Question about Car Audio & Video
I need to reverse the installation of an after-factory satellite radio. The antennae installation by Best Buy disabled my FM and AM capabilities. The car has factory installed XM but at the time, I was a Sirius subscriber. Thanks.
  • 902 Answers
You need to open up your cd / factory sat in dash unit. there is a big input kinda looks like a cig ligher input on the back the and you will find a loose cord back in the dash thasts your antenta cable just plug it back in *you may need to buy and adapter thats why best buy just left it as it is) i would be furious and go back to best buy asap (i worked at best buy its so common that the installers do that) this will be your solution
Posted on Mar 17, 2011
  • jimmy679 Mar 17, 2011
    THANKS!
    I sort of knew that part. I did have to buy the adapter that is what disabled my AM/FM capabilities. How do I get the faceplate off without marking the dash? It's polished wood.
    Thanks again.
  • brian shevack Mar 17, 2011
    its not just the faceplate you need to remove its the unit on the side of the unite are two little slide like bars you need to go to best buy and get the removal kit (it came with the unit when you bought it so if you lost it then you have to do that) Glad i can help! please if you like my solution give me a rating or w/e they do here lol
I have a 2008 Hyundai Accent with just the Factory Am/Fm/ cd radio. I would like to change it to the Factory Am/Fm/Cd with Satelite radio. Will this work? Will the Antenna that is on the car now work for...
it will work but i believe you will need to install a seperate antena which can be purchased from hyundai directly. for 30 bucks, or best buy. but my understanding is that the car does have the unit has the anenta built into it it let me know if this helpeed!
Mar 18, 2011 | Car Audio & Video
Am/fm radio stations not clear... I have the AM antenna attached... but there is no attachment for FM
First of all check for any nearby source of interference.....Move your unit away from all computers, fluorescent lights, neon lights, microwaves, cell phones, and cell phonemag-glass_10x10.gif chargers. These devises tend to produce noise in the medium frequency band, where AM radio is broadcast.
If the unit plugs into the wall with a nonpolarized plug (where both prongs are the same size), try reversing the plug inmag-glass_10x10.gif the outlet. Moving the plug to another outlet might help, too.
check for fault in the antenna lead, (common) or bad earth on the antenna to body
If you don't have an antenna connected to your FM receiver,With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 2 If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
  • Step 3 If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
  • Step 4 If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
  • Step 5 Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
  • Read more: How to Strengthen FM Radio Reception | eHow.com http://www.ehow.com/how_114024_strengthen-fm-radio.html#ixzz0u9nhGXAL
    If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters. Make sure to Switch from stereo to mono.
  • Step 4 With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 5 Alternatively, upgrade to a third-party passive or powered antenna.
  • Step 6 Install a rotatable roof antenna for the best possible reception. Connect your unit to an existing televisionmag-glass_10x10.gif roof antenna for the next-best alternative.
  • Read more: How to Improve FM Reception | eHow.com http://www.ehow.com/how_5554_improve-fm-reception.html#ixzz0u9oTaz4Y
    Jul 19, 2010 | RCA RT2760 System
    Improve reception
    HI there,
    Well Yes you can improve the reception, please follow the below steps -
    Improve FM Radio Reception -
    1. If you don't have an antenna connected to your FM receiver, purchase a simple dipole antenna--a simple T-shape flexible wire-- and connect it to the FM antenna inputs on the receiver. Because FM signals are directional, you'll want to experiment with the positioning of the wire to find the best reception of the station you're trying to receive.
    2. If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
    3. If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
    4. If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
    5. Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
    Improve AM Reception -
    1. Gradually rotate the radio 360 degrees. Leave it in the position where it sounds best.
    2. Reverse the AC plug if it isn't polarized. (If you can flip the plug over, then it's non-polarized.)
    3. Plug the radio into a different AC outlet.
    4. Move the radio closer to a window.
    5. Experiment to learn if appliances and powered products in your home are causing interference: computer monitor, television, electric blanket, light dimmer, fluorescent light, hair dryer, air conditioner, smoke detector. If possible, turn off the offending item. Otherwise, move the radio to another room.
    6. Upgrade to an external antenna if your receiver, tuner or radio has a place to connect one.
    7. Buy a passive AM antenna that doesn't need to be connected to a radio or receiver.
    Good Luck!!
    Thanks
    Dec 29, 2009 | RCA RP5430 Clock Radio
    Pioneer inno radio-doesn't work in car
    When its in the car dock, the Inno sends an FM signal to the car radio. It does not receive a signal from the car radio. You must have the external antenna correctly installed outside the vehicle for the Inno to work. The built in antenna is disabled when the device is placed in the car dock. Make sure to test it outside, since garages or car ports will block the signal.
    Dec 03, 2008 | Pioneer XM2go Inno Satellite Radio...
    Sportster 4
    Shouldn't need one. Does the rear antenna connect to the direct FM box?
    Aug 30, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
    FM radio tune with fm antenna on a305-s6857
    maybe you can find the instructions online, or try google it,if not talk to the store or company you bought it from
    Aug 17, 2008 | Computers & Internet
    STATIC/INTERFERENCE
    &R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
    • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
    • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
    Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
    Solution 2 - Cassette Tape Adapter
    : If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
    Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
    Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
    Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
    You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
    We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
    Sincerely,
    SIRIUS SATELLITE RADIO
    To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
    Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
    Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
    Connect sirius fm adapter to 2008 honda civic sedan radio
    You should use the direct FM box to get the static to go away. You unplug the antenna from the radio, plug the antenna lead from the box into the radio, the antenna line plugs into the box. You will have a mini jack that plugs into your radio or dock.
    This way you can switch it on any station to get rid of the static.
    You shouldn't need to take the dashboard out to get to the radio. Usually you have to take the trim pieces in front of the radio to get the antenna line out.
    Sometime you can reach it from the back of the radio if there is enough clearance to get cak there.
    Jun 12, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
    Sirius satellite radio
    You will need to get another sat antenna, and locate it somewhere either above the camper, or where the camper does not obstruct the antenna. Any store that sells sat radio equipment (Fry's, Best Buy, etc) will have the micro antenna. Install it either on the hood of the truck, or on top of the camper. You will need to run the antenna to the rear of the dash. They make Y couplers that will allow you to run both the OEM antenna and the extermal antenna at the same time, and it will not hurt the system to have both wired in at the same time.
    Oct 01, 2007 | Kenwood SIR-KEN1 SIRIUS Radio Receiver
    Car Audio & Video Logo
    57 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
