points and help others
