Question about RCA Televison & Video
Dish Network HD Monitor HD 40-300
We had an electrical storm and the antenna was struck. In the coax circuit we had a antenna amplifier (that plugged into a 110 receptical), then the digital converter box, then rca plugs to the video 1 port to the TV.
The coax cable looked burned at the connectors. The breaker tripped.(I think the most current went through the amplifier to the ground) and the video inputs for the TV dose not work. The screen comes on. You can navigate the channels.The menu shows up and works. The tuner shows snow but It is not connected to the antenna.
My questions are:
can it simply an input cluster of some type?
if so is it an easy component to replace.
I have a Dish Network HD40-310 Monitor. When you turn power on the green power light comes on, then tv makes funny noise, then goes off again without producing any picture. Any ideas how to fix?
Posted on Jan 01, 2010
  • Johnie916 Aug 29, 2011
    From what I have read, this is a very common problem with this model television. I just happen to find one that was being tossed out. When I turned it on, the power light flashed 3 times then turned off. I read from several different sites and no one has been able to answer the question. I'm just glad that I didn't pay for this thing. Back to the garbage it went!
Samsung hdtv how to know if lightning fried it
If the tv will not turn on it is safe to assume that the electrical storm did damage something in your television.
Jul 11, 2012 | Samsung 46 UN46D6000 LCD TV
I have a RCA Home Theater System RT2380BK I have the speakers wired but i want to hook it up to my dish network when I'm watching movies.Can u help me?
The dish network reciever should have audio and video out on the back, If its a HD device it should also have COAX out (hd audio) get the cables for audio and feed the into a input on the back of your home theater system, there should be several inputs, usually labled like video 1 video 2, tape deck etc etc. the audio in are red and white or red and black usually, the coax connector is orange, and you only need one cable to hook that up. If you have HD audio on the dish network that will sound best in your home theatere system
Mar 10, 2011 | RCA RT2380 Home Theatre System System
Which end is the receiving end of a house tv areial
peter_321
One end of the coax cable is connected to your antenna. The other end connects to a coax port on the back of the receiver labeled "TV/Antenna Cable In". All DISH Network receivers have this port on the back except our "K" series receivers. These receivers require a module to plug into the back of the receiver. Connect the antenna cable to this port, "TV/Antenna Cable In", if the receiver has the port available. I hope this helps.
Ray Calo
DISH Network
Mar 05, 2011 | Televison & Video
I am getting a HD signal to my HDTV with HDMI but the coax out connection is not working. Should I call DISH or ???
Hi jgolf721my name is Mike Houston of DISH Network and I was reading your post and I waswondering if your not getting a picture through the COAX connection. The COAXconnection will not transmit a HD picture only SD, and if your not getting apicture at all you will want to check some things. You will want to make sureit is on the right input or channel and unplug the receiver for 10 seconds andafter you plug it back in it will power up. You should see a DISH Networkscreen acquire the signal, if you have anymore questions you can e-mail me. Michael.houston@dishnetwork.com
Feb 21, 2011 | DISH Network Televison & Video
Trouble with remote on second TV, not responding from back of house
Hi, Mary with Dish Network Customer Service. The TV2 remote (UHF) can work up to 200 feet from the receiver but can also get interference issues that cause it to not work consistently. One of the things that I recommend is to readdress the remote to the receiver and possible installing a pigtail to the remote antenna on the back of the receiver. I have this on one of my receivers and have never had an issue since. To troubleshoot try these steps:
Step 1: Verify correct Remote being used
Check that the remote matches the TV. Use remote key or sticker on remote to confirm. TV1 is located in the same room as your DISH receiver.
Step 2: Check that UHF Remote Antenna is Secure/Upright
If UHF, check that your UHF remote antenna is securely connected to the "Remote Antenna" port on the back of your receiver and that the antenna is upright.
Step 3: Address Remote
To SAT: Access "System Info" - press and release the "SAT" button then press the RECORD button on remote control. If unable to access System Info using the receiver, use "Video Frozen/Locked Up".
To TV/DVD/AUX: Check for current remote codes and address remote.
Step 4: Check that Remote Control Batteries are Fresh
Check that the you have recently replaced the batteries. If not, install new batteries.
Step 5: Reset Receiver
If the issue is only on ONE receiver, unplug the DISH receiver for 10 seconds and plug back in.
Please note: It may take up to 5 minutes for the reset process to be completed.
If you are still having an issue, to install a pigtail you will need a piece of Coax cable, approx. 3 feet long and a barrel connector. Remove the remote antenna from the back of the receiver, attach the coax cable to the receiver. At the other end of the coax cable insert the barrel connector and add the remote antenna. Then drape the coax cable behind and towards where the TV2 is located. It takes the remote antenna away from where all the electronics are, which are major causes of UHF interference. I hope this helps resolve your issue.
Jan 14, 2011 | DISH Network ViP622 DVR DTV Receiver /...
Unhooked all lines in back of tv cant remember to rehook up have2
granmabj,
There are common connections to each receiver but there are unique connections also depending on the receiver. Solo receivers have a coax cable coming from the Dish outside connected to Satellite In. Duo receivers and DVR HD receivers have the coax cable that comes from the dish outside that connects to Satellite 1 and Satellite 2 using a splitter. There is also a cable (coax, RCA (yellow, white, red) or component (green, blue, red - video, white, red - audio) or an HDMI if HD) connected from the receiver to the TV 1. For a duo receiver TV 2 may be backfed on the cable coming from the dish outside using diplexers. This may sound confusing but you can call 1-800-333-3474 for assistance.
Ray Calo
DISH Network
Jul 23, 2010 | DISH Network DVR-625 DTV Receiver /...
HDTV Converter hookup with sat. and antenna
Hi there Phil...... this switch from analog to digital has lots of folks scratching their heads. Fortunately I have some great news for you. The signal coming from the Dish network does not need a converter as it is already digital.
May 29, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Dish Network Channels Work but Local Television Channels Do Not
Do you have an antenna hooked up? You'll need one hooked to your converter box because the digital signal is so much more difficult to tune in to. This may help:
www.antennaweb.org
If you live closer than 15 miles, rabbit ears
If you live closer than 20 miles, omnidirectional
If you live closer than 50 miles, midrange outdoor (oldschool arial w/ rotator)
Further than 80 miles, you'll need a long range with rotator, perhaps even an amplifier to go with it. Print off what your results were on antenna web and bring it to a RadioShack or a local antenna store and they should be able to point you to the right antenna for your particular location.
Apr 21, 2009 | Sony KDL46S3000 46 in. LCD HDTV
Panasonic plasma TV has a black screen after disconnecting Dish TV
proably not tied in tv nomore dish will take over that prot if u got dish hd u get locakls form dish free in hd dont need attc nomore
Oct 10, 2008 | Panasonic TH-37PD25U/P 37 in. EDTV-Ready...
HD TV
In order to receive HD signals, you will need an HD receiver from Dish Network. You can buy an HD antenna from pretty much any store that sells TV stuff (Target, Wal*Mart, BestBuy, etc) which will allow you to receive over the air HD signals. But in order to get your satellite channels in HD, you will need an HD receiver from Dish Network.
Jun 09, 2008 | Televison & Video
Televison & Video Logo
857 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
