Can dv 2150 be programed without remote set time etc.
  • 902 Answers
Yes it can via onscreen menu if you hook up receiver to tv and the ngo to reciever menu (not via hdmi thou) and you can also do it on menu options or set up options on the receiver itself let m know if thi helped
Posted on Mar 17, 2011
Lost my manual for my remote need codes for a quasar tv the remote is a ge 2150 v2
you can buy a universal remote from AV shop and tune to any TV. Can buy one that works as combos for TV, DVD, VHS etc, does away with all remotes
Sep 21, 2012 | Televison & Video
How to bridge NAD 7150 with 2150
Bridge connections
Using 2150 as a slave
Sep 09, 2012 | NAD Audio Players & Recorders
Diagram for fuel line routing for a poulan 2150 chainsaw?
The 2150 has a remote primer, so there will be three pipes, the pipe coming from the fuel tank with the fuel filter on the end is the main fuel tube, this fits to the connection on the carb nearest to the pump cover on the carb ( alluminium cover held with a single screw ) the other connection on the carb has a pipe to the shorter of the two connections on the back of the primer ( suction side ) the longer connection on the back of the primer ( pressure side ) has a pipe back to the fuel tank, so the primer pulls fuel from the tank, into the bulb, and dumps it back to the tank, it does not push fuel into the carb, this way you can depress the bulb as many times as you like without flooding the engine.
Jul 05, 2012 | Poulan Pro Chain Saw 46cc 20"
How to program a haier flat tv and a supersonic DVD player with a jumbo innovage remote control?
There is a way to program this remote to devices without the codes. If it is possible to install the device to this remote at all, this will do it.
This is an alternative method to programming your device without using the code list. The remote control will scroll through the list of codes to identify the correct code for your device.
  1. Turn onthe device that you want to set.
  2. Aim the remote control at the device and press and hold down the CODE SEARCH button for at least 3 seconds until the red LED lights up solid red.
  3. Press the device button for the item you wish to program, e.g. TV,DVD,VCR, etc. and the LED light will blink once and then remain solid red.
  4. Press ON/OFF button on remote slowly and repeatedly until the device you are trying to program shuts off. (Note: LED will blink once each time you press ON/OFF button).
  5. Once this occurs, press ENTER button to store the code and the LED light will turn off.
May 05, 2011 | Innovage Jumbo Remote Control
Can't get my jumbo universal remote to work with my sam sung tv model #LN22B350F2D
You can use CODE SEARCH SETTING for the Jumbo Universal Remote. Have you tried it?
Thanx
Jul 20, 2010 | Innovage Jumbo Remote Control
I need instructions and codes for Innovage Jumbo Remote
www.remotecentral.com
This is a link for a list of codes.
or
Code search setting is an alternative method to programming your device without using the code list
Turn on the device you want to set
Press the decive button for the item you want to program
Press and hold the SET button until the LED light up solid red
Press the MUTE/SEARCH button. The LED will shut off first then light up solid red.
When the device turns off, press the OK button to store this code.
Code Retrieval
Press and hold the device button you want to display on the remote control
Press the NUMBER 1 then count the number of flashes
Press the NUMBER 2 etc
Press the NUMBER 3 ets
Press the NUMBER 4 etc
If the LED light flashes 10 times the number is 0
Nov 11, 2009 | Innovage Jumbo Remote Control
PROGRAMING MY MAGNAVOX UNIVERSAL REMOTE CONTROL
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 18, 2008 | Philips Magnavox Learning Universal Remote
DV 2150 Remote Control Codes
If it's not a well known brand, you're likely not going to find a code for it. I've heard of Go Video, but I don't think it's a very popular brand. (I could be wrong on this point)
Codes don't exist for every tv/dvd/vcr/surround system.
If the remote you bought doesn't have your dvd player listed, then you're probably out of luck.
If it's a very expensive universal remote (like $50-$100) then you might find either a code or a firmware update for it on the manufacturers website.
If not, try every code the instructions list. If you're lucky, one of them will work. If not, c'est la vie.
Feb 13, 2008 | GoVideo DV2150 DVD Player/VCR
Change recording speed
The only solution to this problem is to buy a new remote from the manufacturer. Aftermarket remotes that I have looked at: RCA, PHILLIPS, SONY, etc do not have a speed select button for the VCR. (which IMHO is stupid) Come on aftermarket people- it cant be that hard to program a speed select button!
Oct 13, 2007 | Emerson EWV603 VHS VCR
Date and time etc
The CR2025 Lithium battery, holds the date and time in it's memory and is neccassary for the remote control to work. The CR2025 Type Lithium battery needs replacing. That should sort it. Please rate this solution
Nov 20, 2006 | JVC GR-D290 Mini DV Digital Camcorder
 Grubhead
Grubhead
